Date/Time: Tue, 26 Nov 2024 12:20:35 +0000
I opened a new stock chart yesterday, but it stands still
View Count: 283
[2023-11-23 14:46:58]
User716459 - Posts: 127
I opened a new stock chart yesterday, but it stands still. The time and date is yesterday. Please let me know how to start the chart and how to make the next charts opened have the settings, my preferences, of the previously opened chart. Thank you A
[2023-11-23 23:31:21]
Sierra_Chart Engineering - Posts: 17179
The US markets have closed Wednesday evening. And are closed Thursday 2023-11-23.
However, we see you are using Interactive Brokers.
For US Stock/equities data follow the instructions below:
To access historical and streaming market data independent from your Trading service. Follow these instructions.
Set "Global Settings >> Data/Trade Service Settings >> Current Selected Service" to "SC Data-All Services".
Press "OK"
And then translate the symbols in your Chartbooks and Sierra Chart using this "Edit' menu command:
Edit Menu: Edit >> Translate Symbols To Current Service (Translate Symbols to Current Service)
You can then use the data provided by Sierra Chart independent of your trading service.
For real-time data activate the US Equities exchange:
Denali Exchange Data Feed: US Equities Consolidated Tape Data Feed Notes
Date Time Of Last Edit: 2023-11-23 23:31:47
[2023-11-24 11:51:31]
1 I followed the instructions and started the Apla chart, but I can't start another one following the same steps. The fields I am supposed to change are not active, cannot be edited.
2. time other than the one selected for Brussels. How to change?
3. how to make the new chartbook have the settings, studies as the existing one?
I set up a chart as below and I want, for example, Ebay or another company, when I open a new chart, to have these settings.
4. how to remove the subtitles and get the time scale at the bottom and the scale on the right?
5. countdown t. I installed and it does not hit the bottom right corner. Platf. To contract. It is actually.
Attached is the screen
Thank you
Arek
Private File
[2023-11-24 16:45:38]
I already know almost everything. Please let me know how to remove the subtitles above the volume and the time is 15 m. early.
[2023-11-27 16:19:14]
John - SC Support - Posts: 36286
Refer to the information starting at the following link and the following 2 sections:
Chart Studies: Subgraphs Tab >> Display Study Subgraphs Name and Value - Global
The time on the chart is delayed by 15 minutes because you are using our Delayed Streaming data. If you want real-time data for the U.S. Equities, then you would need to setup the "U.S. Equities Consolidated Tape" exchange in our Denali Exchange Data Feed. Follow the instructions at the following link:
Denali Exchange Data Feed: *Setup Instructions: All Other Exchanges*
Date Time Of Last Edit: 2023-11-27 16:21:18
[2023-11-27 20:09:53]
See the response above. Let us know if you still have outstanding questions.
