Date/Time: Tue, 26 Nov 2024 13:18:32 +0000
The Maximize minimize buttons appears to br too small
View Count: 301
[2023-11-22 22:06:39]
User519646 - Posts: 15
Hello, while after maximizing the chart window, the buttons that showing minimize, restore and close is showing very small, how can we bring those to a normal size. I have attached a screenshot for that issue
[2023-11-22 22:06:57]
Sierra_Chart Engineering - Posts: 17179
We do not know why you are asking us this question. This is operating system controlled. You need to contact the operating system developer about this. Which is Microsoft.
[2023-11-23 09:54:48]
funbun - Posts: 90
Here's an alternative -
Add a Control Bar to the chart -> Right click on the bar to open the settings -> Scroll down to "Window" and toggle it open -> Add the "Window Maximize" & "Window Restore" to the Control Bar
Open the properties of each command and increase the font size to your liking.
Hope it helps
Date Time Of Last Edit: 2023-11-23 09:56:51
