Date/Time: Tue, 26 Nov 2024 13:25:34 +0000
Blank Charts Footprin and volume profile
View Count: 280
[2023-11-22 21:26:52]
User437490 - Posts: 2
I upgraded to live data feed. some of my charts are blank. Volume profile and footprint charts are blank. What should I do?
Reading Internal Order ID file. | 2023-11-22 19:17:50.088
Reading Trade Orders file. | 2023-11-22 19:17:50.151
Reading Trade Positions file. | 2023-11-22 19:17:50.152
Reading Trade Account Data files. | 2023-11-22 19:17:50.152
Software version: 2564 64-bit | 2023-11-22 19:17:50.153
Primary Thread ID: 4748 | 2023-11-22 19:17:50.153
Usage end date: 2023-11-27 | 2023-11-22 19:17:50.153
Enabled for: Sierra Chart Historical Data Service. | 2023-11-22 19:17:50.153
Enabled for: Denali Real-Time Exchange Data Feed. | 2023-11-22 19:17:50.153
Enabled for: Delayed Denali Exchange Data Feed. | 2023-11-22 19:17:50.153
Allow Support for Sierra Chart Data Feeds is enabled. | 2023-11-22 19:17:50.153
Current selected Data/Trading service: Teton CME Order Routing | 2023-11-22 19:17:50.153
Custom symbol settings values: enabled | 2023-11-22 19:17:50.153
Chart Update Interval: 500 | 2023-11-22 19:17:50.153
Intraday Data Storage Time Unit: 0 | 2023-11-22 19:17:50.153
Time Zone: +00:00:00 (GMT+00BST+01,M3.5.0/01:00,M10.5.0/02:00) | 2023-11-22 19:17:50.153
2023-11-22 19:17:50 Local computer time in UTC | 2023-11-22 19:17:50.153
2023-11-22 19:17:50 Local computer time in SC Time Zone | 2023-11-22 19:17:50.153
2023-11-22 19:17:48 Server time in UTC | 2023-11-22 19:17:50.153
Local computer UTC time and Server UTC time difference: 1 seconds. | 2023-11-22 19:17:50.153
Program path: C:\SierraChart\ | 2023-11-22 19:17:50.153
Data Files path: C:\SierraChart\Data\ | 2023-11-22 19:17:50.153
OS Version Number: 10.0 | 2023-11-22 19:17:50.153
Locale Setting: C | 2023-11-22 19:17:50.153
DLLs: UserContributedStudies_64.dll | 2023-11-22 19:17:50.153
Allowed protected custom studies: | 2023-11-22 19:17:50.153
Crash reporter started: true | 2023-11-22 19:17:50.153
Checking for new symbol settings. Requested symbol settings MD5 for service code sc_futures_direct.dtc.trading. Request ID: 1. | 2023-11-22 19:17:50.175
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2023-11-22 19:17:50.209
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2023-11-22 19:17:50.373
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2023-11-22 19:17:50.374
Received 5 login tokens. | 2023-11-22 19:17:50.728
Symbol settings MD5 received. Request ID: 1. | 2023-11-22 19:17:52.225
Requested symbol settings for service code sc_futures_direct.dtc.trading. Request ID: 2. | 2023-11-22 19:17:52.225
Requested user files to download. | 2023-11-22 19:17:52.695
Teton CME Order Routing | Firm: IronBeam | 2023-11-22 19:17:54.691
Teton CME Order Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11085 | 2023-11-22 19:17:54.694
DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2023-11-22 19:17:54.695
DTC Client socket (2) | New receive buffer size: 0 | 2023-11-22 19:17:54.695
DTC Client socket (2) | Connecting to IP: 208.185.224.130. | 2023-11-22 19:17:54.695
Symbol settings received. Request ID: 2. | 2023-11-22 19:17:54.791
Teton CME Order Routing | Network connection to server complete. | 2023-11-22 19:17:54.939
Teton CME Order Routing | Starting socket receive thread. | 2023-11-22 19:17:54.939
Teton CME Order Routing | Sending encoding request to server: Binary VLS. Compression: none | 2023-11-22 19:17:54.939
Teton CME Order Routing | Setting DTC encoding to Binary VLS | 2023-11-22 19:17:55.319
Teton CME Order Routing | Sending logon request message. | 2023-11-22 19:17:55.319
Teton CME Order Routing | Received logon response. | 2023-11-22 19:17:55.623
Teton CME Order Routing | Server Name: SC DTC Server. | 2023-11-22 19:17:55.623
Teton CME Order Routing | Server protocol version: 8. Client protocol version: 8 | 2023-11-22 19:17:55.623
Teton CME Order Routing | Connection error: No trade accounts assigned | 2023-11-22 19:17:55.623 *
Teton CME Order Routing | Failed connections: 1 | 2023-11-22 19:17:55.623
Teton CME Order Routing | Waiting for socket receive thread to end | 2023-11-22 19:17:55.645
DTC Client socket (2) | CloseSocket call. | 2023-11-22 19:17:55.645
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2023-11-22 19:17:55.645
Teton CME Order Routing | Disconnected. | 2023-11-22 19:17:55.646
DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-22 19:17:55.770
DTC Client socket (2) | Closed. | 2023-11-22 19:17:55.770
Files to Open on Startup | Opening file: ExampleChartbook.cht | 2023-11-22 19:17:58.053
ESZ23_FUT_CME 5 Min #4 | Reloading chart. | 2023-11-22 19:17:58.236
10YX23_FUT_CME 5 Min #8 | Reloading chart. | 2023-11-22 19:17:58.255
ESZ23_FUT_CME 1 Min #9 | Reloading chart. | 2023-11-22 19:17:58.387
ESZ23_FUT_CME #1 | Reloading chart. | 2023-11-22 19:17:58.469
ESZ23_FUT_CME 5 Min #2 | Reloading chart. | 2023-11-22 19:17:58.482
ESZ23_FUT_CME 10 Min #5 | Reloading chart. | 2023-11-22 19:17:58.533
ESZ23_FUT_CME #3 | Reloading chart. | 2023-11-22 19:17:58.661
CLF24_FUT_CME 10 Min #6 | Reloading chart. | 2023-11-22 19:17:58.729
10YX23_FUT_CME #7 | Reloading chart. | 2023-11-22 19:17:58.875
10YX23_FUT_CME #7 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-11-22 19:17:58.938
Numbers Bars | Service Package does not support this function or account is expired. Select 'Help >> Account Control Panel' for account management. | 2023-11-22 19:17:58.961 *
Numbers Bars | To restore the chart, remove this study. | 2023-11-22 19:17:58.961 *
Numbers Bars Calculated Values study: Service Package does not support this function or account is expired. Select 'Help >> Account Control Panel' for account management. | 2023-11-22 19:17:58.961 *
Mapping ESZ23_FUT_CME to ESZ23. Service code: cme | 2023-11-22 19:17:59.466
Using symbol data fast lookup vector | 2023-11-22 19:17:59.466
Starting DelayedDownloadMonitoringTimer | 2023-11-22 19:17:59.467
Starting HDTimeoutTimer | 2023-11-22 19:17:59.467
Added historical Intraday data request for ESZ23_FUT_CME to the queue. | 2023-11-22 19:17:59.467
Intraday data recording state for symbol ESZ23_FUT_CME is set to download 'Pending'. | 2023-11-22 19:17:59.467
Triggering next historical data download in queue. | 2023-11-22 19:17:59.521
HD Request # 1 | Downloading Intraday chart data for ESZ23_FUT_CME to the file ESZ23_FUT_CME.scid. Service: cme | 2023-11-22 19:17:59.521
HD Request # 1 | Download start date-time: 2023-11-22 18:50:02.000000. File last date-time: 2023-11-22 18:50:02.876000 | 2023-11-22 19:17:59.522
HD Request # 1 | Using server: ds26.sierracharts.com port 10150 | 2023-11-22 19:17:59.698
Socket (1) | Creating socket. | 2023-11-22 19:17:59.701
Socket (1) | New receive buffer size: 0 | 2023-11-22 19:17:59.701
Socket (1) | Connecting to IP: 142.215.17.188. | 2023-11-22 19:17:59.701
Mapping 10YX23_FUT_CME to 10YX23. Service code: cbot | 2023-11-22 19:17:59.717
Added historical Intraday data request for 10YX23_FUT_CME to the queue. | 2023-11-22 19:17:59.717
Intraday data recording state for symbol 10YX23_FUT_CME is set to download 'Pending'. | 2023-11-22 19:17:59.717
Triggering next historical data download in queue. | 2023-11-22 19:17:59.717
Numbers Bars | Service Package does not support this function or account is expired. Select 'Help >> Account Control Panel' for account management. | 2023-11-22 19:17:59.719 *
Numbers Bars | To restore the chart, remove this study. | 2023-11-22 19:17:59.719 *
Numbers Bars Calculated Values study: Service Package does not support this function or account is expired. Select 'Help >> Account Control Panel' for account management. | 2023-11-22 19:17:59.719 *
ESZ23_FUT_CME #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-11-22 19:17:59.727
Mapping CLF24_FUT_CME to CLF24. Service code: nymex | 2023-11-22 19:17:59.770
Added historical Intraday data request for CLF24_FUT_CME to the queue. | 2023-11-22 19:17:59.770
Intraday data recording state for symbol CLF24_FUT_CME is set to download 'Pending'. | 2023-11-22 19:17:59.770
Triggering next historical data download in queue. | 2023-11-22 19:17:59.770
HD Request # 1 | Setting DTC encoding to Binary VLS | 2023-11-22 19:18:00.087
HD Request # 1 | Sending historical data logon request message. | 2023-11-22 19:18:00.087
HD Request # 1 | Requesting Intraday data. Start date-time: 2023-11-22 18:50:02. Record interval: 0. Symbol: ESZ23 | 2023-11-22 19:18:00.470
HD Request # 1 | Decompressing data. | 2023-11-22 19:18:00.655
HD Request # 1 | Receiving Intraday data for ESZ23_FUT_CME starting at 2023-11-22 18:50:02.028000 | 2023-11-22 19:18:00.863
Socket (1) | CloseSocket call. | 2023-11-22 19:18:01.210
Socket (1) | Shutdown started. Waiting for graceful close. | 2023-11-22 19:18:01.210
Historical data download thread signaled to stop. | 2023-11-22 19:18:01.210
HD Request # 1 | Timestamp of first Intraday data file record written: 2023-11-22 18:50:06.685000. | 2023-11-22 19:18:01.211
HD Request # 1 | Received 13076 Intraday data records from 2023-11-22 18:50:02.028000 to 2023-11-22 19:07:58.261000 (17.9 minutes. Delay: 10.0 minutes) and wrote 13049 records for ESZ23_FUT_CME | 2023-11-22 19:18:01.211
HD Request # 1 | Completion time: 2s. | 2023-11-22 19:18:01.212
HD Request # 1 | Intraday data download complete for ESZ23_FUT_CME. Unique request ID: 1 | 2023-11-22 19:18:01.212
Removing historical data download ID 1. | 2023-11-22 19:18:01.212
Real-time Intraday chart data file updates started for ESZ23_FUT_CME | 2023-11-22 19:18:01.212
Intraday chart data file opened for ESZ23_FUT_CME | 2023-11-22 19:18:01.212
HD Request # 1 | Enabling Intraday chart updating for symbol. | 2023-11-22 19:18:01.212
Triggering next historical data download in queue. | 2023-11-22 19:18:01.212
Historical data for ESZ23_FUT_CME is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2023-11-22 19:18:01.212
HD Request # 2 | Downloading Intraday chart data for 10YX23_FUT_CME to the file 10YX23_FUT_CME.scid. Service: cbot | 2023-11-22 19:18:01.212
HD Request # 2 | Download start date-time: 2023-11-22 18:47:54.000000. File last date-time: 2023-11-22 18:47:54.300000 | 2023-11-22 19:18:01.213
HD Request # 2 | Using server: ds28.sierracharts.com port 10149 | 2023-11-22 19:18:01.213
Socket (3) | Creating socket. | 2023-11-22 19:18:01.216
Socket (3) | New receive buffer size: 0 | 2023-11-22 19:18:01.216
Socket (3) | Connecting to IP: 142.215.18.147. | 2023-11-22 19:18:01.216
Socket (1) | Socket gracefully closed by remote side. | 2023-11-22 19:18:01.343
Socket (1) | Closed. | 2023-11-22 19:18:01.343
HD Request # 2 | Setting DTC encoding to Binary VLS | 2023-11-22 19:18:01.533
HD Request # 2 | Sending historical data logon request message. | 2023-11-22 19:18:01.533
HD Request # 2 | Requesting Intraday data. Start date-time: 2023-11-22 18:47:54. Record interval: 0. Symbol: 10YX23 | 2023-11-22 19:18:01.878
HD Request # 2 | Decompressing data. | 2023-11-22 19:18:02.068
HD Request # 2 | Receiving Intraday data for 10YX23_FUT_CME starting at 2023-11-22 18:47:54.300000 | 2023-11-22 19:18:02.305
Socket (3) | CloseSocket call. | 2023-11-22 19:18:02.305
Socket (3) | Shutdown started. Waiting for graceful close. | 2023-11-22 19:18:02.305
Historical data download thread signaled to stop. | 2023-11-22 19:18:02.306
HD Request # 2 | Timestamp of first Intraday data file record written: 2023-11-22 18:51:33.410000. | 2023-11-22 19:18:02.359
HD Request # 2 | Received 14 Intraday data records from 2023-11-22 18:47:54.300000 to 2023-11-22 19:06:28.314000 (18.6 minutes. Delay: 11.6 minutes) and wrote 13 records for 10YX23_FUT_CME | 2023-11-22 19:18:02.360
HD Request # 2 | Completion time: 1s. | 2023-11-22 19:18:02.360
HD Request # 2 | Intraday data download complete for 10YX23_FUT_CME. Unique request ID: 2 | 2023-11-22 19:18:02.360
Removing historical data download ID 2. | 2023-11-22 19:18:02.360
Real-time Intraday chart data file updates started for 10YX23_FUT_CME | 2023-11-22 19:18:02.360
Intraday chart data file opened for 10YX23_FUT_CME | 2023-11-22 19:18:02.360
HD Request # 2 | Enabling Intraday chart updating for symbol. | 2023-11-22 19:18:02.360
Triggering next historical data download in queue. | 2023-11-22 19:18:02.360
Historical data for 10YX23_FUT_CME is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2023-11-22 19:18:02.360
HD Request # 3 | Downloading Intraday chart data for CLF24_FUT_CME to the file CLF24_FUT_CME.scid. Service: nymex | 2023-11-22 19:18:02.360
HD Request # 3 | Download start date-time: 2023-11-22 18:46:31.000000. File last date-time: 2023-11-22 18:46:31.574000 | 2023-11-22 19:18:02.361
HD Request # 3 | Using server: ds27.sierracharts.com port 10150 | 2023-11-22 19:18:02.361
Socket (1) | Creating socket. | 2023-11-22 19:18:02.366
Socket (1) | New receive buffer size: 0 | 2023-11-22 19:18:02.366
Socket (1) | Connecting to IP: 38.89.227.130. | 2023-11-22 19:18:02.366
Socket (3) | Socket gracefully closed by remote side. | 2023-11-22 19:18:02.526
Socket (3) | Closed. | 2023-11-22 19:18:02.526
HD Request # 3 | Setting DTC encoding to Binary VLS | 2023-11-22 19:18:02.668
HD Request # 3 | Sending historical data logon request message. | 2023-11-22 19:18:02.668
Numbers Bars | Service Package does not support this function or account is expired. Select 'Help >> Account Control Panel' for account management. | 2023-11-22 19:18:02.770 *
Numbers Bars | To restore the chart, remove this study. | 2023-11-22 19:18:02.770 *
Numbers Bars Calculated Values study: Service Package does not support this function or account is expired. Select 'Help >> Account Control Panel' for account management. | 2023-11-22 19:18:02.770 *
HD Request # 3 | Requesting Intraday data. Start date-time: 2023-11-22 18:46:31. Record interval: 0. Symbol: CLF24 | 2023-11-22 19:18:03.052
HD Request # 3 | Decompressing data. | 2023-11-22 19:18:03.206
HD Request # 3 | Receiving Intraday data for CLF24_FUT_CME starting at 2023-11-22 18:46:31.574000 | 2023-11-22 19:18:03.383
Socket (1) | CloseSocket call. | 2023-11-22 19:18:03.538
Socket (1) | Shutdown started. Waiting for graceful close. | 2023-11-22 19:18:03.538
Historical data download thread signaled to stop. | 2023-11-22 19:18:03.538
HD Request # 3 | Timestamp of first Intraday data file record written: 2023-11-22 18:46:34.599000. | 2023-11-22 19:18:03.538
HD Request # 3 | Received 5972 Intraday data records from 2023-11-22 18:46:31.574000 to 2023-11-22 19:08:02.403000 (21.5 minutes. Delay: 10.0 minutes) and wrote 5971 records for CLF24_FUT_CME | 2023-11-22 19:18:03.539
HD Request # 3 | Completion time: 1s. | 2023-11-22 19:18:03.540
HD Request # 3 | Intraday data download complete for CLF24_FUT_CME. Unique request ID: 3 | 2023-11-22 19:18:03.540
Removing historical data download ID 3. | 2023-11-22 19:18:03.540
Real-time Intraday chart data file updates started for CLF24_FUT_CME | 2023-11-22 19:18:03.540
Intraday chart data file opened for CLF24_FUT_CME | 2023-11-22 19:18:03.540
HD Request # 3 | Enabling Intraday chart updating for symbol. | 2023-11-22 19:18:03.540
No download requests in the queue to start downloads for. | 2023-11-22 19:18:03.540
Historical data for CLF24_FUT_CME is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2023-11-22 19:18:03.540
Socket (1) | Socket gracefully closed by remote side. | 2023-11-22 19:18:03.686
Socket (1) | Closed. | 2023-11-22 19:18:03.686
ESZ23_FUT_CME[M] 5 Min #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-11-22 19:18:05.418
ESZ23_FUT_CME[M] 1 Min #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-11-22 19:18:15.495
Numbers Bars | Service Package does not support this function or account is expired. Select 'Help >> Account Control Panel' for account management. | 2023-11-22 19:18:15.496 *
Numbers Bars | To restore the chart, remove this study. | 2023-11-22 19:18:15.496 *
Numbers Bars Calculated Values study: Service Package does not support this function or account is expired. Select 'Help >> Account Control Panel' for account management. | 2023-11-22 19:18:15.498 *
Numbers Bars | Service Package does not support this function or account is expired. Select 'Help >> Account Control Panel' for account management. | 2023-11-22 19:18:15.560 *
Numbers Bars | To restore the chart, remove this study. | 2023-11-22 19:18:15.560 *
Numbers Bars Calculated Values study: Service Package does not support this function or account is expired. Select 'Help >> Account Control Panel' for account management. | 2023-11-22 19:18:15.560 *
Numbers Bars | Service Package does not support this function or account is expired. Select 'Help >> Account Control Panel' for account management. | 2023-11-22 19:18:15.903 *
Numbers Bars | To restore the chart, remove this study. | 2023-11-22 19:18:15.903 *
Numbers Bars Calculated Values study: Service Package does not support this function or account is expired. Select 'Help >> Account Control Panel' for account management. | 2023-11-22 19:18:15.903 *
ESZ23_FUT_CME[M] #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-11-22 19:18:22.458
TPO Profile Chart | Service Package does not support this function or account is expired. Select 'Help >> Account Control Panel' for account management. | 2023-11-22 19:18:22.461 *
TPO Profile Chart | To restore the chart, remove this study. | 2023-11-22 19:18:22.461 *
TPO Profile Chart | Service Package does not support this function or account is expired. Select 'Help >> Account Control Panel' for account management. | 2023-11-22 19:18:22.483 *
TPO Profile Chart | To restore the chart, remove this study. | 2023-11-22 19:18:22.483 *
TPO Profile Chart | Service Package does not support this function or account is expired. Select 'Help >> Account Control Panel' for account management. | 2023-11-22 19:18:22.484 *
TPO Profile Chart | To restore the chart, remove this study. | 2023-11-22 19:18:22.484 *
Teton CME Order Routing | Firm: IronBeam | 2023-11-22 19:18:52.050
Teton CME Order Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11085 | 2023-11-22 19:18:52.050
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2023-11-22 19:18:52.051
DTC Client socket (1) | New receive buffer size: 0 | 2023-11-22 19:18:52.051
DTC Client socket (1) | Connecting to IP: 208.185.224.130. | 2023-11-22 19:18:52.051
Teton CME Order Routing | Network connection to server complete. | 2023-11-22 19:18:52.175
Teton CME Order Routing | Starting socket receive thread. | 2023-11-22 19:18:52.175
Teton CME Order Routing | Sending encoding request to server: Binary VLS. Compression: none | 2023-11-22 19:18:52.175
Teton CME Order Routing | Setting DTC encoding to Binary VLS | 2023-11-22 19:18:52.546
Teton CME Order Routing | Sending logon request message. | 2023-11-22 19:18:52.546
Teton CME Order Routing | Received logon response. | 2023-11-22 19:18:52.670
Teton CME Order Routing | Server Name: SC DTC Server. | 2023-11-22 19:18:52.670
Teton CME Order Routing | Server protocol version: 8. Client protocol version: 8 | 2023-11-22 19:18:52.670
Teton CME Order Routing | Connection error: No trade accounts assigned | 2023-11-22 19:18:52.670 *
Teton CME Order Routing | Failed connections: 2 | 2023-11-22 19:18:52.670
Teton CME Order Routing | Waiting for socket receive thread to end | 2023-11-22 19:18:52.711
DTC Client socket (1) | CloseSocket call. | 2023-11-22 19:18:52.712
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-11-22 19:18:52.712
Teton CME Order Routing | Disconnected. | 2023-11-22 19:18:52.713
DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-11-22 19:18:52.835
DTC Client socket (1) | Closed. | 2023-11-22 19:18:52.835
ESZ23_FUT_CME[M] #3 | StartDateTimeForLoadingOrderFills: 2023-11-08 19:07:58 | 2023-11-22 19:19:49.180
ESZ23_FUT_CME[M] 5 Min #4 | StartDateTimeForLoadingOrderFills: 2023-10-23 21:15:00 | 2023-11-22 19:19:49.194
ESZ23_FUT_CME[M] 1 Min #9 | StartDateTimeForLoadingOrderFills: 2023-10-23 21:00:00 | 2023-11-22 19:19:49.226
10YX23_FUT_CME[M] #7 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-11-22 19:19:49.243
ESZ23_FUT_CME[M] #1 | StartDateTimeForLoadingOrderFills: 2023-05-22 14:36:00 | 2023-11-22 19:19:49.251
ESZ23_FUT_CME[M] #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-11-22 19:20:06.823
ESZ23_FUT_CME[M] 5 Min #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-11-22 19:20:06.835
ESZ23_FUT_CME[M] 1 Min #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-11-22 19:20:06.840
10YX23_FUT_CME[M] #7 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-11-22 19:20:06.848
ESZ23_FUT_CME[M] #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-11-22 19:20:06.859
Checking for new symbol settings. Requested symbol settings MD5 for service code scdataallservices. Request ID: 3. | 2023-11-22 19:20:21.230
Current selected Data/Trading service: SC Data - All Services | 2023-11-22 19:20:21.230
Symbol settings MD5 received. Request ID: 3. | 2023-11-22 19:20:23.481
Requested symbol settings for service code scdataallservices. Request ID: 4. | 2023-11-22 19:20:23.481
Symbol settings received. Request ID: 4. | 2023-11-22 19:20:26.176
SC Data - All Services | Disconnected. | 2023-11-22 19:20:30.010
SC Data - All Services | Disconnected. | 2023-11-22 19:20:30.011
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-22 19:20:30.011
ESZ23-CME[M] #3 | Reloading chart. | 2023-11-22 19:20:30.480
CLF24-NYMEX[M] 10 Min #6 | Reloading chart. | 2023-11-22 19:20:30.503
ESZ23-CME[M] 5 Min #4 | Reloading chart. | 2023-11-22 19:20:30.527
10YX23-CBOT[M] 5 Min #8 | Reloading chart. | 2023-11-22 19:20:30.556
ESZ23-CME[M] 1 Min #9 | Reloading chart. | 2023-11-22 19:20:30.567
10YX23-CBOT[M] #7 | Reloading chart. | 2023-11-22 19:20:30.640
10YX23-CBOT[M] #7 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-11-22 19:20:30.641
ESZ23-CME[M] 5 Min #2 | Reloading chart. | 2023-11-22 19:20:30.644
ESZ23-CME[M] #1 | Reloading chart. | 2023-11-22 19:20:30.653
ESZ23-CME[M] 10 Min #5 | Reloading chart. | 2023-11-22 19:20:30.661
Mapping ESZ23-CME to ESZ23. Service code: cme | 2023-11-22 19:20:31.151
Added historical Intraday data request for ESZ23-CME to the queue. | 2023-11-22 19:20:31.151
Intraday data recording state for symbol ESZ23-CME is set to download 'Pending'. | 2023-11-22 19:20:31.151
Triggering next historical data download in queue. | 2023-11-22 19:20:31.151
HD Request # 4 | Downloading Intraday chart data for ESZ23-CME to the file ESZ23-CME.scid. Service: cme | 2023-11-22 19:20:31.151
HD Request # 4 | Download start date-time: 2023-11-22 18:45:55.000000. File last date-time: 2023-11-22 18:45:55.070001 | 2023-11-22 19:20:31.152
HD Request # 4 | Using server: ds23.sierracharts.com port 10149 | 2023-11-22 19:20:31.152
Socket (1) | Creating socket. | 2023-11-22 19:20:31.153
Socket (1) | New receive buffer size: 0 | 2023-11-22 19:20:31.153
Socket (1) | Connecting to IP: 142.215.17.190. | 2023-11-22 19:20:31.153
ESZ23-CME[M] #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-11-22 19:20:31.276
Mapping CLF24-NYMEX to CLF24. Service code: nymex | 2023-11-22 19:20:31.290
Added historical Intraday data request for CLF24-NYMEX to the queue. | 2023-11-22 19:20:31.290
Intraday data recording state for symbol CLF24-NYMEX is set to download 'Pending'. | 2023-11-22 19:20:31.290
Triggering next historical data download in queue. | 2023-11-22 19:20:31.290
Mapping 10YX23-CBOT to 10YX23. Service code: cbot | 2023-11-22 19:20:31.295
Added historical Intraday data request for 10YX23-CBOT to the queue. | 2023-11-22 19:20:31.296
Intraday data recording state for symbol 10YX23-CBOT is set to download 'Pending'. | 2023-11-22 19:20:31.296
Triggering next historical data download in queue. | 2023-11-22 19:20:31.296
HD Request # 4 | Setting DTC encoding to Binary VLS | 2023-11-22 19:20:31.501
HD Request # 4 | Sending historical data logon request message. | 2023-11-22 19:20:31.501
HD Request # 4 | Requesting Intraday data. Start date-time: 2023-11-22 18:45:55. Record interval: 0. Symbol: ESZ23 | 2023-11-22 19:20:31.894
SC Data - All Services | Connected to server complete. | 2023-11-22 19:20:32.009
No download requests in the queue to start downloads for. | 2023-11-22 19:20:32.011
Triggering next historical data download in queue. | 2023-11-22 19:20:32.011
Notice: Not connected to Live trading account to receive CME realtime futures data at non-professional fees. | 2023-11-22 19:20:32.012
Mapping ESZ23-CME to ESZ23. Service code: cme | 2023-11-22 19:20:32.025
Using symbol data fast lookup vector | 2023-11-22 19:20:32.025
Delayed Data Feed | Starting real-time market data updates for: ESZ23-CME (ESZ23). ID: 1 Service code: cme | 2023-11-22 19:20:32.026
Delayed Data Feed | Connecting to the server ds13.sierracharts.com. Port 10043 | 2023-11-22 19:20:32.038
DTC Client socket (2) | Creating socket. | 2023-11-22 19:20:32.038
DTC Client socket (2) | New receive buffer size: 0 | 2023-11-22 19:20:32.038
DTC Client socket (2) | Connecting to IP: 162.251.232.244. | 2023-11-22 19:20:32.038
Delayed Data Feed | Requesting security definition data for: ESZ23-CME (ESZ23). ID: 1 | 2023-11-22 19:20:32.039
Mapping CLF24-NYMEX to CLF24. Service code: nymex | 2023-11-22 19:20:32.039
Delayed Data Feed | Starting real-time market data updates for: CLF24-NYMEX (CLF24). ID: 2 Service code: nymex | 2023-11-22 19:20:32.040
Delayed Data Feed | Requesting security definition data for: CLF24-NYMEX (CLF24). ID: 2 | 2023-11-22 19:20:32.040
Mapping 10YX23-CBOT to 10YX23. Service code: cbot | 2023-11-22 19:20:32.072
Delayed Data Feed | Starting real-time market data updates for: 10YX23-CBOT (10YX23). ID: 3 Service code: cbot | 2023-11-22 19:20:32.073
Delayed Data Feed | Requesting security definition data for: 10YX23-CBOT (10YX23). ID: 3 | 2023-11-22 19:20:32.073
HD Request # 4 | Decompressing data. | 2023-11-22 19:20:32.078
Delayed Data Feed | Network connection to server complete. | 2023-11-22 19:20:32.267
Delayed Data Feed | Starting socket receive thread. | 2023-11-22 19:20:32.267
Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-11-22 19:20:32.267
HD Request # 4 | Receiving Intraday data for ESZ23-CME starting at 2023-11-22 18:45:55.060000 | 2023-11-22 19:20:32.418
Delayed Data Feed | Setting DTC encoding to Binary VLS | 2023-11-22 19:20:32.511
Delayed Data Feed | Sending logon request message. | 2023-11-22 19:20:32.511
Delayed Data Feed | Received logon response. | 2023-11-22 19:20:32.711
Delayed Data Feed | Server Name: RealTimeServer. | 2023-11-22 19:20:32.711
Delayed Data Feed | Server protocol version: 8. Client protocol version: 8 | 2023-11-22 19:20:32.711
Delayed Data Feed | Logon error received from server: Data service (sc_delayed_exchange.datafeed) is disabled or unsupported. A software update may be necessary. | 2023-11-22 19:20:32.711
Delayed Data Feed | Failed connections: 1 | 2023-11-22 19:20:32.711
Delayed Data Feed | Waiting for socket receive thread to end | 2023-11-22 19:20:32.711
DTC Client socket (2) | CloseSocket call. | 2023-11-22 19:20:32.711
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2023-11-22 19:20:32.711
Delayed Data Feed | Disconnected from the server. | 2023-11-22 19:20:32.711
Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-22 19:20:32.711
Socket (1) | CloseSocket call. | 2023-11-22 19:20:32.713
Socket (1) | Shutdown started. Waiting for graceful close. | 2023-11-22 19:20:32.713
Historical data download thread signaled to stop. | 2023-11-22 19:20:32.713
HD Request # 4 | Timestamp of first Intraday data file record written: 2023-11-22 18:45:56.549000. | 2023-11-22 19:20:32.714
HD Request # 4 | Received 16882 Intraday data records from 2023-11-22 18:45:55.060000 to 2023-11-22 19:10:31.984000 (24.6 minutes. Delay: 10.0 minutes) and wrote 16877 records for ESZ23-CME | 2023-11-22 19:20:32.714
HD Request # 4 | Add time&sales data | Remembered last file record date-time: 2023-11-22 19:10:31.984000 | 2023-11-22 19:20:32.736
HD Request # 4 | Completion time: 1s. | 2023-11-22 19:20:32.745
HD Request # 4 | Intraday data download complete for ESZ23-CME. Unique request ID: 4 | 2023-11-22 19:20:32.745
Removing historical data download ID 4. | 2023-11-22 19:20:32.745
Real-time Intraday chart data file updates started for ESZ23-CME | 2023-11-22 19:20:32.745
Intraday chart data file opened for ESZ23-CME | 2023-11-22 19:20:32.745
HD Request # 4 | Enabling Intraday chart updating for symbol. | 2023-11-22 19:20:32.745
Triggering next historical data download in queue. | 2023-11-22 19:20:32.749
Historical data for ESZ23-CME is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2023-11-22 19:20:32.749
Delaying start of download for CLF24-NYMEX. | 2023-11-22 19:20:32.750
Socket (1) | Socket gracefully closed by remote side. | 2023-11-22 19:20:32.845
Socket (1) | Closed. | 2023-11-22 19:20:32.845
DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-11-22 19:20:32.946
DTC Client socket (2) | Closed. | 2023-11-22 19:20:32.946
ESZ23-CME[M] 5 Min #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-11-22 19:20:43.889
Delayed Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2023-11-22 19:20:44.007
Requesting market depth updates for: 10YX23-CBOT if supported. NumLevels=100 | 2023-11-22 19:20:44.007
Separate subscription for market depth updates not supported. 10YX23-CBOT | 2023-11-22 19:20:44.007
Requesting market depth updates for: ESZ23-CME if supported. NumLevels=100 | 2023-11-22 19:20:44.007
Separate subscription for market depth updates not supported. ESZ23-CME | 2023-11-22 19:20:44.007
DTC Client socket (1) | Creating socket. | 2023-11-22 19:20:44.011
DTC Client socket (1) | New receive buffer size: 0 | 2023-11-22 19:20:44.011
DTC Client socket (1) | Connecting to IP: 142.215.17.189. | 2023-11-22 19:20:44.011
Delayed Data Feed | Network connection to server complete. | 2023-11-22 19:20:44.158
Delayed Data Feed | Starting socket receive thread. | 2023-11-22 19:20:44.159
Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-11-22 19:20:44.159
Delayed Data Feed | Setting DTC encoding to Binary VLS | 2023-11-22 19:20:44.384
Delayed Data Feed | Sending logon request message. | 2023-11-22 19:20:44.384
Delayed Data Feed | Received logon response. | 2023-11-22 19:20:44.844
Delayed Data Feed | Server Name: SC Realtime Server. | 2023-11-22 19:20:44.844
Delayed Data Feed | Server protocol version: 8. Client protocol version: 8 | 2023-11-22 19:20:44.844
Delayed Data Feed | Successfully connected. | 2023-11-22 19:20:44.844
Delayed Data Feed | Trading is not supported. | 2023-11-22 19:20:44.844
Delayed Data Feed | Restarting real-time data updates for symbol: 10YX23-CBOT -> 10YX23. Market Depth data restarted. | 2023-11-22 19:20:44.845
Delayed Data Feed | Restarting real-time data updates for symbol: CLF24-NYMEX -> CLF24 | 2023-11-22 19:20:44.845
Added historical Intraday data request for ESZ23-CME to the queue. | 2023-11-22 19:20:44.850
Intraday data recording state for symbol ESZ23-CME is set to download 'Pending'. | 2023-11-22 19:20:44.850
Triggering next historical data download in queue. | 2023-11-22 19:20:44.850
Delayed Data Feed | Restarting real-time data updates for symbol: ESZ23-CME -> ESZ23. Market Depth data restarted. | 2023-11-22 19:20:44.850
ESZ23-CME[M] 1 Min #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-11-22 19:20:44.952
Delayed Data Feed | Clearing market depth for 10YX23-CBOT | 2023-11-22 19:20:45.057
Delayed Data Feed | Received security definition for symbol 10YX23-CBOT | 2023-11-22 19:20:45.058
Delayed Data Feed | Clearing market depth for ESZ23-CME | 2023-11-22 19:20:45.058
Delayed Data Feed | Received security definition for symbol CLF24-NYMEX | 2023-11-22 19:20:45.058
Delayed Data Feed | Received security definition for symbol ESZ23-CME | 2023-11-22 19:20:45.058
ESZ23-CME[M] #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-11-22 19:20:50.256
HD Request # 5 | Downloading Intraday chart data for CLF24-NYMEX to the file CLF24-NYMEX.scid. Service: nymex | 2023-11-22 19:20:50.906
HD Request # 5 | Download start date-time: 2023-11-22 18:45:56.000000. File last date-time: 2023-11-22 18:45:56.432001 | 2023-11-22 19:20:50.906
HD Request # 5 | Using server: ds26.sierracharts.com port 10150 | 2023-11-22 19:20:50.906
Socket (2) | Creating socket. | 2023-11-22 19:20:50.906
Socket (2) | New receive buffer size: 0 | 2023-11-22 19:20:50.906
Socket (2) | Connecting to IP: 142.215.17.188. | 2023-11-22 19:20:50.906
HD Request # 5 | Setting DTC encoding to Binary VLS | 2023-11-22 19:20:51.180
HD Request # 5 | Sending historical data logon request message. | 2023-11-22 19:20:51.180
HD Request # 5 | Requesting Intraday data. Start date-time: 2023-11-22 18:45:56. Record interval: 0. Symbol: CLF24 | 2023-11-22 19:20:51.517
HD Request # 5 | Decompressing data. | 2023-11-22 19:20:51.650
HD Request # 5 | Receiving Intraday data for CLF24-NYMEX starting at 2023-11-22 18:45:56.051000 | 2023-11-22 19:20:51.799
Socket (2) | CloseSocket call. | 2023-11-22 19:20:51.944
Socket (2) | Shutdown started. Waiting for graceful close. | 2023-11-22 19:20:51.944
Historical data download thread signaled to stop. | 2023-11-22 19:20:51.944
HD Request # 5 | Timestamp of first Intraday data file record written: 2023-11-22 18:45:58.032000. | 2023-11-22 19:20:51.945
HD Request # 5 | Received 6756 Intraday data records from 2023-11-22 18:45:56.051000 to 2023-11-22 19:10:50.897000 (24.9 minutes. Delay: 10.0 minutes) and wrote 6747 records for CLF24-NYMEX | 2023-11-22 19:20:51.945
HD Request # 5 | Add time&sales data | Remembered last file record date-time: 2023-11-22 19:10:50.897000 | 2023-11-22 19:20:51.956
HD Request # 5 | Completion time: 1s. | 2023-11-22 19:20:51.956
HD Request # 5 | Intraday data download complete for CLF24-NYMEX. Unique request ID: 5 | 2023-11-22 19:20:51.956
Removing historical data download ID 5. | 2023-11-22 19:20:51.956
Real-time Intraday chart data file updates started for CLF24-NYMEX | 2023-11-22 19:20:51.956
Intraday chart data file opened for CLF24-NYMEX | 2023-11-22 19:20:51.956
HD Request # 5 | Enabling Intraday chart updating for symbol. | 2023-11-22 19:20:51.956
Triggering next historical data download in queue. | 2023-11-22 19:20:51.956
HD Request # 6 | Downloading Intraday chart data for 10YX23-CBOT to the file 10YX23-CBOT.scid. Service: cbot | 2023-11-22 19:20:51.956
HD Request # 6 | Download start date-time: 2023-11-22 18:42:26.000000. File last date-time: 2023-11-22 18:42:26.458000 | 2023-11-22 19:20:51.957
HD Request # 6 | Using server: ds28.sierracharts.com port 10149 | 2023-11-22 19:20:51.957
Socket (3) | Creating socket. | 2023-11-22 19:20:51.957
Socket (3) | New receive buffer size: 0 | 2023-11-22 19:20:51.957
Socket (3) | Connecting to IP: 142.215.18.147. | 2023-11-22 19:20:51.957
Socket (2) | Socket gracefully closed by remote side. | 2023-11-22 19:20:52.086
Socket (2) | Closed. | 2023-11-22 19:20:52.086
HD Request # 6 | Setting DTC encoding to Binary VLS | 2023-11-22 19:20:52.243
HD Request # 6 | Sending historical data logon request message. | 2023-11-22 19:20:52.243
HD Request # 6 | Requesting Intraday data. Start date-time: 2023-11-22 18:42:26. Record interval: 0. Symbol: 10YX23 | 2023-11-22 19:20:52.570
HD Request # 6 | Decompressing data. | 2023-11-22 19:20:52.708
HD Request # 6 | Receiving Intraday data for 10YX23-CBOT starting at 2023-11-22 18:42:26.458000 | 2023-11-22 19:20:52.841
Socket (3) | CloseSocket call. | 2023-11-22 19:20:52.841
Socket (3) | Shutdown started. Waiting for graceful close. | 2023-11-22 19:20:52.841
Historical data download thread signaled to stop. | 2023-11-22 19:20:52.841
HD Request # 6 | Timestamp of first Intraday data file record written: 2023-11-22 18:47:54.300000. | 2023-11-22 19:20:52.841
HD Request # 6 | Received 17 Intraday data records from 2023-11-22 18:42:26.458000 to 2023-11-22 19:10:19.951000 (27.9 minutes. Delay: 10.5 minutes) and wrote 16 records for 10YX23-CBOT | 2023-11-22 19:20:52.841
HD Request # 6 | Add time&sales data | Remembered last file record date-time: 2023-11-22 19:10:19.951000 | 2023-11-22 19:20:52.851
HD Request # 6 | Completion time: 1s. | 2023-11-22 19:20:52.852
HD Request # 6 | Intraday data download complete for 10YX23-CBOT. Unique request ID: 6 | 2023-11-22 19:20:52.852
Removing historical data download ID 6. | 2023-11-22 19:20:52.852
Real-time Intraday chart data file updates started for 10YX23-CBOT | 2023-11-22 19:20:52.852
Intraday chart data file opened for 10YX23-CBOT | 2023-11-22 19:20:52.852
HD Request # 6 | Enabling Intraday chart updating for symbol. | 2023-11-22 19:20:52.852
Triggering next historical data download in queue. | 2023-11-22 19:20:52.852
HD Request # 7 | Downloading Intraday chart data for ESZ23-CME to the file ESZ23-CME.scid. Service: cme | 2023-11-22 19:20:52.852
HD Request # 7 | Download start date-time: 2023-11-22 19:10:31.000000. File last date-time: 2023-11-22 19:10:31.984000 | 2023-11-22 19:20:52.853
HD Request # 7 | Using server: ds27.sierracharts.com port 10150 | 2023-11-22 19:20:52.853
Socket (2) | Creating socket. | 2023-11-22 19:20:52.853
Socket (2) | New receive buffer size: 0 | 2023-11-22 19:20:52.853
Socket (2) | Connecting to IP: 38.89.227.130. | 2023-11-22 19:20:52.853
Socket (3) | Socket gracefully closed by remote side. | 2023-11-22 19:20:52.972
Socket (3) | Closed. | 2023-11-22 19:20:52.972
HD Request # 7 | Setting DTC encoding to Binary VLS | 2023-11-22 19:20:53.125
HD Request # 7 | Sending historical data logon request message. | 2023-11-22 19:20:53.125
HD Request # 7 | Requesting Intraday data. Start date-time: 2023-11-22 19:10:31. Record interval: 0. Symbol: ESZ23 | 2023-11-22 19:20:53.507
HD Request # 7 | Decompressing data. | 2023-11-22 19:20:53.643
HD Request # 7 | Receiving Intraday data for ESZ23-CME starting at 2023-11-22 19:10:31.089000 | 2023-11-22 19:20:53.774
Socket (2) | CloseSocket call. | 2023-11-22 19:20:53.775
Socket (2) | Shutdown started. Waiting for graceful close. | 2023-11-22 19:20:53.775
Historical data download thread signaled to stop. | 2023-11-22 19:20:53.779
HD Request # 7 | Timestamp of first Intraday data file record written: 2023-11-22 19:10:32.288000. | 2023-11-22 19:20:53.779
HD Request # 7 | Received 399 Intraday data records from 2023-11-22 19:10:31.089000 to 2023-11-22 19:10:52.681002 (21.6 seconds. Delay: 10.0 minutes) and wrote 394 records for ESZ23-CME | 2023-11-22 19:20:53.779
HD Request # 7 | Add time&sales data | Remembered last file record date-time: 2023-11-22 19:10:52.681002 | 2023-11-22 19:20:53.791
HD Request # 7 | Completion time: 1s. | 2023-11-22 19:20:53.791
HD Request # 7 | Intraday data download complete for ESZ23-CME. Unique request ID: 7 | 2023-11-22 19:20:53.791
Removing historical data download ID 7. | 2023-11-22 19:20:53.791
Real-time Intraday chart data file updates started for ESZ23-CME | 2023-11-22 19:20:53.791
Intraday chart data file opened for ESZ23-CME | 2023-11-22 19:20:53.792
HD Request # 7 | Enabling Intraday chart updating for symbol. | 2023-11-22 19:20:53.792
No download requests in the queue to start downloads for. | 2023-11-22 19:20:53.792
Socket (2) | Socket gracefully closed by remote side. | 2023-11-22 19:20:53.911
Socket (2) | Closed. | 2023-11-22 19:20:53.911
Opened cached Intraday file: C:\SierraChart\Data\ESZ23-CME.scid. Thread ID: 26768 | 2023-11-22 19:20:53.998
Opened cached Intraday file: C:\SierraChart\Data\CLF24-NYMEX.scid. Thread ID: 26768 | 2023-11-22 19:20:55.435
DTC Client socket (1) | Close event error. Windows error code 10053: Uma ligação estabelecida foi anulada pelo software no computador anfitrião. | 2023-11-22 19:29:53.545 *
DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-11-22 19:29:53.545
DTC Client socket (1) | CloseSocket call. | 2023-11-22 19:29:53.683
DTC Client socket (1) | Max send buffers used during socket life: 3 | 2023-11-22 19:29:53.683
DTC Client socket (1) | Max send buffer size during socket life: 290 | 2023-11-22 19:29:53.683
DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-22 19:29:53.684
DTC Client socket (1) | Closed. | 2023-11-22 19:29:53.684
Delayed Data Feed | Waiting for socket receive thread to end | 2023-11-22 19:29:53.684
DTC Client socket (0) | CloseSocket call. | 2023-11-22 19:29:53.685
Delayed Data Feed | Disconnected from the server. | 2023-11-22 19:29:53.685
Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-22 19:29:53.685
Delayed Data Feed | Connecting to the server ds31-2.sierracharts.com. Port 10043 | 2023-11-22 19:29:55.685
DTC Client socket (1) | Creating socket. | 2023-11-22 19:29:55.765
DTC Client socket (1) | New receive buffer size: 0 | 2023-11-22 19:29:55.765
DTC Client socket (1) | Connecting to IP: 38.88.205.70. | 2023-11-22 19:29:55.765
Delayed Data Feed | Network connection to server complete. | 2023-11-22 19:29:55.875
Delayed Data Feed | Starting socket receive thread. | 2023-11-22 19:29:55.875
Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-11-22 19:29:55.875
Delayed Data Feed | Setting DTC encoding to Binary VLS | 2023-11-22 19:29:56.002
Delayed Data Feed | Sending logon request message. | 2023-11-22 19:29:56.002
Delayed Data Feed | Received logon response. | 2023-11-22 19:29:56.440
Delayed Data Feed | Server Name: SC Realtime Server. | 2023-11-22 19:29:56.440
Delayed Data Feed | Server protocol version: 8. Client protocol version: 8 | 2023-11-22 19:29:56.440
Delayed Data Feed | Successfully connected. | 2023-11-22 19:29:56.440
Delayed Data Feed | Trading is not supported. | 2023-11-22 19:29:56.440
Added historical Intraday data request for 10YX23-CBOT to the queue. | 2023-11-22 19:29:56.440
Intraday data recording state for symbol 10YX23-CBOT is set to download 'Pending'. | 2023-11-22 19:29:56.440
Triggering next historical data download in queue. | 2023-11-22 19:29:56.440
Delayed Data Feed | Restarting real-time data updates for symbol: 10YX23-CBOT -> 10YX23. Market Depth data restarted. | 2023-11-22 19:29:56.440
Added historical Intraday data request for CLF24-NYMEX to the queue. | 2023-11-22 19:29:56.440
Intraday data recording state for symbol CLF24-NYMEX is set to download 'Pending'. | 2023-11-22 19:29:56.440
Delayed Data Feed | Restarting real-time data updates for symbol: CLF24-NYMEX -> CLF24 | 2023-11-22 19:29:56.440
Added historical Intraday data request for ESZ23-CME to the queue. | 2023-11-22 19:29:56.440
Intraday data recording state for symbol ESZ23-CME is set to download 'Pending'. | 2023-11-22 19:29:56.440
Delayed Data Feed | Restarting real-time data updates for symbol: ESZ23-CME -> ESZ23. Market Depth data restarted. | 2023-11-22 19:29:56.440
HD Request # 8 | Downloading Intraday chart data for 10YX23-CBOT to the file 10YX23-CBOT.scid. Service: cbot | 2023-11-22 19:29:56.440
HD Request # 8 | Download start date-time: 2023-11-22 19:10:19.000000. File last date-time: 2023-11-22 19:10:19.951000 | 2023-11-22 19:29:56.440
HD Request # 8 | Using server: ds23.sierracharts.com port 10149 | 2023-11-22 19:29:56.440
Socket (2) | Creating socket. | 2023-11-22 19:29:56.440
Socket (2) | New receive buffer size: 0 | 2023-11-22 19:29:56.441
Socket (2) | Connecting to IP: 142.215.17.190. | 2023-11-22 19:29:56.441
HD Request # 8 | Setting DTC encoding to Binary VLS | 2023-11-22 19:29:56.703
HD Request # 8 | Sending historical data logon request message. | 2023-11-22 19:29:56.703
Delayed Data Feed | Clearing market depth for 10YX23-CBOT | 2023-11-22 19:29:56.767
Delayed Data Feed | Clearing market depth for ESZ23-CME | 2023-11-22 19:29:56.767
Delayed Data Feed | Received security definition for symbol 10YX23-CBOT | 2023-11-22 19:29:56.767
Delayed Data Feed | Received security definition for symbol CLF24-NYMEX | 2023-11-22 19:29:56.767
Delayed Data Feed | Received security definition for symbol ESZ23-CME | 2023-11-22 19:29:56.767
HD Request # 8 | Requesting Intraday data. Start date-time: 2023-11-22 19:10:19. Record interval: 0. Symbol: 10YX23 | 2023-11-22 19:29:57.047
HD Request # 8 | Decompressing data. | 2023-11-22 19:29:57.175
HD Request # 8 | Receiving Intraday data for 10YX23-CBOT starting at 2023-11-22 19:10:19.951000 | 2023-11-22 19:29:57.301
Socket (2) | CloseSocket call. | 2023-11-22 19:29:57.301
Socket (2) | Shutdown started. Waiting for graceful close. | 2023-11-22 19:29:57.301
Historical data download thread signaled to stop. | 2023-11-22 19:29:57.301
HD Request # 8 | Timestamp of first Intraday data file record written: 2023-11-22 19:13:47.504000. | 2023-11-22 19:29:57.301
HD Request # 8 | Received 11 Intraday data records from 2023-11-22 19:10:19.951000 to 2023-11-22 19:17:39.925001 (7.3 minutes. Delay: 12.3 minutes) and wrote 10 records for 10YX23-CBOT | 2023-11-22 19:29:57.302
HD Request # 8 | Add time&sales data | Remembered last file record date-time: 2023-11-22 19:17:39.925001 | 2023-11-22 19:29:57.309
HD Request # 8 | Completion time: 1s. | 2023-11-22 19:29:57.309
HD Request # 8 | Intraday data download complete for 10YX23-CBOT. Unique request ID: 8 | 2023-11-22 19:29:57.309
Removing historical data download ID 8. | 2023-11-22 19:29:57.309
Real-time Intraday chart data file updates started for 10YX23-CBOT | 2023-11-22 19:29:57.309
Intraday chart data file opened for 10YX23-CBOT | 2023-11-22 19:29:57.309
HD Request # 8 | Enabling Intraday chart updating for symbol. | 2023-11-22 19:29:57.309
Triggering next historical data download in queue. | 2023-11-22 19:29:57.309
HD Request # 9 | Downloading Intraday chart data for CLF24-NYMEX to the file CLF24-NYMEX.scid. Service: nymex | 2023-11-22 19:29:57.310
HD Request # 9 | Download start date-time: 2023-11-22 19:11:10.000000. File last date-time: 2023-11-22 19:11:10.101000 | 2023-11-22 19:29:57.310
HD Request # 9 | Using server: ds26.sierracharts.com port 10150 | 2023-11-22 19:29:57.310
Socket (3) | Creating socket. | 2023-11-22 19:29:57.310
Socket (3) | New receive buffer size: 0 | 2023-11-22 19:29:57.310
Socket (3) | Connecting to IP: 142.215.17.188. | 2023-11-22 19:29:57.310
Socket (2) | Socket gracefully closed by remote side. | 2023-11-22 19:29:57.431
Socket (2) | Closed. | 2023-11-22 19:29:57.431
HD Request # 9 | Setting DTC encoding to Binary VLS | 2023-11-22 19:29:57.585
HD Request # 9 | Sending historical data logon request message. | 2023-11-22 19:29:57.585
HD Request # 9 | Requesting Intraday data. Start date-time: 2023-11-22 19:11:10. Record interval: 0. Symbol: CLF24 | 2023-11-22 19:29:57.918
HD Request # 9 | Decompressing data. | 2023-11-22 19:29:58.184
HD Request # 9 | Receiving Intraday data for CLF24-NYMEX starting at 2023-11-22 19:11:10.100000 | 2023-11-22 19:29:58.446
Socket (3) | CloseSocket call. | 2023-11-22 19:29:58.449
Socket (3) | Shutdown started. Waiting for graceful close. | 2023-11-22 19:29:58.449
Historical data download thread signaled to stop. | 2023-11-22 19:29:58.449
HD Request # 9 | Timestamp of first Intraday data file record written: 2023-11-22 19:11:13.364000. | 2023-11-22 19:29:58.450
HD Request # 9 | Received 3289 Intraday data records from 2023-11-22 19:11:10.100000 to 2023-11-22 19:19:55.690000 (8.8 minutes. Delay: 10.0 minutes) and wrote 3283 records for CLF24-NYMEX | 2023-11-22 19:29:58.450
HD Request # 9 | Add time&sales data | Remembered last file record date-time: 2023-11-22 19:19:55.690000 | 2023-11-22 19:29:58.461
HD Request # 9 | Completion time: 1s. | 2023-11-22 19:29:58.461
HD Request # 9 | Intraday data download complete for CLF24-NYMEX. Unique request ID: 9 | 2023-11-22 19:29:58.461
Removing historical data download ID 9. | 2023-11-22 19:29:58.461
Real-time Intraday chart data file updates started for CLF24-NYMEX | 2023-11-22 19:29:58.461
Intraday chart data file opened for CLF24-NYMEX | 2023-11-22 19:29:58.461
HD Request # 9 | Enabling Intraday chart updating for symbol. | 2023-11-22 19:29:58.461
Triggering next historical data download in queue. | 2023-11-22 19:29:58.461
HD Request # 10 | Downloading Intraday chart data for ESZ23-CME to the file ESZ23-CME.scid. Service: cme | 2023-11-22 19:29:58.461
HD Request # 10 | Download start date-time: 2023-11-22 19:11:09.000000. File last date-time: 2023-11-22 19:11:09.111000 | 2023-11-22 19:29:58.461
HD Request # 10 | Using server: ds28.sierracharts.com port 10149 | 2023-11-22 19:29:58.461
Socket (2) | Creating socket. | 2023-11-22 19:29:58.461
Socket (2) | New receive buffer size: 0 | 2023-11-22 19:29:58.462
Socket (2) | Connecting to IP: 142.215.18.147. | 2023-11-22 19:29:58.462
Socket (3) | Socket gracefully closed by remote side. | 2023-11-22 19:29:58.580
Socket (3) | Closed. | 2023-11-22 19:29:58.580
HD Request # 10 | Setting DTC encoding to Binary VLS | 2023-11-22 19:29:58.738
HD Request # 10 | Sending historical data logon request message. | 2023-11-22 19:29:58.738
HD Request # 10 | Requesting Intraday data. Start date-time: 2023-11-22 19:11:09. Record interval: 0. Symbol: ESZ23 | 2023-11-22 19:29:59.073
HD Request # 10 | Decompressing data. | 2023-11-22 19:29:59.208
Opened cached Intraday file: C:\SierraChart\Data\CLF24-NYMEX.scid. Thread ID: 30196 | 2023-11-22 19:30:00.277
HD Request # 10 | Receiving Intraday data for ESZ23-CME starting at 2023-11-22 19:11:09.111000 | 2023-11-22 19:30:00.358
Socket (2) | CloseSocket call. | 2023-11-22 19:30:01.165
Socket (2) | Shutdown started. Waiting for graceful close. | 2023-11-22 19:30:01.166
Historical data download thread signaled to stop. | 2023-11-22 19:30:01.237
HD Request # 10 | Timestamp of first Intraday data file record written: 2023-11-22 19:11:14.327000. | 2023-11-22 19:30:01.238
HD Request # 10 | Received 9429 Intraday data records from 2023-11-22 19:11:09.111000 to 2023-11-22 19:19:58.791001 (8.8 minutes. Delay: 10.0 minutes) and wrote 9428 records for ESZ23-CME | 2023-11-22 19:30:01.238
HD Request # 10 | Add time&sales data | Remembered last file record date-time: 2023-11-22 19:19:58.791001 | 2023-11-22 19:30:01.244
HD Request # 10 | Completion time: 3s. | 2023-11-22 19:30:01.244
HD Request # 10 | Intraday data download complete for ESZ23-CME. Unique request ID: 10 | 2023-11-22 19:30:01.244
Removing historical data download ID 10. | 2023-11-22 19:30:01.244
Real-time Intraday chart data file updates started for ESZ23-CME | 2023-11-22 19:30:01.244
Intraday chart data file opened for ESZ23-CME | 2023-11-22 19:30:01.244
HD Request # 10 | Enabling Intraday chart updating for symbol. | 2023-11-22 19:30:01.244
No download requests in the queue to start downloads for. | 2023-11-22 19:30:01.245
Socket (2) | Socket gracefully closed by remote side. | 2023-11-22 19:30:01.304
Socket (2) | Closed. | 2023-11-22 19:30:01.305
Opened cached Intraday file: C:\SierraChart\Data\ESZ23-CME.scid. Thread ID: 30196 | 2023-11-22 19:30:01.570
Numbers Bars | Service Package does not support this function or account is expired. Select 'Help >> Account Control Panel' for account management. | 2023-11-22 19:30:55.145 *
Numbers Bars | To restore the chart, remove this study. | 2023-11-22 19:30:55.145 *
Numbers Bars | Service Package does not support this function or account is expired. Select 'Help >> Account Control Panel' for account management. | 2023-11-22 19:30:56.000 *
Numbers Bars | To restore the chart, remove this study. | 2023-11-22 19:30:56.000 *
Numbers Bars | Service Package does not support this function or account is expired. Select 'Help >> Account Control Panel' for account management. | 2023-11-22 19:30:56.517 *
Numbers Bars | To restore the chart, remove this study. | 2023-11-22 19:30:56.517 *
Numbers Bars | Service Package does not support this function or account is expired. Select 'Help >> Account Control Panel' for account management. | 2023-11-22 19:31:08.016 *
Numbers Bars | To restore the chart, remove this study. | 2023-11-22 19:31:08.016 *
Numbers Bars Calculated Values study: Service Package does not support this function or account is expired. Select 'Help >> Account Control Panel' for account management. | 2023-11-22 19:31:08.018 *
Numbers Bars | Service Package does not support this function or account is expired. Select 'Help >> Account Control Panel' for account management. | 2023-11-22 19:31:08.039 *
Numbers Bars | To restore the chart, remove this study. | 2023-11-22 19:31:08.039 *
Numbers Bars Calculated Values study: Service Package does not support this function or account is expired. Select 'Help >> Account Control Panel' for account management. | 2023-11-22 19:31:08.039 *
Numbers Bars | Service Package does not support this function or account is expired. Select 'Help >> Account Control Panel' for account management. | 2023-11-22 19:31:08.533 *
Numbers Bars | To restore the chart, remove this study. | 2023-11-22 19:31:08.533 *
Numbers Bars Calculated Values study: Service Package does not support this function or account is expired. Select 'Help >> Account Control Panel' for account management. | 2023-11-22 19:31:08.534 *
ESZ24-CME Daily #10 | Reloading chart. | 2023-11-22 19:33:13.666
Enabling compression for file: C:\SierraChart\Data\ESZ24-CME.dly | 2023-11-22 19:33:13.668
ESZ24-CME Daily #10 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESZ24-CME.dly | 2023-11-22 19:33:13.672
Starting DelayedDownloadMonitoringTimer | 2023-11-22 19:33:14.159
Starting HDTimeoutTimer | 2023-11-22 19:33:14.159
Added historical Daily data request for ESZ24-CME to the queue. | 2023-11-22 19:33:14.161
Triggering next historical data download in queue. | 2023-11-22 19:33:14.165
Mapping ESZ24-CME to ESZ24. Service code: cme | 2023-11-22 19:33:14.165
Delayed Data Feed | Starting real-time market data updates for: ESZ24-CME (ESZ24). ID: 4 Service code: cme | 2023-11-22 19:33:14.165
Delayed Data Feed | Requesting security definition data for: ESZ24-CME (ESZ24). ID: 4 | 2023-11-22 19:33:14.165
HD Request # 11 | Downloading Historical Daily chart data for ESZ24-CME. Starting date: 1973-12-04. Service: scdataallservices | 2023-11-22 19:33:14.172
Delayed Data Feed | Received security definition for symbol ESZ24-CME | 2023-11-22 19:33:14.416
HD Request # 11 | Requesting historical Daily data for ESZ24 starting at 1973-12-03. SC External HD service. | 2023-11-22 19:33:14.937
HD Request # 11 | Receiving historical Daily data for ESZ24-CME starting at 2021-06-04. | 2023-11-22 19:33:15.450
HD Request # 11 | Writing historical Daily data to the file ESZ24-CME.dly. | 2023-11-22 19:33:15.451
HD Request # 11 | Bytes received: 28608 | 2023-11-22 19:33:15.459
HD Request # 11 | Received 623 Daily data records from 2021-06-04 00:00:00 to 2023-11-21 00:00:00 (2.5 years) and wrote 623 records for ESZ24-CME | 2023-11-22 19:33:15.459
HD Request # 11 | Completion time: 1s. | 2023-11-22 19:33:15.459
HD Request # 11 | Daily data download complete for ESZ24-CME. Unique request ID: 11 | 2023-11-22 19:33:15.459
Removing historical data download ID 11. | 2023-11-22 19:33:15.459
No download requests in the queue to start downloads for. | 2023-11-22 19:33:15.459
ESZ24-CME[M] Daily #10 | Reloading chart. | 2023-11-22 19:33:15.689
Enabling compression for file: C:\SierraChart\Data\ESZ24-CME.scid | 2023-11-22 19:33:18.543
ESZ24-CME 5 Min #11 | Reloading chart. | 2023-11-22 19:33:18.544
ESZ24-CME 5 Min #11 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESZ24-CME.scid | 2023-11-22 19:33:18.550
Added historical Intraday data request for ESZ24-CME to the queue. | 2023-11-22 19:33:19.045
Intraday data recording state for symbol ESZ24-CME is set to download 'Pending'. | 2023-11-22 19:33:19.045
Triggering next historical data download in queue. | 2023-11-22 19:33:19.045
HD Request # 12 | Downloading Intraday chart data for ESZ24-CME to the file ESZ24-CME.scid. Service: cme | 2023-11-22 19:33:19.053
HD Request # 12 | Download start date-time: 2023-05-20 20:33:19.000000. File last date-time: 00:00:00.000000 | 2023-11-22 19:33:19.053
HD Request # 12 | Using server: ds27.sierracharts.com port 10150 | 2023-11-22 19:33:19.054
Socket (2) | Creating socket. | 2023-11-22 19:33:19.187
Socket (2) | New receive buffer size: 0 | 2023-11-22 19:33:19.187
Socket (2) | Connecting to IP: 38.89.227.130. | 2023-11-22 19:33:19.187
HD Request # 12 | Setting DTC encoding to Binary VLS | 2023-11-22 19:33:19.460
HD Request # 12 | Sending historical data logon request message. | 2023-11-22 19:33:19.460
HD Request # 12 | Requesting Intraday data. Start date-time: 2023-05-20 20:33:19. Record interval: 0. Symbol: ESZ24 | 2023-11-22 19:33:19.840
HD Request # 12 | Decompressing data. | 2023-11-22 19:33:19.971
HD Request # 12 | Receiving Intraday data for ESZ24-CME starting at 2023-09-27 13:14:01.405000 | 2023-11-22 19:33:20.101
Socket (2) | CloseSocket call. | 2023-11-22 19:33:20.101
Socket (2) | Shutdown started. Waiting for graceful close. | 2023-11-22 19:33:20.101
Historical data download thread signaled to stop. | 2023-11-22 19:33:20.140
HD Request # 12 | Timestamp of first Intraday data file record written: 2023-09-27 13:14:01.405000. | 2023-11-22 19:33:20.141
HD Request # 12 | Received 18 Intraday data records from 2023-09-27 13:14:01.405000 to 2023-11-20 20:01:35.835000 (54.3 days. Delay: 47.5 hours) and wrote 18 records for ESZ24-CME | 2023-11-22 19:33:20.141
HD Request # 12 | Add time&sales data | Remembered last file record date-time: 2023-11-20 20:01:35.835000 | 2023-11-22 19:33:20.148
HD Request # 12 | Completion time: 1s. | 2023-11-22 19:33:20.149
HD Request # 12 | Intraday data download complete for ESZ24-CME. Unique request ID: 12 | 2023-11-22 19:33:20.149
Removing historical data download ID 12. | 2023-11-22 19:33:20.149
Real-time Intraday chart data file updates started for ESZ24-CME | 2023-11-22 19:33:20.149
Intraday chart data file opened for ESZ24-CME | 2023-11-22 19:33:20.149
HD Request # 12 | Enabling Intraday chart updating for symbol. | 2023-11-22 19:33:20.149
No download requests in the queue to start downloads for. | 2023-11-22 19:33:20.149
Socket (2) | Socket gracefully closed by remote side. | 2023-11-22 19:33:20.233
Socket (2) | Closed. | 2023-11-22 19:33:20.234
Numbers Bars | Service Package does not support this function or account is expired. Select 'Help >> Account Control Panel' for account management. | 2023-11-22 19:33:34.485 *
Numbers Bars | To restore the chart, remove this study. | 2023-11-22 19:33:34.485 *
Numbers Bars Calculated Values study: Service Package does not support this function or account is expired. Select 'Help >> Account Control Panel' for account management. | 2023-11-22 19:33:34.485 *
ESZ24-CME[M] Daily #10 | Reloading chart. | 2023-11-22 19:33:34.730
Numbers Bars | Service Package does not support this function or account is expired. Select 'Help >> Account Control Panel' for account management. | 2023-11-22 19:33:34.739 *
Numbers Bars | To restore the chart, remove this study. | 2023-11-22 19:33:34.739 *
Numbers Bars Calculated Values study: Service Package does not support this function or account is expired. Select 'Help >> Account Control Panel' for account management. | 2023-11-22 19:33:34.739 *
Numbers Bars | Service Package does not support this function or account is expired. Select 'Help >> Account Control Panel' for account management. | 2023-11-22 19:33:35.234 *
Numbers Bars | To restore the chart, remove this study. | 2023-11-22 19:33:35.234 *
Numbers Bars Calculated Values study: Service Package does not support this function or account is expired. Select 'Help >> Account Control Panel' for account management. | 2023-11-22 19:33:35.234 *
ESZ24-CME[M] 1 Min #10 | Reloading chart. | 2023-11-22 19:33:54.962
File >> Reconnect selected. | 2023-11-22 19:35:24.693
Delayed Data Feed | Waiting for socket receive thread to end | 2023-11-22 19:35:24.694
DTC Client socket (1) | CloseSocket call. | 2023-11-22 19:35:24.694
DTC Client socket (1) | Max send buffers used during socket life: 3 | 2023-11-22 19:35:24.694
DTC Client socket (1) | Max send buffer size during socket life: 290 | 2023-11-22 19:35:24.694
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-11-22 19:35:24.694
Delayed Data Feed | Disconnected from the server. | 2023-11-22 19:35:24.694
SC Data - All Services | Disconnected. | 2023-11-22 19:35:24.694
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-22 19:35:24.694
DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-11-22 19:35:24.955
DTC Client socket (1) | Closed. | 2023-11-22 19:35:24.956
SC Data - All Services | Connected to server complete. | 2023-11-22 19:35:26.698
No download requests in the queue to start downloads for. | 2023-11-22 19:35:26.699
Notice: Not connected to Live trading account to receive CME realtime futures data at non-professional fees. | 2023-11-22 19:35:26.699
Mapping ESZ24-CME to ESZ24. Service code: cme | 2023-11-22 19:35:26.981
Using symbol data fast lookup vector | 2023-11-22 19:35:26.981
Delayed Data Feed | Starting real-time market data updates for: ESZ24-CME (ESZ24). ID: 1 Service code: cme | 2023-11-22 19:35:26.981
Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-11-22 19:35:26.981
Delayed Data Feed | Requesting security definition data for: ESZ24-CME (ESZ24). ID: 1 | 2023-11-22 19:35:26.981
Added historical Intraday data request for ESZ24-CME to the queue. | 2023-11-22 19:35:26.981
Intraday data recording state for symbol ESZ24-CME is set to download 'Pending'. | 2023-11-22 19:35:26.981
Triggering next historical data download in queue. | 2023-11-22 19:35:26.981
Delaying start of download for ESZ24-CME. | 2023-11-22 19:35:26.983
DTC Client socket (2) | Creating socket. | 2023-11-22 19:35:27.065
DTC Client socket (2) | New receive buffer size: 0 | 2023-11-22 19:35:27.065
DTC Client socket (2) | Connecting to IP: 142.215.18.148. | 2023-11-22 19:35:27.065
Mapping ESZ23-CME to ESZ23. Service code: cme | 2023-11-22 19:35:27.162
Delayed Data Feed | Starting real-time market data updates for: ESZ23-CME (ESZ23). ID: 2 Service code: cme | 2023-11-22 19:35:27.163
Delayed Data Feed | Requesting security definition data for: ESZ23-CME (ESZ23). ID: 2 | 2023-11-22 19:35:27.163
Added historical Intraday data request for ESZ23-CME to the queue. | 2023-11-22 19:35:27.163
Intraday data recording state for symbol ESZ23-CME is set to download 'Pending'. | 2023-11-22 19:35:27.163
Triggering next historical data download in queue. | 2023-11-22 19:35:27.163
Delayed Data Feed | Network connection to server complete. | 2023-11-22 19:35:27.237
Delayed Data Feed | Starting socket receive thread. | 2023-11-22 19:35:27.237
Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-11-22 19:35:27.237
Mapping CLF24-NYMEX to CLF24. Service code: nymex | 2023-11-22 19:35:27.241
Delayed Data Feed | Starting real-time market data updates for: CLF24-NYMEX (CLF24). ID: 3 Service code: nymex | 2023-11-22 19:35:27.241
Delayed Data Feed | Requesting security definition data for: CLF24-NYMEX (CLF24). ID: 3 | 2023-11-22 19:35:27.241
Added historical Intraday data request for CLF24-NYMEX to the queue. | 2023-11-22 19:35:27.241
Intraday data recording state for symbol CLF24-NYMEX is set to download 'Pending'. | 2023-11-22 19:35:27.241
Triggering next historical data download in queue. | 2023-11-22 19:35:27.241
Mapping 10YX23-CBOT to 10YX23. Service code: cbot | 2023-11-22 19:35:27.248
Delayed Data Feed | Starting real-time market data updates for: 10YX23-CBOT (10YX23). ID: 4 Service code: cbot | 2023-11-22 19:35:27.248
Delayed Data Feed | Requesting security definition data for: 10YX23-CBOT (10YX23). ID: 4 | 2023-11-22 19:35:27.248
Added historical Intraday data request for 10YX23-CBOT to the queue. | 2023-11-22 19:35:27.248
Intraday data recording state for symbol 10YX23-CBOT is set to download 'Pending'. | 2023-11-22 19:35:27.248
Triggering next historical data download in queue. | 2023-11-22 19:35:27.248
Delayed Data Feed | Setting DTC encoding to Binary VLS | 2023-11-22 19:35:27.396
Delayed Data Feed | Sending logon request message. | 2023-11-22 19:35:27.396
Delayed Data Feed | Received logon response. | 2023-11-22 19:35:27.834
Delayed Data Feed | Server Name: SC Realtime Server. | 2023-11-22 19:35:27.834
Delayed Data Feed | Server protocol version: 8. Client protocol version: 8 | 2023-11-22 19:35:27.834
Delayed Data Feed | Successfully connected. | 2023-11-22 19:35:27.834
Delayed Data Feed | Trading is not supported. | 2023-11-22 19:35:27.834
Delayed Data Feed | Restarting real-time data updates for symbol: 10YX23-CBOT -> 10YX23 | 2023-11-22 19:35:27.834
Delayed Data Feed | Restarting real-time data updates for symbol: CLF24-NYMEX -> CLF24 | 2023-11-22 19:35:27.834
Delayed Data Feed | Restarting real-time data updates for symbol: ESZ23-CME -> ESZ23 | 2023-11-22 19:35:27.834
Delayed Data Feed | Restarting real-time data updates for symbol: ESZ24-CME -> ESZ24 | 2023-11-22 19:35:27.834
Delayed Data Feed | Received security definition for symbol 10YX23-CBOT | 2023-11-22 19:35:28.053
Delayed Data Feed | Received security definition for symbol CLF24-NYMEX | 2023-11-22 19:35:28.053
Delayed Data Feed | Received security definition for symbol ESZ23-CME | 2023-11-22 19:35:28.053
Delayed Data Feed | Received security definition for symbol ESZ24-CME | 2023-11-22 19:35:28.053
Requesting market depth updates for: 10YX23-CBOT if supported. NumLevels=100 | 2023-11-22 19:35:31.727
Requesting market depth updates for: ESZ23-CME if supported. NumLevels=100 | 2023-11-22 19:35:31.727
Delayed Data Feed | Clearing market depth for 10YX23-CBOT | 2023-11-22 19:35:31.865
Delayed Data Feed | Clearing market depth for ESZ23-CME | 2023-11-22 19:35:31.865
HD Request # 13 | Downloading Intraday chart data for ESZ24-CME to the file ESZ24-CME.scid. Service: cme | 2023-11-22 19:35:33.774
HD Request # 13 | Download start date-time: 2023-11-20 20:01:35.000000. File last date-time: 2023-11-20 20:01:35.835000 | 2023-11-22 19:35:33.775
HD Request # 13 | Using server: ds23.sierracharts.com port 10149 | 2023-11-22 19:35:33.775
Socket (1) | Creating socket. | 2023-11-22 19:35:33.777
Socket (1) | New receive buffer size: 0 | 2023-11-22 19:35:33.777
Socket (1) | Connecting to IP: 142.215.17.190. | 2023-11-22 19:35:33.777
HD Request # 13 | Setting DTC encoding to Binary VLS | 2023-11-22 19:35:34.044
HD Request # 13 | Sending historical data logon request message. | 2023-11-22 19:35:34.044
HD Request # 13 | Requesting Intraday data. Start date-time: 2023-11-20 20:01:35. Record interval: 0. Symbol: ESZ24 | 2023-11-22 19:35:34.376
HD Request # 13 | Decompressing data. | 2023-11-22 19:35:34.510
HD Request # 13 | Receiving Intraday data for ESZ24-CME starting at 2023-11-20 20:01:35.835000 | 2023-11-22 19:35:34.640
Socket (1) | CloseSocket call. | 2023-11-22 19:35:34.640
Socket (1) | Shutdown started. Waiting for graceful close. | 2023-11-22 19:35:34.640
Historical data download thread signaled to stop. | 2023-11-22 19:35:34.641
HD Request # 13 | Received 1 Intraday data record from 2023-11-20 20:01:35.835000 to 2023-11-20 20:01:35.835000 (0.0 seconds. Delay: 47.6 hours) and wrote 0 records for ESZ24-CME | 2023-11-22 19:35:34.641
HD Request # 13 | Add time&sales data | Remembered last file record date-time: 2023-11-20 20:01:35.835000 | 2023-11-22 19:35:34.641
HD Request # 13 | Completion time: 1s. | 2023-11-22 19:35:34.642
HD Request # 13 | Intraday data download complete for ESZ24-CME. Unique request ID: 13 | 2023-11-22 19:35:34.642
Removing historical data download ID 13. | 2023-11-22 19:35:34.642
Real-time Intraday chart data file updates started for ESZ24-CME | 2023-11-22 19:35:34.642
Intraday chart data file opened for ESZ24-CME | 2023-11-22 19:35:34.642
HD Request # 13 | Enabling Intraday chart updating for symbol. | 2023-11-22 19:35:34.642
Triggering next historical data download in queue. | 2023-11-22 19:35:34.642
HD Request # 14 | Downloading Intraday chart data for ESZ23-CME to the file ESZ23-CME.scid. Service: cme | 2023-11-22 19:35:34.642
HD Request # 14 | Download start date-time: 2023-11-22 19:25:14.000000. File last date-time: 2023-11-22 19:25:14.655000 | 2023-11-22 19:35:34.642
HD Request # 14 | Using server: ds26.sierracharts.com port 10150 | 2023-11-22 19:35:34.642
Socket (3) | Creating socket. | 2023-11-22 19:35:34.643
Socket (3) | New receive buffer size: 0 | 2023-11-22 19:35:34.643
Socket (3) | Connecting to IP: 142.215.17.188. | 2023-11-22 19:35:34.643
Socket (1) | Socket gracefully closed by remote side. | 2023-11-22 19:35:34.782
Socket (1) | Closed. | 2023-11-22 19:35:34.782
HD Request # 14 | Setting DTC encoding to Binary VLS | 2023-11-22 19:35:34.930
HD Request # 14 | Sending historical data logon request message. | 2023-11-22 19:35:34.930
HD Request # 14 | Requesting Intraday data. Start date-time: 2023-11-22 19:25:14. Record interval: 0. Symbol: ESZ23 | 2023-11-22 19:35:35.269
HD Request # 14 | Decompressing data. | 2023-11-22 19:35:35.400
HD Request # 14 | Receiving Intraday data for ESZ23-CME starting at 2023-11-22 19:25:14.018000 | 2023-11-22 19:35:35.534
Socket (3) | CloseSocket call. | 2023-11-22 19:35:35.535
Socket (3) | Shutdown started. Waiting for graceful close. | 2023-11-22 19:35:35.535
Historical data download thread signaled to stop. | 2023-11-22 19:35:35.536
HD Request # 14 | Timestamp of first Intraday data file record written: 2023-11-22 19:25:15.027000. | 2023-11-22 19:35:35.536
HD Request # 14 | Received 429 Intraday data records from 2023-11-22 19:25:14.018000 to 2023-11-22 19:25:34.478000 (20.5 seconds. Delay: 10.0 minutes) and wrote 344 records for ESZ23-CME | 2023-11-22 19:35:35.536
HD Request # 14 | Add time&sales data | Remembered last file record date-time: 2023-11-22 19:25:34.478000 | 2023-11-22 19:35:35.545
HD Request # 14 | Completion time: 1s. | 2023-11-22 19:35:35.545
HD Request # 14 | Intraday data download complete for ESZ23-CME. Unique request ID: 14 | 2023-11-22 19:35:35.545
Removing historical data download ID 14. | 2023-11-22 19:35:35.545
Real-time Intraday chart data file updates started for ESZ23-CME | 2023-11-22 19:35:35.545
Intraday chart data file opened for ESZ23-CME | 2023-11-22 19:35:35.545
HD Request # 14 | Enabling Intraday chart updating for symbol. | 2023-11-22 19:35:35.545
Triggering next historical data download in queue. | 2023-11-22 19:35:35.545
HD Request # 15 | Downloading Intraday chart data for CLF24-NYMEX to the file CLF24-NYMEX.scid. Service: nymex | 2023-11-22 19:35:35.545
HD Request # 15 | Download start date-time: 2023-11-22 19:25:14.000000. File last date-time: 2023-11-22 19:25:14.605000 | 2023-11-22 19:35:35.545
HD Request # 15 | Using server: ds28.sierracharts.com port 10149 | 2023-11-22 19:35:35.545
Socket (1) | Creating socket. | 2023-11-22 19:35:35.546
Socket (1) | New receive buffer size: 0 | 2023-11-22 19:35:35.546
Socket (1) | Connecting to IP: 142.215.18.147. | 2023-11-22 19:35:35.546
Socket (3) | Socket gracefully closed by remote side. | 2023-11-22 19:35:35.668
Socket (3) | Closed. | 2023-11-22 19:35:35.669
HD Request # 15 | Setting DTC encoding to Binary VLS | 2023-11-22 19:35:35.820
HD Request # 15 | Sending historical data logon request message. | 2023-11-22 19:35:35.820
HD Request # 15 | Requesting Intraday data. Start date-time: 2023-11-22 19:25:14. Record interval: 0. Symbol: CLF24 | 2023-11-22 19:35:36.160
HD Request # 15 | Decompressing data. | 2023-11-22 19:35:36.295
HD Request # 15 | Receiving Intraday data for CLF24-NYMEX starting at 2023-11-22 19:25:14.603000 | 2023-11-22 19:35:36.430
Socket (1) | CloseSocket call. | 2023-11-22 19:35:36.431
Socket (1) | Shutdown started. Waiting for graceful close. | 2023-11-22 19:35:36.431
Historical data download thread signaled to stop. | 2023-11-22 19:35:36.431
HD Request # 15 | Timestamp of first Intraday data file record written: 2023-11-22 19:25:15.201000. | 2023-11-22 19:35:36.431
HD Request # 15 | Received 250 Intraday data records from 2023-11-22 19:25:14.603000 to 2023-11-22 19:25:35.912001 (21.3 seconds. Delay: 10.0 minutes) and wrote 237 records for CLF24-NYMEX | 2023-11-22 19:35:36.431
HD Request # 15 | Add time&sales data | Remembered last file record date-time: 2023-11-22 19:25:35.912001 | 2023-11-22 19:35:36.442
HD Request # 15 | Completion time: 1s. | 2023-11-22 19:35:36.442
HD Request # 15 | Intraday data download complete for CLF24-NYMEX. Unique request ID: 15 | 2023-11-22 19:35:36.442
Removing historical data download ID 15. | 2023-11-22 19:35:36.442
Real-time Intraday chart data file updates started for CLF24-NYMEX | 2023-11-22 19:35:36.442
Intraday chart data file opened for CLF24-NYMEX | 2023-11-22 19:35:36.442
HD Request # 15 | Enabling Intraday chart updating for symbol. | 2023-11-22 19:35:36.442
Triggering next historical data download in queue. | 2023-11-22 19:35:36.442
HD Request # 16 | Downloading Intraday chart data for 10YX23-CBOT to the file 10YX23-CBOT.scid. Service: cbot | 2023-11-22 19:35:36.442
HD Request # 16 | Download start date-time: 2023-11-22 19:17:39.000000. File last date-time: 2023-11-22 19:17:39.925001 | 2023-11-22 19:35:36.443
HD Request # 16 | Using server: ds27.sierracharts.com port 10150 | 2023-11-22 19:35:36.443
Socket (3) | Creating socket. | 2023-11-22 19:35:36.443
Socket (3) | New receive buffer size: 0 | 2023-11-22 19:35:36.443
Socket (3) | Connecting to IP: 38.89.227.130. | 2023-11-22 19:35:36.443
Socket (1) | Socket gracefully closed by remote side. | 2023-11-22 19:35:36.566
Socket (1) | Closed. | 2023-11-22 19:35:36.566
HD Request # 16 | Setting DTC encoding to Binary VLS | 2023-11-22 19:35:36.717
HD Request # 16 | Sending historical data logon request message. | 2023-11-22 19:35:36.717
HD Request # 16 | Requesting Intraday data. Start date-time: 2023-11-22 19:17:39. Record interval: 0. Symbol: 10YX23 | 2023-11-22 19:35:37.101
HD Request # 16 | Decompressing data. | 2023-11-22 19:35:37.233
Opened cached Intraday file: C:\SierraChart\Data\CLF24-NYMEX.scid. Thread ID: 12576 | 2023-11-22 19:35:37.261
HD Request # 16 | Receiving Intraday data for 10YX23-CBOT starting at 2023-11-22 19:17:39.925000 | 2023-11-22 19:35:37.362
Socket (3) | CloseSocket call. | 2023-11-22 19:35:37.363
Socket (3) | Shutdown started. Waiting for graceful close. | 2023-11-22 19:35:37.363
Historical data download thread signaled to stop. | 2023-11-22 19:35:37.363
HD Request # 16 | Received 2 Intraday data records from 2023-11-22 19:17:39.925000 to 2023-11-22 19:17:39.925001 (0.0 seconds. Delay: 18.0 minutes) and wrote 0 records for 10YX23-CBOT | 2023-11-22 19:35:37.363
HD Request # 16 | Add time&sales data | Remembered last file record date-time: 2023-11-22 19:17:39.925001 | 2023-11-22 19:35:37.363
HD Request # 16 | Completion time: 1s. | 2023-11-22 19:35:37.363
HD Request # 16 | Intraday data download complete for 10YX23-CBOT. Unique request ID: 16 | 2023-11-22 19:35:37.363
Removing historical data download ID 16. | 2023-11-22 19:35:37.364
Real-time Intraday chart data file updates started for 10YX23-CBOT | 2023-11-22 19:35:37.364
Intraday chart data file opened for 10YX23-CBOT | 2023-11-22 19:35:37.364
HD Request # 16 | Enabling Intraday chart updating for symbol. | 2023-11-22 19:35:37.364
No download requests in the queue to start downloads for. | 2023-11-22 19:35:37.364
Socket (3) | Socket gracefully closed by remote side. | 2023-11-22 19:35:37.493
Socket (3) | Closed. | 2023-11-22 19:35:37.493
Opened cached Intraday file: C:\SierraChart\Data\ESZ23-CME.scid. Thread ID: 12576 | 2023-11-22 19:35:38.208
Opened cached Intraday file: C:\SierraChart\Data\10YX23-CBOT.scid. Thread ID: 12576 | 2023-11-22 19:37:35.389
DTC Client socket (2) | Socket receive error. Windows error code 10054: Uma ligação existente foi forçada a fechar pelo anfitrião remoto. | 2023-11-22 19:47:20.902
DTC Client socket (2) | Socket receive error. Windows error code 10054: Uma ligação existente foi forçada a fechar pelo anfitrião remoto. | 2023-11-22 19:47:21.056
DTC Client socket (2) | Socket receive error. Windows error code 10054: Uma ligação existente foi forçada a fechar pelo anfitrião remoto. | 2023-11-22 19:47:21.076
DTC Client socket (2) | Socket receive error. Windows error code 10054: Uma ligação existente foi forçada a fechar pelo anfitrião remoto. | 2023-11-22 19:47:21.119
DTC Client socket (2) | Socket receive error. Windows error code 10054: Uma ligação existente foi forçada a fechar pelo anfitrião remoto. | 2023-11-22 19:47:21.128
DTC Client socket (2) | Socket receive error. Windows error code 10054: Uma ligação existente foi forçada a fechar pelo anfitrião remoto. | 2023-11-22 19:47:21.131
DTC Client socket (2) | Socket receive error. Windows error code 10054: Uma ligação existente foi forçada a fechar pelo anfitrião remoto. | 2023-11-22 19:47:21.135
DTC Client socket (2) | Socket receive error. Windows error code 10054: Uma ligação existente foi forçada a fechar pelo anfitrião remoto. | 2023-11-22 19:47:21.164
DTC Client socket (2) | Socket receive error. Windows error code 10054: Uma ligação existente foi forçada a fechar pelo anfitrião remoto. | 2023-11-22 19:47:21.176
DTC Client socket (2) | Socket receive error. Windows error code 10054: Uma ligação existente foi forçada a fechar pelo anfitrião remoto. | 2023-11-22 19:47:21.193
DTC Client socket (2) | Socket receive error. Windows error code 10054: Uma ligação existente foi forçada a fechar pelo anfitrião remoto. | 2023-11-22 19:47:21.194
DTC Client socket (2) | Socket receive error. Windows error code 10054: Uma ligação existente foi forçada a fechar pelo anfitrião remoto. | 2023-11-22 19:47:21.195
DTC Client socket (2) | Socket receive error. Windows error code 10054: Uma ligação existente foi forçada a fechar pelo anfitrião remoto. | 2023-11-22 19:47:21.316
DTC Client socket (2) | Socket receive error. Windows error code 10054: Uma ligação existente foi forçada a fechar pelo anfitrião remoto. | 2023-11-22 19:47:21.374
DTC Client socket (2) | Socket receive error. Windows error code 10054: Uma ligação existente foi forçada a fechar pelo anfitrião remoto. | 2023-11-22 19:47:21.417
DTC Client socket (2) | Close event error. Windows error code 10053: Uma ligação estabelecida foi anulada pelo software no computador anfitrião. | 2023-11-22 19:47:21.424 *
DTC Client socket (2) | CloseSocket call. | 2023-11-22 19:47:21.547
Delayed Data Feed | Unexpected condition: Socket not connected in c_DTCServiceClient::OnBufferedSocketReceivedData | 2023-11-22 19:47:21.547
Delayed Data Feed | Waiting for socket receive thread to end | 2023-11-22 19:47:21.547
DTC Client socket (0) | CloseSocket call. | 2023-11-22 19:47:21.547
Delayed Data Feed | Disconnected from the server. | 2023-11-22 19:47:21.547
Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-22 19:47:21.548
DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-22 19:47:21.553
DTC Client socket (2) | Closed. | 2023-11-22 19:47:21.554
Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-11-22 19:47:23.532
DTC Client socket (1) | Creating socket. | 2023-11-22 19:47:23.532
DTC Client socket (1) | New receive buffer size: 0 | 2023-11-22 19:47:23.532
DTC Client socket (1) | Connecting to IP: 142.215.18.148. | 2023-11-22 19:47:23.532
Delayed Data Feed | Network connection to server complete. | 2023-11-22 19:47:23.664
Delayed Data Feed | Starting socket receive thread. | 2023-11-22 19:47:23.664
Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-11-22 19:47:23.664
Delayed Data Feed | Setting DTC encoding to Binary VLS | 2023-11-22 19:47:23.837
Delayed Data Feed | Sending logon request message. | 2023-11-22 19:47:23.837
Delayed Data Feed | Received logon response. | 2023-11-22 19:47:24.243
Delayed Data Feed | Server Name: SC Realtime Server. | 2023-11-22 19:47:24.243
Delayed Data Feed | Server protocol version: 8. Client protocol version: 8 | 2023-11-22 19:47:24.243
Delayed Data Feed | Successfully connected. | 2023-11-22 19:47:24.243
Delayed Data Feed | Trading is not supported. | 2023-11-22 19:47:24.243
Added historical Intraday data request for 10YX23-CBOT to the queue. | 2023-11-22 19:47:24.243
Intraday data recording state for symbol 10YX23-CBOT is set to download 'Pending'. | 2023-11-22 19:47:24.243
Triggering next historical data download in queue. | 2023-11-22 19:47:24.243
Delayed Data Feed | Restarting real-time data updates for symbol: 10YX23-CBOT -> 10YX23. Market Depth data restarted. | 2023-11-22 19:47:24.243
Added historical Intraday data request for CLF24-NYMEX to the queue. | 2023-11-22 19:47:24.243
Intraday data recording state for symbol CLF24-NYMEX is set to download 'Pending'. | 2023-11-22 19:47:24.243
Delayed Data Feed | Restarting real-time data updates for symbol: CLF24-NYMEX -> CLF24 | 2023-11-22 19:47:24.243
Added historical Intraday data request for ESZ23-CME to the queue. | 2023-11-22 19:47:24.243
Intraday data recording state for symbol ESZ23-CME is set to download 'Pending'. | 2023-11-22 19:47:24.243
Delayed Data Feed | Restarting real-time data updates for symbol: ESZ23-CME -> ESZ23. Market Depth data restarted. | 2023-11-22 19:47:24.243
Added historical Intraday data request for ESZ24-CME to the queue. | 2023-11-22 19:47:24.243
Intraday data recording state for symbol ESZ24-CME is set to download 'Pending'. | 2023-11-22 19:47:24.243
Delayed Data Feed | Restarting real-time data updates for symbol: ESZ24-CME -> ESZ24 | 2023-11-22 19:47:24.243
HD Request # 17 | Downloading Intraday chart data for 10YX23-CBOT to the file 10YX23-CBOT.scid. Service: cbot | 2023-11-22 19:47:24.243
HD Request # 17 | Download start date-time: 2023-11-22 19:27:25.000000. File last date-time: 2023-11-22 19:27:25.403000 | 2023-11-22 19:47:24.244
HD Request # 17 | Using server: ds23.sierracharts.com port 10149 | 2023-11-22 19:47:24.244
Socket (2) | Creating socket. | 2023-11-22 19:47:24.244
Socket (2) | New receive buffer size: 0 | 2023-11-22 19:47:24.244
Socket (2) | Connecting to IP: 142.215.17.190. | 2023-11-22 19:47:24.244
HD Request # 17 | Setting DTC encoding to Binary VLS | 2023-11-22 19:47:24.529
HD Request # 17 | Sending historical data logon request message. | 2023-11-22 19:47:24.529
Delayed Data Feed | Clearing market depth for 10YX23-CBOT | 2023-11-22 19:47:24.623
Delayed Data Feed | Clearing market depth for ESZ23-CME | 2023-11-22 19:47:24.623
Delayed Data Feed | Received security definition for symbol 10YX23-CBOT | 2023-11-22 19:47:24.623
Delayed Data Feed | Received security definition for symbol CLF24-NYMEX | 2023-11-22 19:47:24.623
Delayed Data Feed | Received security definition for symbol ESZ23-CME | 2023-11-22 19:47:24.623
Delayed Data Feed | Received security definition for symbol ESZ24-CME | 2023-11-22 19:47:24.623
HD Request # 17 | Requesting Intraday data. Start date-time: 2023-11-22 19:27:25. Record interval: 0. Symbol: 10YX23 | 2023-11-22 19:47:24.866
HD Request # 17 | Decompressing data. | 2023-11-22 19:47:24.997
HD Request # 17 | Receiving Intraday data for 10YX23-CBOT starting at 2023-11-22 19:27:25.403000 | 2023-11-22 19:47:25.129
Socket (2) | CloseSocket call. | 2023-11-22 19:47:25.130
Socket (2) | Shutdown started. Waiting for graceful close. | 2023-11-22 19:47:25.130
Historical data download thread signaled to stop. | 2023-11-22 19:47:25.160
HD Request # 17 | Timestamp of first Intraday data file record written: 2023-11-22 19:32:58.462000. | 2023-11-22 19:47:25.160
HD Request # 17 | Received 8 Intraday data records from 2023-11-22 19:27:25.403000 to 2023-11-22 19:36:32.028000 (9.1 minutes. Delay: 10.9 minutes) and wrote 7 records for 10YX23-CBOT | 2023-11-22 19:47:25.160
HD Request # 17 | Add time&sales data | Remembered last file record date-time: 2023-11-22 19:36:32.028000 | 2023-11-22 19:47:25.168
HD Request # 17 | Completion time: 1s. | 2023-11-22 19:47:25.168
HD Request # 17 | Intraday data download complete for 10YX23-CBOT. Unique request ID: 17 | 2023-11-22 19:47:25.168
Removing historical data download ID 17. | 2023-11-22 19:47:25.168
Real-time Intraday chart data file updates started for 10YX23-CBOT | 2023-11-22 19:47:25.168
Intraday chart data file opened for 10YX23-CBOT | 2023-11-22 19:47:25.168
HD Request # 17 | Enabling Intraday chart updating for symbol. | 2023-11-22 19:47:25.168
Triggering next historical data download in queue. | 2023-11-22 19:47:25.168
HD Request # 18 | Downloading Intraday chart data for CLF24-NYMEX to the file CLF24-NYMEX.scid. Service: nymex | 2023-11-22 19:47:25.168
HD Request # 18 | Download start date-time: 2023-11-22 19:31:03.000000. File last date-time: 2023-11-22 19:31:03.825002 | 2023-11-22 19:47:25.168
HD Request # 18 | Using server: ds26.sierracharts.com port 10150 | 2023-11-22 19:47:25.168
Socket (3) | Creating socket. | 2023-11-22 19:47:25.168
Socket (3) | New receive buffer size: 0 | 2023-11-22 19:47:25.168
Socket (3) | Connecting to IP: 142.215.17.188. | 2023-11-22 19:47:25.168
Socket (2) | Socket gracefully closed by remote side. | 2023-11-22 19:47:25.259
Socket (2) | Closed. | 2023-11-22 19:47:25.260
HD Request # 18 | Setting DTC encoding to Binary VLS | 2023-11-22 19:47:25.443
HD Request # 18 | Sending historical data logon request message. | 2023-11-22 19:47:25.443
HD Request # 18 | Requesting Intraday data. Start date-time: 2023-11-22 19:31:03. Record interval: 0. Symbol: CLF24 | 2023-11-22 19:47:25.780
HD Request # 18 | Decompressing data. | 2023-11-22 19:47:25.909
HD Request # 18 | Receiving Intraday data for CLF24-NYMEX starting at 2023-11-22 19:31:03.180000 | 2023-11-22 19:47:26.065
Socket (3) | CloseSocket call. | 2023-11-22 19:47:26.068
Historical data download thread signaled to stop. | 2023-11-22 19:47:26.068
Socket (3) | Shutdown started. Waiting for graceful close. | 2023-11-22 19:47:26.068
HD Request # 18 | Timestamp of first Intraday data file record written: 2023-11-22 19:31:05.099000. | 2023-11-22 19:47:26.069
HD Request # 18 | Received 1399 Intraday data records from 2023-11-22 19:31:03.180000 to 2023-11-22 19:37:23.876000 (6.3 minutes. Delay: 10.0 minutes) and wrote 1394 records for CLF24-NYMEX | 2023-11-22 19:47:26.069
HD Request # 18 | Add time&sales data | Remembered last file record date-time: 2023-11-22 19:37:23.876000 | 2023-11-22 19:47:26.084
HD Request # 18 | Completion time: 1s. | 2023-11-22 19:47:26.084
HD Request # 18 | Intraday data download complete for CLF24-NYMEX. Unique request ID: 18 | 2023-11-22 19:47:26.084
Removing historical data download ID 18. | 2023-11-22 19:47:26.084
Real-time Intraday chart data file updates started for CLF24-NYMEX | 2023-11-22 19:47:26.084
Intraday chart data file opened for CLF24-NYMEX | 2023-11-22 19:47:26.084
HD Request # 18 | Enabling Intraday chart updating for symbol. | 2023-11-22 19:47:26.084
Triggering next historical data download in queue. | 2023-11-22 19:47:26.084
HD Request # 19 | Downloading Intraday chart data for ESZ23-CME to the file ESZ23-CME.scid. Service: cme | 2023-11-22 19:47:26.085
HD Request # 19 | Download start date-time: 2023-11-22 19:31:04.000000. File last date-time: 2023-11-22 19:31:04.436000 | 2023-11-22 19:47:26.085
HD Request # 19 | Using server: ds28.sierracharts.com port 10149 | 2023-11-22 19:47:26.085
Socket (2) | Creating socket. | 2023-11-22 19:47:26.086
Socket (2) | New receive buffer size: 0 | 2023-11-22 19:47:26.086
Socket (2) | Connecting to IP: 142.215.18.147. | 2023-11-22 19:47:26.086
Socket (3) | Socket gracefully closed by remote side. | 2023-11-22 19:47:26.233
Socket (3) | Closed. | 2023-11-22 19:47:26.233
HD Request # 19 | Setting DTC encoding to Binary VLS | 2023-11-22 19:47:26.376
HD Request # 19 | Sending historical data logon request message. | 2023-11-22 19:47:26.376
Opened cached Intraday file: C:\SierraChart\Data\CLF24-NYMEX.scid. Thread ID: 23832 | 2023-11-22 19:47:26.676
HD Request # 19 | Requesting Intraday data. Start date-time: 2023-11-22 19:31:04. Record interval: 0. Symbol: ESZ23 | 2023-11-22 19:47:26.728
HD Request # 19 | Decompressing data. | 2023-11-22 19:47:26.875
HD Request # 19 | Receiving Intraday data for ESZ23-CME starting at 2023-11-22 19:31:04.436000 | 2023-11-22 19:47:27.290
Socket (2) | CloseSocket call. | 2023-11-22 19:47:27.557
Historical data download thread signaled to stop. | 2023-11-22 19:47:27.557
Socket (2) | Shutdown started. Waiting for graceful close. | 2023-11-22 19:47:27.557
HD Request # 19 | Timestamp of first Intraday data file record written: 2023-11-22 19:31:04.549000. | 2023-11-22 19:47:27.557
HD Request # 19 | Received 9773 Intraday data records from 2023-11-22 19:31:04.436000 to 2023-11-22 19:37:26.952001 (6.4 minutes. Delay: 10.0 minutes) and wrote 9772 records for ESZ23-CME | 2023-11-22 19:47:27.558
HD Request # 19 | Add time&sales data | Remembered last file record date-time: 2023-11-22 19:37:26.952001 | 2023-11-22 19:47:27.573
HD Request # 19 | Completion time: 1s. | 2023-11-22 19:47:27.573
HD Request # 19 | Intraday data download complete for ESZ23-CME. Unique request ID: 19 | 2023-11-22 19:47:27.573
Removing historical data download ID 19. | 2023-11-22 19:47:27.573
Real-time Intraday chart data file updates started for ESZ23-CME | 2023-11-22 19:47:27.573
Intraday chart data file opened for ESZ23-CME | 2023-11-22 19:47:27.573
HD Request # 19 | Enabling Intraday chart updating for symbol. | 2023-11-22 19:47:27.573
Triggering next historical data download in queue. | 2023-11-22 19:47:27.573
HD Request # 20 | Downloading Intraday chart data for ESZ24-CME to the file ESZ24-CME.scid. Service: cme | 2023-11-22 19:47:27.574
HD Request # 20 | Download start date-time: 2023-11-20 20:01:35.000000. File last date-time: 2023-11-20 20:01:35.835000 | 2023-11-22 19:47:27.574
HD Request # 20 | Using server: ds27.sierracharts.com port 10150 | 2023-11-22 19:47:27.575
Socket (3) | Creating socket. | 2023-11-22 19:47:27.575
Socket (3) | New receive buffer size: 0 | 2023-11-22 19:47:27.575
Socket (3) | Connecting to IP: 38.89.227.130. | 2023-11-22 19:47:27.575
Socket (2) | Socket gracefully closed by remote side. | 2023-11-22 19:47:27.711
Socket (2) | Closed. | 2023-11-22 19:47:27.712
HD Request # 20 | Setting DTC encoding to Binary VLS | 2023-11-22 19:47:27.806
HD Request # 20 | Sending historical data logon request message. | 2023-11-22 19:47:27.806
Opened cached Intraday file: C:\SierraChart\Data\ESZ23-CME.scid. Thread ID: 23832 | 2023-11-22 19:47:27.837
HD Request # 20 | Requesting Intraday data. Start date-time: 2023-11-20 20:01:35. Record interval: 0. Symbol: ESZ24 | 2023-11-22 19:47:28.171
HD Request # 20 | Decompressing data. | 2023-11-22 19:47:28.283
HD Request # 20 | Receiving Intraday data for ESZ24-CME starting at 2023-11-20 20:01:35.835000 | 2023-11-22 19:47:28.422
Socket (3) | CloseSocket call. | 2023-11-22 19:47:28.422
Socket (3) | Shutdown started. Waiting for graceful close. | 2023-11-22 19:47:28.422
Historical data download thread signaled to stop. | 2023-11-22 19:47:28.474
HD Request # 20 | Received 1 Intraday data record from 2023-11-20 20:01:35.835000 to 2023-11-20 20:01:35.835000 (0.0 seconds. Delay: 47.8 hours) and wrote 0 records for ESZ24-CME | 2023-11-22 19:47:28.474
HD Request # 20 | Add time&sales data | Remembered last file record date-time: 2023-11-20 20:01:35.835000 | 2023-11-22 19:47:28.475
HD Request # 20 | Completion time: 1s. | 2023-11-22 19:47:28.475
HD Request # 20 | Intraday data download complete for ESZ24-CME. Unique request ID: 20 | 2023-11-22 19:47:28.475
Removing historical data download ID 20. | 2023-11-22 19:47:28.475
Real-time Intraday chart data file updates started for ESZ24-CME | 2023-11-22 19:47:28.475
Intraday chart data file opened for ESZ24-CME | 2023-11-22 19:47:28.475
HD Request # 20 | Enabling Intraday chart updating for symbol. | 2023-11-22 19:47:28.475
No download requests in the queue to start downloads for. | 2023-11-22 19:47:28.475
Socket (3) | Socket gracefully closed by remote side. | 2023-11-22 19:47:28.534
Socket (3) | Closed. | 2023-11-22 19:47:28.534
Opened cached Intraday file: C:\SierraChart\Data\10YX23-CBOT.scid. Thread ID: 23832 | 2023-11-22 19:48:06.055
Delayed Data Feed | Waiting for socket receive thread to end | 2023-11-22 19:55:57.869
DTC Client socket (1) | CloseSocket call. | 2023-11-22 19:55:57.870
DTC Client socket (1) | Max send buffers used during socket life: 4 | 2023-11-22 19:55:57.870
DTC Client socket (1) | Max send buffer size during socket life: 358 | 2023-11-22 19:55:57.870
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-11-22 19:55:57.870
Delayed Data Feed | Disconnected from the server. | 2023-11-22 19:55:57.870
SC Data - All Services | Disconnected. | 2023-11-22 19:55:57.870
Checking for new symbol settings. Requested symbol settings MD5 for service code sc_futures_direct.dtc.trading. Request ID: 5. | 2023-11-22 19:55:57.960
Current selected Data/Trading service: Teton CME Order Routing | 2023-11-22 19:55:57.960
DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-11-22 19:55:58.311
DTC Client socket (1) | Closed. | 2023-11-22 19:55:58.311
Symbol settings MD5 received. Request ID: 5. | 2023-11-22 19:56:00.085
Requested symbol settings for service code sc_futures_direct.dtc.trading. Request ID: 6. | 2023-11-22 19:56:00.085
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-22 19:56:00.521
Enabling compression for file: C:\SierraChart\Data\ESZ24_FUT_CME.scid | 2023-11-22 19:56:00.671
ESZ24_FUT_CME[M] 1 Min #10 | Reloading chart. | 2023-11-22 19:56:00.674
ESZ24_FUT_CME[M] 1 Min #10 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESZ24_FUT_CME.scid | 2023-11-22 19:56:00.678
ESZ23_FUT_CME[M] #3 | Reloading chart. | 2023-11-22 19:56:00.687
ESZ23_FUT_CME[M] 5 Min #4 | Reloading chart. | 2023-11-22 19:56:00.810
CLF24_FUT_CME[M] 10 Min #6 | Reloading chart. | 2023-11-22 19:56:00.860
ESZ23_FUT_CME[M] 1 Min #9 | Reloading chart. | 2023-11-22 19:56:00.925
10YX23_FUT_CME[M] 5 Min #8 | Reloading chart. | 2023-11-22 19:56:00.939
ESZ23_FUT_CME[M] 5 Min #2 | Reloading chart. | 2023-11-22 19:56:01.059
10YX23_FUT_CME[M] #7 | Reloading chart. | 2023-11-22 19:56:01.108
10YX23_FUT_CME[M] #7 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-11-22 19:56:01.108
ESZ23_FUT_CME[M] #1 | Reloading chart. | 2023-11-22 19:56:01.142
ESZ23_FUT_CME[M] 10 Min #5 | Reloading chart. | 2023-11-22 19:56:01.415
Mapping ESZ24_FUT_CME to ESZ24. Service code: cme | 2023-11-22 19:56:01.423
Added historical Intraday data request for ESZ24_FUT_CME to the queue. | 2023-11-22 19:56:01.424
Intraday data recording state for symbol ESZ24_FUT_CME is set to download 'Pending'. | 2023-11-22 19:56:01.424
Triggering next historical data download in queue. | 2023-11-22 19:56:01.424
HD Request # 21 | Downloading Intraday chart data for ESZ24_FUT_CME to the file ESZ24_FUT_CME.scid. Service: cme | 2023-11-22 19:56:01.426
HD Request # 21 | Download start date-time: 2023-05-20 20:56:01.000000. File last date-time: 00:00:00.000000 | 2023-11-22 19:56:01.426
HD Request # 21 | Using server: ds23.sierracharts.com port 10149 | 2023-11-22 19:56:01.426
Mapping ESZ23_FUT_CME to ESZ23. Service code: cme | 2023-11-22 19:56:01.433
Added historical Intraday data request for ESZ23_FUT_CME to the queue. | 2023-11-22 19:56:01.433
Intraday data recording state for symbol ESZ23_FUT_CME is set to download 'Pending'. | 2023-11-22 19:56:01.433
Triggering next historical data download in queue. | 2023-11-22 19:56:01.434
Mapping CLF24_FUT_CME to CLF24. Service code: nymex | 2023-11-22 19:56:01.495
Added historical Intraday data request for CLF24_FUT_CME to the queue. | 2023-11-22 19:56:01.496
Intraday data recording state for symbol CLF24_FUT_CME is set to download 'Pending'. | 2023-11-22 19:56:01.496
Triggering next historical data download in queue. | 2023-11-22 19:56:01.499
Mapping 10YX23_FUT_CME to 10YX23. Service code: cbot | 2023-11-22 19:56:01.510
Added historical Intraday data request for 10YX23_FUT_CME to the queue. | 2023-11-22 19:56:01.511
Intraday data recording state for symbol 10YX23_FUT_CME is set to download 'Pending'. | 2023-11-22 19:56:01.511
Triggering next historical data download in queue. | 2023-11-22 19:56:01.511
Socket (2) | Creating socket. | 2023-11-22 19:56:01.898
Socket (2) | New receive buffer size: 0 | 2023-11-22 19:56:01.898
Socket (2) | Connecting to IP: 142.215.17.190. | 2023-11-22 19:56:01.898
ESZ23_FUT_CME[M] #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-11-22 19:56:02.034
HD Request # 21 | Setting DTC encoding to Binary VLS | 2023-11-22 19:56:02.391
HD Request # 21 | Sending historical data logon request message. | 2023-11-22 19:56:02.391
Teton CME Order Routing | Firm: IronBeam | 2023-11-22 19:56:02.530
Teton CME Order Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11085 | 2023-11-22 19:56:02.533
DTC Client socket (3) | Creating socket. Using TLS 1.2. | 2023-11-22 19:56:02.573
DTC Client socket (3) | New receive buffer size: 0 | 2023-11-22 19:56:02.573
DTC Client socket (3) | Connecting to IP: 208.185.224.130. | 2023-11-22 19:56:02.573
HD Request # 21 | Requesting Intraday data. Start date-time: 2023-05-20 20:56:01. Record interval: 0. Symbol: ESZ24 | 2023-11-22 19:56:02.736
Teton CME Order Routing | Network connection to server complete. | 2023-11-22 19:56:02.758
Teton CME Order Routing | Starting socket receive thread. | 2023-11-22 19:56:02.758
Teton CME Order Routing | Sending encoding request to server: Binary VLS. Compression: none | 2023-11-22 19:56:02.758
HD Request # 21 | Decompressing data. | 2023-11-22 19:56:02.926
HD Request # 21 | Receiving Intraday data for ESZ24_FUT_CME starting at 2023-09-27 13:14:01.405000 | 2023-11-22 19:56:03.078
Socket (2) | CloseSocket call. | 2023-11-22 19:56:03.080
Socket (2) | Shutdown started. Waiting for graceful close. | 2023-11-22 19:56:03.080
Historical data download thread signaled to stop. | 2023-11-22 19:56:03.080
HD Request # 21 | Timestamp of first Intraday data file record written: 2023-09-27 13:14:01.405000. | 2023-11-22 19:56:03.081
HD Request # 21 | Received 18 Intraday data records from 2023-09-27 13:14:01.405000 to 2023-11-20 20:01:35.835000 (54.3 days. Delay: 47.9 hours) and wrote 18 records for ESZ24_FUT_CME | 2023-11-22 19:56:03.082
HD Request # 21 | Completion time: 2s. | 2023-11-22 19:56:03.082
HD Request # 21 | Intraday data download complete for ESZ24_FUT_CME. Unique request ID: 21 | 2023-11-22 19:56:03.082
Removing historical data download ID 21. | 2023-11-22 19:56:03.082
Real-time Intraday chart data file updates started for ESZ24_FUT_CME | 2023-11-22 19:56:03.082
Intraday chart data file opened for ESZ24_FUT_CME | 2023-11-22 19:56:03.082
HD Request # 21 | Enabling Intraday chart updating for symbol. | 2023-11-22 19:56:03.082
Triggering next historical data download in queue. | 2023-11-22 19:56:03.082
Historical data for ESZ24_FUT_CME is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2023-11-22 19:56:03.082
HD Request # 22 | Downloading Intraday chart data for ESZ23_FUT_CME to the file ESZ23_FUT_CME.scid. Service: cme | 2023-11-22 19:56:03.082
HD Request # 22 | Download start date-time: 2023-11-22 19:07:58.000000. File last date-time: 2023-11-22 19:07:58.261000 | 2023-11-22 19:56:03.088
HD Request # 22 | Using server: ds26.sierracharts.com port 10150 | 2023-11-22 19:56:03.088
Socket (4) | Creating socket. | 2023-11-22 19:56:03.191
Socket (4) | New receive buffer size: 0 | 2023-11-22 19:56:03.191
Socket (4) | Connecting to IP: 142.215.17.188. | 2023-11-22 19:56:03.191
Socket (2) | Socket gracefully closed by remote side. | 2023-11-22 19:56:03.249
Teton CME Order Routing | Setting DTC encoding to Binary VLS | 2023-11-22 19:56:03.249
Teton CME Order Routing | Sending logon request message. | 2023-11-22 19:56:03.249
Socket (2) | Closed. | 2023-11-22 19:56:03.249
HD Request # 22 | Setting DTC encoding to Binary VLS | 2023-11-22 19:56:03.573
HD Request # 22 | Sending historical data logon request message. | 2023-11-22 19:56:03.573
Teton CME Order Routing | Received logon response. | 2023-11-22 19:56:03.573
Teton CME Order Routing | Server Name: SC DTC Server. | 2023-11-22 19:56:03.573
Teton CME Order Routing | Server protocol version: 8. Client protocol version: 8 | 2023-11-22 19:56:03.573
Teton CME Order Routing | Connection error: No trade accounts assigned | 2023-11-22 19:56:03.573 *
Teton CME Order Routing | Failed connections: 1 | 2023-11-22 19:56:03.573
Teton CME Order Routing | Waiting for socket receive thread to end | 2023-11-22 19:56:03.666
DTC Client socket (3) | CloseSocket call. | 2023-11-22 19:56:03.666
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2023-11-22 19:56:03.666
Teton CME Order Routing | Disconnected. | 2023-11-22 19:56:03.666
DTC Client socket (3) | Socket gracefully closed by remote side. | 2023-11-22 19:56:03.805
DTC Client socket (3) | Closed. | 2023-11-22 19:56:03.805
HD Request # 22 | Requesting Intraday data. Start date-time: 2023-11-22 19:07:58. Record interval: 0. Symbol: ESZ23 | 2023-11-22 19:56:03.905
HD Request # 22 | Decompressing data. | 2023-11-22 19:56:04.073
HD Request # 22 | Receiving Intraday data for ESZ23_FUT_CME starting at 2023-11-22 19:07:58.258000 | 2023-11-22 19:56:04.228
Symbol settings received. Request ID: 6. | 2023-11-22 19:56:04.414
HD Request # 22 | Timestamp of first Intraday data file record written: 2023-11-22 19:08:00.010000. | 2023-11-22 19:56:04.956
Socket (4) | CloseSocket call. | 2023-11-22 19:56:05.332
Socket (4) | Shutdown started. Waiting for graceful close. | 2023-11-22 19:56:05.332
Socket (4) | Socket gracefully closed by remote side. | 2023-11-22 19:56:05.557
Socket (4) | Closed. | 2023-11-22 19:56:05.557
Historical data download thread signaled to stop. | 2023-11-22 19:56:06.154
HD Request # 22 | Received 58494 Intraday data records from 2023-11-22 19:07:58.258000 to 2023-11-22 19:46:03.816002 (38.1 minutes. Delay: 10.0 minutes) and wrote 58492 records for ESZ23_FUT_CME | 2023-11-22 19:56:06.162
HD Request # 22 | Completion time: 3s. | 2023-11-22 19:56:06.162
HD Request # 22 | Intraday data download complete for ESZ23_FUT_CME. Unique request ID: 22 | 2023-11-22 19:56:06.162
Removing historical data download ID 22. | 2023-11-22 19:56:06.162
Real-time Intraday chart data file updates started for ESZ23_FUT_CME | 2023-11-22 19:56:06.162
Intraday chart data file opened for ESZ23_FUT_CME | 2023-11-22 19:56:06.162
HD Request # 22 | Enabling Intraday chart updating for symbol. | 2023-11-22 19:56:06.162
Triggering next historical data download in queue. | 2023-11-22 19:56:06.162
Historical data for ESZ23_FUT_CME is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2023-11-22 19:56:06.162
HD Request # 23 | Downloading Intraday chart data for CLF24_FUT_CME to the file CLF24_FUT_CME.scid. Service: nymex | 2023-11-22 19:56:06.164
HD Request # 23 | Download start date-time: 2023-11-22 19:08:02.000000. File last date-time: 2023-11-22 19:08:02.403000 | 2023-11-22 19:56:06.164
HD Request # 23 | Using server: ds28.sierracharts.com port 10149 | 2023-11-22 19:56:06.164
Socket (2) | Creating socket. | 2023-11-22 19:56:06.216
Socket (2) | New receive buffer size: 0 | 2023-11-22 19:56:06.216
Socket (2) | Connecting to IP: 142.215.18.147. | 2023-11-22 19:56:06.216
HD Request # 23 | Setting DTC encoding to Binary VLS | 2023-11-22 19:56:06.642
HD Request # 23 | Sending historical data logon request message. | 2023-11-22 19:56:06.643
HD Request # 23 | Requesting Intraday data. Start date-time: 2023-11-22 19:08:02. Record interval: 0. Symbol: CLF24 | 2023-11-22 19:56:06.980
HD Request # 23 | Decompressing data. | 2023-11-22 19:56:07.156
HD Request # 23 | Receiving Intraday data for CLF24_FUT_CME starting at 2023-11-22 19:08:02.403000 | 2023-11-22 19:56:07.568
Socket (2) | CloseSocket call. | 2023-11-22 19:56:07.942
Socket (2) | Shutdown started. Waiting for graceful close. | 2023-11-22 19:56:07.942
Historical data download thread signaled to stop. | 2023-11-22 19:56:07.942
HD Request # 23 | Timestamp of first Intraday data file record written: 2023-11-22 19:08:03.802000. | 2023-11-22 19:56:07.943
HD Request # 23 | Received 13811 Intraday data records from 2023-11-22 19:08:02.403000 to 2023-11-22 19:46:06.648001 (38.1 minutes. Delay: 10.0 minutes) and wrote 13810 records for CLF24_FUT_CME | 2023-11-22 19:56:07.943
HD Request # 23 | Completion time: 1s. | 2023-11-22 19:56:07.943
HD Request # 23 | Intraday data download complete for CLF24_FUT_CME. Unique request ID: 23 | 2023-11-22 19:56:07.943
Removing historical data download ID 23. | 2023-11-22 19:56:07.943
Real-time Intraday chart data file updates started for CLF24_FUT_CME | 2023-11-22 19:56:07.943
Intraday chart data file opened for CLF24_FUT_CME | 2023-11-22 19:56:07.943
HD Request # 23 | Enabling Intraday chart updating for symbol. | 2023-11-22 19:56:07.943
Triggering next historical data download in queue. | 2023-11-22 19:56:07.943
Historical data for CLF24_FUT_CME is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2023-11-22 19:56:07.943
HD Request # 24 | Downloading Intraday chart data for 10YX23_FUT_CME to the file 10YX23_FUT_CME.scid. Service: cbot | 2023-11-22 19:56:07.943
HD Request # 24 | Download start date-time: 2023-11-22 19:06:28.000000. File last date-time: 2023-11-22 19:06:28.314000 | 2023-11-22 19:56:07.944
HD Request # 24 | Using server: ds27.sierracharts.com port 10150 | 2023-11-22 19:56:07.944
Socket (1) | Creating socket. | 2023-11-22 19:56:07.953
Socket (1) | New receive buffer size: 0 | 2023-11-22 19:56:07.953
Socket (1) | Connecting to IP: 38.89.227.130. | 2023-11-22 19:56:07.953
Socket (2) | Socket gracefully closed by remote side. | 2023-11-22 19:56:08.108
Socket (2) | Closed. | 2023-11-22 19:56:08.108
HD Request # 24 | Setting DTC encoding to Binary VLS | 2023-11-22 19:56:08.280
HD Request # 24 | Sending historical data logon request message. | 2023-11-22 19:56:08.280
HD Request # 24 | Requesting Intraday data. Start date-time: 2023-11-22 19:06:28. Record interval: 0. Symbol: 10YX23 | 2023-11-22 19:56:08.730
HD Request # 24 | Decompressing data. | 2023-11-22 19:56:08.943
HD Request # 24 | Receiving Intraday data for 10YX23_FUT_CME starting at 2023-11-22 19:06:28.314000 | 2023-11-22 19:56:09.173
Socket (1) | CloseSocket call. | 2023-11-22 19:56:09.173
Socket (1) | Shutdown started. Waiting for graceful close. | 2023-11-22 19:56:09.173
Historical data download thread signaled to stop. | 2023-11-22 19:56:09.173
HD Request # 24 | Timestamp of first Intraday data file record written: 2023-11-22 19:10:10.115000. | 2023-11-22 19:56:09.173
HD Request # 24 | Received 27 Intraday data records from 2023-11-22 19:06:28.314000 to 2023-11-22 19:42:47.316000 (36.3 minutes. Delay: 13.4 minutes) and wrote 26 records for 10YX23_FUT_CME | 2023-11-22 19:56:09.174
HD Request # 24 | Completion time: 2s. | 2023-11-22 19:56:09.174
HD Request # 24 | Intraday data download complete for 10YX23_FUT_CME. Unique request ID: 24 | 2023-11-22 19:56:09.174
Removing historical data download ID 24. | 2023-11-22 19:56:09.174
Real-time Intraday chart data file updates started for 10YX23_FUT_CME | 2023-11-22 19:56:09.174
Intraday chart data file opened for 10YX23_FUT_CME | 2023-11-22 19:56:09.174
HD Request # 24 | Enabling Intraday chart updating for symbol. | 2023-11-22 19:56:09.174
No download requests in the queue to start downloads for. | 2023-11-22 19:56:09.174
Historical data for 10YX23_FUT_CME is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2023-11-22 19:56:09.174
Socket (1) | Socket gracefully closed by remote side. | 2023-11-22 19:56:09.321
Socket (1) | Closed. | 2023-11-22 19:56:09.321
ESZ23_FUT_CME[M] 5 Min #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-11-22 19:56:09.688
ESZ23_FUT_CME[M] 1 Min #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-11-22 19:56:21.162
ESZ23_FUT_CME[M] #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-11-22 19:56:29.921
Checking for new symbol settings. Requested symbol settings MD5 for service code scdataallservices. Request ID: 7. | 2023-11-22 19:56:56.489
Current selected Data/Trading service: SC Data - All Services | 2023-11-22 19:56:56.489
SC Data - All Services | Disconnected. | 2023-11-22 19:56:58.162
SC Data - All Services | Disconnected. | 2023-11-22 19:56:58.165
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-22 19:56:58.165
ESZ23-CME[M] 1 Min #9 | Reloading chart. | 2023-11-22 19:56:58.185
10YX23-CBOT[M] 5 Min #8 | Reloading chart. | 2023-11-22 19:56:58.227
ESZ23-CME[M] 5 Min #2 | Reloading chart. | 2023-11-22 19:56:58.236
10YX23-CBOT[M] #7 | Reloading chart. | 2023-11-22 19:56:58.362
10YX23-CBOT[M] #7 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-11-22 19:56:58.363
ESZ23-CME[M] #1 | Reloading chart. | 2023-11-22 19:56:58.382
ESZ24-CME[M] 1 Min #10 | Reloading chart. | 2023-11-22 19:56:58.396
ESZ23-CME[M] #3 | Reloading chart. | 2023-11-22 19:56:58.409
ESZ23-CME[M] 5 Min #4 | Reloading chart. | 2023-11-22 19:56:58.512
CLF24-NYMEX[M] 10 Min #6 | Reloading chart. | 2023-11-22 19:56:58.543
ESZ23-CME[M] 10 Min #5 | Reloading chart. | 2023-11-22 19:56:58.671
Symbol settings MD5 received. Request ID: 7. | 2023-11-22 19:56:58.997
Requested symbol settings for service code scdataallservices. Request ID: 8. | 2023-11-22 19:56:58.997
ESZ23-CME[M] #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-11-22 19:56:59.640
SC Data - All Services | Connected to server complete. | 2023-11-22 19:57:00.201
No download requests in the queue to start downloads for. | 2023-11-22 19:57:00.202
Notice: Not connected to Live trading account to receive CME realtime futures data at non-professional fees. | 2023-11-22 19:57:00.202
Mapping ESZ23-CME to ESZ23. Service code: cme | 2023-11-22 19:57:00.204
Using symbol data fast lookup vector | 2023-11-22 19:57:00.204
Delayed Data Feed | Starting real-time market data updates for: ESZ23-CME (ESZ23). ID: 1 Service code: cme | 2023-11-22 19:57:00.204
Delayed Data Feed | Connecting to the server ds26.sierracharts.com. Port 10043 | 2023-11-22 19:57:00.204
Delayed Data Feed | Requesting security definition data for: ESZ23-CME (ESZ23). ID: 1 | 2023-11-22 19:57:00.204
Added historical Intraday data request for ESZ23-CME to the queue. | 2023-11-22 19:57:00.204
Intraday data recording state for symbol ESZ23-CME is set to download 'Pending'. | 2023-11-22 19:57:00.204
Triggering next historical data download in queue. | 2023-11-22 19:57:00.204
DTC Client socket (1) | Creating socket. | 2023-11-22 19:57:00.204
DTC Client socket (1) | New receive buffer size: 0 | 2023-11-22 19:57:00.204
DTC Client socket (1) | Connecting to IP: 142.215.17.188. | 2023-11-22 19:57:00.204
Delaying start of download for ESZ23-CME. | 2023-11-22 19:57:00.205
Delayed Data Feed | Network connection to server complete. | 2023-11-22 19:57:01.307
Delayed Data Feed | Starting socket receive thread. | 2023-11-22 19:57:01.307
Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-11-22 19:57:01.307
Mapping 10YX23-CBOT to 10YX23. Service code: cbot | 2023-11-22 19:57:01.312
Delayed Data Feed | Starting real-time market data updates for: 10YX23-CBOT (10YX23). ID: 2 Service code: cbot | 2023-11-22 19:57:01.312
Delayed Data Feed | Requesting security definition data for: 10YX23-CBOT (10YX23). ID: 2 | 2023-11-22 19:57:01.312
Added historical Intraday data request for 10YX23-CBOT to the queue. | 2023-11-22 19:57:01.312
Intraday data recording state for symbol 10YX23-CBOT is set to download 'Pending'. | 2023-11-22 19:57:01.312
Triggering next historical data download in queue. | 2023-11-22 19:57:01.312
Mapping ESZ24-CME to ESZ24. Service code: cme | 2023-11-22 19:57:01.393
Delayed Data Feed | Starting real-time market data updates for: ESZ24-CME (ESZ24). ID: 3 Service code: cme | 2023-11-22 19:57:01.393
Delayed Data Feed | Requesting security definition data for: ESZ24-CME (ESZ24). ID: 3 | 2023-11-22 19:57:01.393
Added historical Intraday data request for ESZ24-CME to the queue. | 2023-11-22 19:57:01.393
Intraday data recording state for symbol ESZ24-CME is set to download 'Pending'. | 2023-11-22 19:57:01.393
Triggering next historical data download in queue. | 2023-11-22 19:57:01.393
Mapping CLF24-NYMEX to CLF24. Service code: nymex | 2023-11-22 19:57:01.420
Delayed Data Feed | Starting real-time market data updates for: CLF24-NYMEX (CLF24). ID: 4 Service code: nymex | 2023-11-22 19:57:01.420
Delayed Data Feed | Requesting security definition data for: CLF24-NYMEX (CLF24). ID: 4 | 2023-11-22 19:57:01.420
Added historical Intraday data request for CLF24-NYMEX to the queue. | 2023-11-22 19:57:01.420
Intraday data recording state for symbol CLF24-NYMEX is set to download 'Pending'. | 2023-11-22 19:57:01.420
Triggering next historical data download in queue. | 2023-11-22 19:57:01.420
Delayed Data Feed | Setting DTC encoding to Binary VLS | 2023-11-22 19:57:01.568
Delayed Data Feed | Sending logon request message. | 2023-11-22 19:57:01.568
Delayed Data Feed | Received logon response. | 2023-11-22 19:57:02.134
Delayed Data Feed | Server Name: SC Realtime Server. | 2023-11-22 19:57:02.134
Delayed Data Feed | Server protocol version: 8. Client protocol version: 8 | 2023-11-22 19:57:02.134
Delayed Data Feed | Successfully connected. | 2023-11-22 19:57:02.134
Delayed Data Feed | Trading is not supported. | 2023-11-22 19:57:02.134
Delayed Data Feed | Restarting real-time data updates for symbol: 10YX23-CBOT -> 10YX23 | 2023-11-22 19:57:02.134
Delayed Data Feed | Restarting real-time data updates for symbol: CLF24-NYMEX -> CLF24 | 2023-11-22 19:57:02.134
Delayed Data Feed | Restarting real-time data updates for symbol: ESZ23-CME -> ESZ23 | 2023-11-22 19:57:02.134
Delayed Data Feed | Restarting real-time data updates for symbol: ESZ24-CME -> ESZ24 | 2023-11-22 19:57:02.134
Symbol settings received. Request ID: 8. | 2023-11-22 19:57:02.455
Delayed Data Feed | Received security definition for symbol 10YX23-CBOT | 2023-11-22 19:57:17.757
Delayed Data Feed | Received security definition for symbol CLF24-NYMEX | 2023-11-22 19:57:17.757
Delayed Data Feed | Received security definition for symbol ESZ23-CME | 2023-11-22 19:57:17.757
Delayed Data Feed | Received security definition for symbol ESZ24-CME | 2023-11-22 19:57:17.757
ESZ23-CME[M] 5 Min #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-11-22 19:57:17.767
ESZ23-CME[M] 1 Min #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-11-22 19:57:17.772
HD Request # 25 | Downloading Intraday chart data for ESZ23-CME to the file ESZ23-CME.scid. Service: cme | 2023-11-22 19:57:18.006
HD Request # 25 | Download start date-time: 2023-11-22 19:45:47.000000. File last date-time: 2023-11-22 19:45:47.483000 | 2023-11-22 19:57:18.017
HD Request # 25 | Using server: ds23.sierracharts.com port 10149 | 2023-11-22 19:57:18.017
Socket (3) | Creating socket. | 2023-11-22 19:57:18.017
Socket (3) | New receive buffer size: 0 | 2023-11-22 19:57:18.017
Socket (3) | Connecting to IP: 142.215.17.190. | 2023-11-22 19:57:18.017
Requesting market depth updates for: 10YX23-CBOT if supported. NumLevels=100 | 2023-11-22 19:57:18.099
Requesting market depth updates for: ESZ23-CME if supported. NumLevels=100 | 2023-11-22 19:57:18.099
HD Request # 25 | Setting DTC encoding to Binary VLS | 2023-11-22 19:57:18.277
HD Request # 25 | Sending historical data logon request message. | 2023-11-22 19:57:18.277
Delayed Data Feed | Clearing market depth for 10YX23-CBOT | 2023-11-22 19:57:18.282
Delayed Data Feed | Clearing market depth for ESZ23-CME | 2023-11-22 19:57:18.282
HD Request # 25 | Requesting Intraday data. Start date-time: 2023-11-22 19:45:47. Record interval: 0. Symbol: ESZ23 | 2023-11-22 19:57:18.630
HD Request # 25 | Decompressing data. | 2023-11-22 19:57:18.764
HD Request # 25 | Receiving Intraday data for ESZ23-CME starting at 2023-11-22 19:45:47.212000 | 2023-11-22 19:57:19.168
Socket (3) | CloseSocket call. | 2023-11-22 19:57:19.169
Socket (3) | Shutdown started. Waiting for graceful close. | 2023-11-22 19:57:19.169
Historical data download thread signaled to stop. | 2023-11-22 19:57:19.169
HD Request # 25 | Timestamp of first Intraday data file record written: 2023-11-22 19:45:48.274000. | 2023-11-22 19:57:19.170
HD Request # 25 | Received 2741 Intraday data records from 2023-11-22 19:45:47.212000 to 2023-11-22 19:47:18.751000 (91.5 seconds. Delay: 10.0 minutes) and wrote 2739 records for ESZ23-CME | 2023-11-22 19:57:19.170
HD Request # 25 | Add time&sales data | Remembered last file record date-time: 2023-11-22 19:47:18.751000 | 2023-11-22 19:57:19.191
HD Request # 25 | Completion time: 1s. | 2023-11-22 19:57:19.193
HD Request # 25 | Intraday data download complete for ESZ23-CME. Unique request ID: 25 | 2023-11-22 19:57:19.193
Removing historical data download ID 25. | 2023-11-22 19:57:19.193
Real-time Intraday chart data file updates started for ESZ23-CME | 2023-11-22 19:57:19.193
Intraday chart data file opened for ESZ23-CME | 2023-11-22 19:57:19.193
HD Request # 25 | Enabling Intraday chart updating for symbol. | 2023-11-22 19:57:19.193
Triggering next historical data download in queue. | 2023-11-22 19:57:19.194
HD Request # 26 | Downloading Intraday chart data for 10YX23-CBOT to the file 10YX23-CBOT.scid. Service: cbot | 2023-11-22 19:57:19.194
HD Request # 26 | Download start date-time: 2023-11-22 19:42:47.000000. File last date-time: 2023-11-22 19:42:47.316000 | 2023-11-22 19:57:19.194
HD Request # 26 | Using server: ds26.sierracharts.com port 10150 | 2023-11-22 19:57:19.194
Socket (2) | Creating socket. | 2023-11-22 19:57:19.195
Socket (2) | New receive buffer size: 0 | 2023-11-22 19:57:19.195
Socket (2) | Connecting to IP: 142.215.17.188. | 2023-11-22 19:57:19.195
Socket (3) | Socket gracefully closed by remote side. | 2023-11-22 19:57:19.376
Socket (3) | Closed. | 2023-11-22 19:57:19.376
HD Request # 26 | Setting DTC encoding to Binary VLS | 2023-11-22 19:57:19.627
HD Request # 26 | Sending historical data logon request message. | 2023-11-22 19:57:19.627
Opened cached Intraday file: C:\SierraChart\Data\ESZ23-CME.scid. Thread ID: 16852 | 2023-11-22 19:57:19.860
HD Request # 26 | Requesting Intraday data. Start date-time: 2023-11-22 19:42:47. Record interval: 0. Symbol: 10YX23 | 2023-11-22 19:57:20.260
HD Request # 26 | Decompressing data. | 2023-11-22 19:57:20.407
HD Request # 26 | Receiving Intraday data for 10YX23-CBOT starting at 2023-11-22 19:42:47.316000 | 2023-11-22 19:57:20.563
Socket (2) | CloseSocket call. | 2023-11-22 19:57:20.563
Socket (2) | Shutdown started. Waiting for graceful close. | 2023-11-22 19:57:20.563
Historical data download thread signaled to stop. | 2023-11-22 19:57:20.563
HD Request # 26 | Received 1 Intraday data record from 2023-11-22 19:42:47.316000 to 2023-11-22 19:42:47.316000 (0.0 seconds. Delay: 14.6 minutes) and wrote 0 records for 10YX23-CBOT | 2023-11-22 19:57:20.563
HD Request # 26 | Add time&sales data | Remembered last file record date-time: 2023-11-22 19:42:47.316000 | 2023-11-22 19:57:20.564
HD Request # 26 | Completion time: 1s. | 2023-11-22 19:57:20.564
HD Request # 26 | Intraday data download complete for 10YX23-CBOT. Unique request ID: 26 | 2023-11-22 19:57:20.564
Removing historical data download ID 26. | 2023-11-22 19:57:20.564
Real-time Intraday chart data file updates started for 10YX23-CBOT | 2023-11-22 19:57:20.564
Intraday chart data file opened for 10YX23-CBOT | 2023-11-22 19:57:20.564
HD Request # 26 | Enabling Intraday chart updating for symbol. | 2023-11-22 19:57:20.564
Triggering next historical data download in queue. | 2023-11-22 19:57:20.564
HD Request # 27 | Downloading Intraday chart data for ESZ24-CME to the file ESZ24-CME.scid. Service: cme | 2023-11-22 19:57:20.564
HD Request # 27 | Download start date-time: 2023-11-20 20:01:35.000000. File last date-time: 2023-11-20 20:01:35.835000 | 2023-11-22 19:57:20.564
HD Request # 27 | Using server: ds28.sierracharts.com port 10149 | 2023-11-22 19:57:20.564
Socket (3) | Creating socket. | 2023-11-22 19:57:20.564
Socket (3) | New receive buffer size: 0 | 2023-11-22 19:57:20.564
Socket (3) | Connecting to IP: 142.215.18.147. | 2023-11-22 19:57:20.564
Socket (2) | Socket gracefully closed by remote side. | 2023-11-22 19:57:20.696
Socket (2) | Closed. | 2023-11-22 19:57:20.697
HD Request # 27 | Setting DTC encoding to Binary VLS | 2023-11-22 19:57:20.837
HD Request # 27 | Sending historical data logon request message. | 2023-11-22 19:57:20.838
HD Request # 27 | Requesting Intraday data. Start date-time: 2023-11-20 20:01:35. Record interval: 0. Symbol: ESZ24 | 2023-11-22 19:57:21.173
HD Request # 27 | Decompressing data. | 2023-11-22 19:57:21.305
HD Request # 27 | Receiving Intraday data for ESZ24-CME starting at 2023-11-20 20:01:35.835000 | 2023-11-22 19:57:21.448
Socket (3) | CloseSocket call. | 2023-11-22 19:57:21.448
Historical data download thread signaled to stop. | 2023-11-22 19:57:21.451
HD Request # 27 | Received 1 Intraday data record from 2023-11-20 20:01:35.835000 to 2023-11-20 20:01:35.835000 (0.0 seconds. Delay: 47.9 hours) and wrote 0 records for ESZ24-CME | 2023-11-22 19:57:21.451
HD Request # 27 | Add time&sales data | Remembered last file record date-time: 2023-11-20 20:01:35.835000 | 2023-11-22 19:57:21.452
HD Request # 27 | Completion time: 1s. | 2023-11-22 19:57:21.452
HD Request # 27 | Intraday data download complete for ESZ24-CME. Unique request ID: 27 | 2023-11-22 19:57:21.452
Removing historical data download ID 27. | 2023-11-22 19:57:21.452
Real-time Intraday chart data file updates started for ESZ24-CME | 2023-11-22 19:57:21.452
Intraday chart data file opened for ESZ24-CME | 2023-11-22 19:57:21.452
HD Request # 27 | Enabling Intraday chart updating for symbol. | 2023-11-22 19:57:21.452
Triggering next historical data download in queue. | 2023-11-22 19:57:21.452
HD Request # 28 | Downloading Intraday chart data for CLF24-NYMEX to the file CLF24-NYMEX.scid. Service: nymex | 2023-11-22 19:57:21.452
HD Request # 28 | Download start date-time: 2023-11-22 19:45:47.000000. File last date-time: 2023-11-22 19:45:47.248000 | 2023-11-22 19:57:21.452
HD Request # 28 | Using server: ds27.sierracharts.com port 10150 | 2023-11-22 19:57:21.452
Socket (3) | Shutdown started. Waiting for graceful close. | 2023-11-22 19:57:21.463
Socket (2) | Creating socket. | 2023-11-22 19:57:21.463
Socket (2) | New receive buffer size: 0 | 2023-11-22 19:57:21.463
Socket (2) | Connecting to IP: 38.89.227.130. | 2023-11-22 19:57:21.463
Socket (3) | Socket gracefully closed by remote side. | 2023-11-22 19:57:21.600
Socket (3) | Closed. | 2023-11-22 19:57:21.600
HD Request # 28 | Setting DTC encoding to Binary VLS | 2023-11-22 19:57:21.705
HD Request # 28 | Sending historical data logon request message. | 2023-11-22 19:57:21.705
HD Request # 28 | Requesting Intraday data. Start date-time: 2023-11-22 19:45:47. Record interval: 0. Symbol: CLF24 | 2023-11-22 19:57:22.087
HD Request # 28 | Decompressing data. | 2023-11-22 19:57:22.210
HD Request # 28 | Receiving Intraday data for CLF24-NYMEX starting at 2023-11-22 19:45:47.246000 | 2023-11-22 19:57:22.325
Socket (2) | CloseSocket call. | 2023-11-22 19:57:22.327
Socket (2) | Shutdown started. Waiting for graceful close. | 2023-11-22 19:57:22.327
Historical data download thread signaled to stop. | 2023-11-22 19:57:22.327
HD Request # 28 | Timestamp of first Intraday data file record written: 2023-11-22 19:45:47.732000. | 2023-11-22 19:57:22.327
HD Request # 28 | Received 245 Intraday data records from 2023-11-22 19:45:47.246000 to 2023-11-22 19:47:20.207000 (93.0 seconds. Delay: 10.0 minutes) and wrote 240 records for CLF24-NYMEX | 2023-11-22 19:57:22.328
HD Request # 28 | Add time&sales data | Remembered last file record date-time: 2023-11-22 19:47:20.207000 | 2023-11-22 19:57:22.338
HD Request # 28 | Completion time: 1s. | 2023-11-22 19:57:22.338
HD Request # 28 | Intraday data download complete for CLF24-NYMEX. Unique request ID: 28 | 2023-11-22 19:57:22.338
Removing historical data download ID 28. | 2023-11-22 19:57:22.338
Real-time Intraday chart data file updates started for CLF24-NYMEX | 2023-11-22 19:57:22.338
Intraday chart data file opened for CLF24-NYMEX | 2023-11-22 19:57:22.338
HD Request # 28 | Enabling Intraday chart updating for symbol. | 2023-11-22 19:57:22.338
No download requests in the queue to start downloads for. | 2023-11-22 19:57:22.338
Socket (2) | Socket gracefully closed by remote side. | 2023-11-22 19:57:22.442
Socket (2) | Closed. | 2023-11-22 19:57:22.442
ESZ23-CME[M] #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-11-22 19:57:23.022
Opened cached Intraday file: C:\SierraChart\Data\CLF24-NYMEX.scid. Thread ID: 16852 | 2023-11-22 19:57:30.099
Opened cached Intraday file: C:\SierraChart\Data\10YX23-CBOT.scid. Thread ID: 16852 | 2023-11-22 19:58:37.375
DTC Client socket (1) | Close event error. Windows error code 10053: Uma ligação estabelecida foi anulada pelo software no computador anfitrião. | 2023-11-22 20:52:39.927 *
DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-11-22 20:52:39.927
DTC Client socket (1) | CloseSocket call. | 2023-11-22 20:52:40.354
Delayed Data Feed | Waiting for socket receive thread to end | 2023-11-22 20:52:40.357
DTC Client socket (0) | CloseSocket call. | 2023-11-22 20:52:40.357
Delayed Data Feed | Disconnected from the server. | 2023-11-22 20:52:40.357
Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-11-22 20:52:40.357
DTC Client socket (1) | Socket receive error. Windows error code 10054: Uma ligação existente foi forçada a fechar pelo anfitrião remoto. | 2023-11-22 20:52:40.379
DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-22 20:52:40.431
DTC Client socket (1) | Closed. | 2023-11-22 20:52:40.432
Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-11-22 20:52:42.350
DTC Client socket (1) | Creating socket. | 2023-11-22 20:52:42.350
DTC Client socket (1) | New receive buffer size: 0 | 2023-11-22 20:52:42.351
DTC Client socket (1) | Connecting to IP: 142.215.18.147. | 2023-11-22 20:52:42.351
Delayed Data Feed | Network connection to server complete. | 2023-11-22 20:52:42.482
Delayed Data Feed | Starting socket receive thread. | 2023-11-22 20:52:42.482
Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-11-22 20:52:42.482
Delayed Data Feed | Setting DTC encoding to Binary VLS | 2023-11-22 20:52:42.650
Delayed Data Feed | Sending logon request message. | 2023-11-22 20:52:42.650
Delayed Data Feed | Received logon response. | 2023-11-22 20:52:43.096
Delayed Data Feed | Server Name: SC Realtime Server. | 2023-11-22 20:52:43.096
Delayed Data Feed | Server protocol version: 8. Client protocol version: 8 | 2023-11-22 20:52:43.096
Delayed Data Feed | Successfully connected. | 2023-11-22 20:52:43.096
Delayed Data Feed | Trading is not supported. | 2023-11-22 20:52:43.096
Added historical Intraday data request for 10YX23-CBOT to the queue. | 2023-11-22 20:52:43.096
Intraday data recording state for symbol 10YX23-CBOT is set to download 'Pending'. | 2023-11-22 20:52:43.097
Triggering next historical data download in queue. | 2023-11-22 20:52:43.097
Delayed Data Feed | Restarting real-time data updates for symbol: 10YX23-CBOT -> 10YX23. Market Depth data restarted. | 2023-11-22 20:52:43.097
Added historical Intraday data request for CLF24-NYMEX to the queue. | 2023-11-22 20:52:43.097
Intraday data recording state for symbol CLF24-NYMEX is set to download 'Pending'. | 2023-11-22 20:52:43.097
Delayed Data Feed | Restarting real-time data updates for symbol: CLF24-NYMEX -> CLF24 | 2023-11-22 20:52:43.097
Added historical Intraday data request for ESZ23-CME to the queue. | 2023-11-22 20:52:43.097
Intraday data recording state for symbol ESZ23-CME is set to download 'Pending'. | 2023-11-22 20:52:43.097
Delayed Data Feed | Restarting real-time data updates for symbol: ESZ23-CME -> ESZ23. Market Depth data restarted. | 2023-11-22 20:52:43.097
Added historical Intraday data request for ESZ24-CME to the queue. | 2023-11-22 20:52:43.097
Intraday data recording state for symbol ESZ24-CME is set to download 'Pending'. | 2023-11-22 20:52:43.097
Delayed Data Feed | Restarting real-time data updates for symbol: ESZ24-CME -> ESZ24 | 2023-11-22 20:52:43.097
HD Request # 29 | Downloading Intraday chart data for 10YX23-CBOT to the file 10YX23-CBOT.scid. Service: cbot | 2023-11-22 20:52:43.097
HD Request # 29 | Download start date-time: 2023-11-22 19:48:27.000000. File last date-time: 2023-11-22 19:48:27.420000 | 2023-11-22 20:52:43.098
HD Request # 29 | Using server: ds23.sierracharts.com port 10149 | 2023-11-22 20:52:43.098
Socket (2) | Creating socket. | 2023-11-22 20:52:43.098
Socket (2) | New receive buffer size: 0 | 2023-11-22 20:52:43.098
Socket (2) | Connecting to IP: 142.215.17.190. | 2023-11-22 20:52:43.098
HD Request # 29 | Setting DTC encoding to Binary VLS | 2023-11-22 20:52:43.371
HD Request # 29 | Sending historical data logon request message. | 2023-11-22 20:52:43.371
Delayed Data Feed | Clearing market depth for 10YX23-CBOT | 2023-11-22 20:52:43.444
Delayed Data Feed | Clearing market depth for ESZ23-CME | 2023-11-22 20:52:43.444
Delayed Data Feed | Received security definition for symbol 10YX23-CBOT | 2023-11-22 20:52:43.445
Delayed Data Feed | Received security definition for symbol CLF24-NYMEX | 2023-11-22 20:52:43.445
Delayed Data Feed | Received security definition for symbol ESZ23-CME | 2023-11-22 20:52:43.445
Delayed Data Feed | Received security definition for symbol ESZ24-CME | 2023-11-22 20:52:43.445
HD Request # 29 | Requesting Intraday data. Start date-time: 2023-11-22 19:48:27. Record interval: 0. Symbol: 10YX23 | 2023-11-22 20:52:43.710
HD Request # 29 | Decompressing data. | 2023-11-22 20:52:43.839
HD Request # 29 | Receiving Intraday data for 10YX23-CBOT starting at 2023-11-22 19:48:27.420000 | 2023-11-22 20:52:43.974
Socket (2) | CloseSocket call. | 2023-11-22 20:52:43.974
Socket (2) | Shutdown started. Waiting for graceful close. | 2023-11-22 20:52:43.974
Historical data download thread signaled to stop. | 2023-11-22 20:52:43.974
HD Request # 29 | Timestamp of first Intraday data file record written: 2023-11-22 19:51:56.418000. | 2023-11-22 20:52:43.974
HD Request # 29 | Received 65 Intraday data records from 2023-11-22 19:48:27.420000 to 2023-11-22 20:34:38.158000 (46.2 minutes. Delay: 18.1 minutes) and wrote 64 records for 10YX23-CBOT | 2023-11-22 20:52:43.974
HD Request # 29 | Add time&sales data | Remembered last file record date-time: 2023-11-22 20:34:38.158000 | 2023-11-22 20:52:43.981
HD Request # 29 | Completion time: 0s. | 2023-11-22 20:52:43.981
HD Request # 29 | Intraday data download complete for 10YX23-CBOT. Unique request ID: 29 | 2023-11-22 20:52:43.981
Removing historical data download ID 29. | 2023-11-22 20:52:43.981
Real-time Intraday chart data file updates started for 10YX23-CBOT | 2023-11-22 20:52:43.981
Intraday chart data file opened for 10YX23-CBOT | 2023-11-22 20:52:43.981
HD Request # 29 | Enabling Intraday chart updating for symbol. | 2023-11-22 20:52:43.981
Triggering next historical data download in queue. | 2023-11-22 20:52:43.981
HD Request # 30 | Downloading Intraday chart data for CLF24-NYMEX to the file CLF24-NYMEX.scid. Service: nymex | 2023-11-22 20:52:43.981
HD Request # 30 | Download start date-time: 2023-11-22 19:51:23.000000. File last date-time: 2023-11-22 19:51:23.644000 | 2023-11-22 20:52:43.981
HD Request # 30 | Using server: ds26.sierracharts.com port 10150 | 2023-11-22 20:52:43.982
Socket (3) | Creating socket. | 2023-11-22 20:52:43.982
Socket (3) | New receive buffer size: 0 | 2023-11-22 20:52:43.982
Socket (3) | Connecting to IP: 142.215.17.188. | 2023-11-22 20:52:43.982
Socket (2) | Socket gracefully closed by remote side. | 2023-11-22 20:52:44.104
Socket (2) | Closed. | 2023-11-22 20:52:44.104
HD Request # 30 | Setting DTC encoding to Binary VLS | 2023-11-22 20:52:44.261
HD Request # 30 | Sending historical data logon request message. | 2023-11-22 20:52:44.261
HD Request # 30 | Requesting Intraday data. Start date-time: 2023-11-22 19:51:23. Record interval: 0. Symbol: CLF24 | 2023-11-22 20:52:44.593
HD Request # 30 | Decompressing data. | 2023-11-22 20:52:44.724
HD Request # 30 | Receiving Intraday data for CLF24-NYMEX starting at 2023-11-22 19:51:23.644000 | 2023-11-22 20:52:44.862
Socket (3) | CloseSocket call. | 2023-11-22 20:52:44.866
Socket (3) | Shutdown started. Waiting for graceful close. | 2023-11-22 20:52:44.866
Historical data download thread signaled to stop. | 2023-11-22 20:52:44.866
HD Request # 30 | Timestamp of first Intraday data file record written: 2023-11-22 19:51:32.100000. | 2023-11-22 20:52:44.867
HD Request # 30 | Received 2352 Intraday data records from 2023-11-22 19:51:23.644000 to 2023-11-22 20:42:25.385000 (51.0 minutes. Delay: 10.3 minutes) and wrote 2351 records for CLF24-NYMEX | 2023-11-22 20:52:44.867
HD Request # 30 | Add time&sales data | Remembered last file record date-time: 2023-11-22 20:42:25.385000 | 2023-11-22 20:52:44.882
HD Request # 30 | Completion time: 1s. | 2023-11-22 20:52:44.882
HD Request # 30 | Intraday data download complete for CLF24-NYMEX. Unique request ID: 30 | 2023-11-22 20:52:44.882
Removing historical data download ID 30. | 2023-11-22 20:52:44.882
Real-time Intraday chart data file updates started for CLF24-NYMEX | 2023-11-22 20:52:44.882
Intraday chart data file opened for CLF24-NYMEX | 2023-11-22 20:52:44.882
HD Request # 30 | Enabling Intraday chart updating for symbol. | 2023-11-22 20:52:44.882
Triggering next historical data download in queue. | 2023-11-22 20:52:44.882
HD Request # 31 | Downloading Intraday chart data for ESZ23-CME to the file ESZ23-CME.scid. Service: cme | 2023-11-22 20:52:44.882
HD Request # 31 | Download start date-time: 2023-11-22 19:51:26.000000. File last date-time: 2023-11-22 19:51:26.215000 | 2023-11-22 20:52:44.883
HD Request # 31 | Using server: ds28.sierracharts.com port 10149 | 2023-11-22 20:52:44.883
Socket (2) | Creating socket. | 2023-11-22 20:52:44.883
Socket (2) | New receive buffer size: 0 | 2023-11-22 20:52:44.883
Socket (2) | Connecting to IP: 142.215.18.147. | 2023-11-22 20:52:44.883
Socket (3) | Socket gracefully closed by remote side. | 2023-11-22 20:52:44.998
Socket (3) | Closed. | 2023-11-22 20:52:44.998
HD Request # 31 | Setting DTC encoding to Binary VLS | 2023-11-22 20:52:45.146
HD Request # 31 | Sending historical data logon request message. | 2023-11-22 20:52:45.146
HD Request # 31 | Requesting Intraday data. Start date-time: 2023-11-22 19:51:26. Record interval: 0. Symbol: ESZ23 | 2023-11-22 20:52:45.484
HD Request # 31 | Decompressing data. | 2023-11-22 20:52:45.617
HD Request # 31 | Receiving Intraday data for ESZ23-CME starting at 2023-11-22 19:51:26.120000 | 2023-11-22 20:52:45.899
HD Request # 31 | Timestamp of first Intraday data file record written: 2023-11-22 19:51:26.345000. | 2023-11-22 20:52:46.307
Socket (2) | CloseSocket call. | 2023-11-22 20:52:46.552
Socket (2) | Shutdown started. Waiting for graceful close. | 2023-11-22 20:52:46.552
Historical data download thread signaled to stop. | 2023-11-22 20:52:46.552
HD Request # 31 | Received 62321 Intraday data records from 2023-11-22 19:51:26.120000 to 2023-11-22 20:42:45.341000 (51.3 minutes. Delay: 10.0 minutes) and wrote 62319 records for ESZ23-CME | 2023-11-22 20:52:46.553
HD Request # 31 | Add time&sales data | Remembered last file record date-time: 2023-11-22 20:42:45.341000 | 2023-11-22 20:52:46.569
HD Request # 31 | Completion time: 2s. | 2023-11-22 20:52:46.569
HD Request # 31 | Intraday data download complete for ESZ23-CME. Unique request ID: 31 | 2023-11-22 20:52:46.569
Removing historical data download ID 31. | 2023-11-22 20:52:46.569
Real-time Intraday chart data file updates started for ESZ23-CME | 2023-11-22 20:52:46.570
Intraday chart data file opened for ESZ23-CME | 2023-11-22 20:52:46.570
HD Request # 31 | Enabling Intraday chart updating for symbol. | 2023-11-22 20:52:46.570
Triggering next historical data download in queue. | 2023-11-22 20:52:46.570
HD Request # 32 | Downloading Intraday chart data for ESZ24-CME to the file ESZ24-CME.scid. Service: cme | 2023-11-22 20:52:46.570
HD Request # 32 | Download start date-time: 2023-11-20 20:01:35.000000. File last date-time: 2023-11-20 20:01:35.835000 | 2023-11-22 20:52:46.570
HD Request # 32 | Using server: ds27.sierracharts.com port 10150 | 2023-11-22 20:52:46.571
Socket (3) | Creating socket. | 2023-11-22 20:52:46.572
Socket (3) | New receive buffer size: 0 | 2023-11-22 20:52:46.572
Socket (3) | Connecting to IP: 38.89.227.130. | 2023-11-22 20:52:46.572
Socket (2) | Socket gracefully closed by remote side. | 2023-11-22 20:52:46.681
Socket (2) | Closed. | 2023-11-22 20:52:46.681
Opened cached Intraday file: C:\SierraChart\Data\ESZ23-CME.scid. Thread ID: 20552 | 2023-11-22 20:52:46.775
HD Request # 32 | Setting DTC encoding to Binary VLS | 2023-11-22 20:52:46.839
HD Request # 32 | Sending historical data logon request message. | 2023-11-22 20:52:46.839
HD Request # 32 | Requesting Intraday data. Start date-time: 2023-11-20 20:01:35. Record interval: 0. Symbol: ESZ24 | 2023-11-22 20:52:47.226
HD Request # 32 | Decompressing data. | 2023-11-22 20:52:47.356
HD Request # 32 | Receiving Intraday data for ESZ24-CME starting at 2023-11-20 20:01:35.835000 | 2023-11-22 20:52:47.485
Socket (3) | CloseSocket call. | 2023-11-22 20:52:47.485
Socket (3) | Shutdown started. Waiting for graceful close. | 2023-11-22 20:52:47.486
Historical data download thread signaled to stop. | 2023-11-22 20:52:47.486
HD Request # 32 | Received 1 Intraday data record from 2023-11-20 20:01:35.835000 to 2023-11-20 20:01:35.835000 (0.0 seconds. Delay: 2.0 days) and wrote 0 records for ESZ24-CME | 2023-11-22 20:52:47.486
HD Request # 32 | Add time&sales data | Remembered last file record date-time: 2023-11-20 20:01:35.835000 | 2023-11-22 20:52:47.487
HD Request # 32 | Completion time: 1s. | 2023-11-22 20:52:47.487
HD Request # 32 | Intraday data download complete for ESZ24-CME. Unique request ID: 32 | 2023-11-22 20:52:47.487
Removing historical data download ID 32. | 2023-11-22 20:52:47.487
Real-time Intraday chart data file updates started for ESZ24-CME | 2023-11-22 20:52:47.487
Intraday chart data file opened for ESZ24-CME | 2023-11-22 20:52:47.487
HD Request # 32 | Enabling Intraday chart updating for symbol. | 2023-11-22 20:52:47.487
No download requests in the queue to start downloads for. | 2023-11-22 20:52:47.487
Socket (3) | Socket gracefully closed by remote side. | 2023-11-22 20:52:47.616
Socket (3) | Closed. | 2023-11-22 20:52:47.616
Opened cached Intraday file: C:\SierraChart\Data\CLF24-NYMEX.scid. Thread ID: 20552 | 2023-11-22 20:52:55.330
Opened cached Intraday file: C:\SierraChart\Data\10YX23-CBOT.scid. Thread ID: 20552 | 2023-11-22 20:53:34.328
ESZ23-CME[M] 5 Min #2 | Reloading chart. | 2023-11-22 21:02:01.259
ESZ23-CME[M] 10 Min #5 | Reloading chart. | 2023-11-22 21:02:30.517
[2023-11-22 22:04:22]
John - SC Support - Posts: 36286
Your Footprint charts are blank because you are not on the correct package to be able to use them. You need to be on one of the "Advanced" packages to be able to use the Numbers Bars. Refer to the information at the following link:
Description of Service Packages and Pricing: Integrated Packages
To change your Sierra Chart Service Package, select "Help >> Account Control Panel" on the Sierra Chart program menu. On the displayed webpage, click on the "Set Service Package for Renewal" link.
Or go to this page:
https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation
You will need to login if you are not currently logged in.
In the "Available Services >> Choose Usage Time Service Package" frame, select the Service Package that you want to set your account to. Press the "Set" button.
The remaining service usage time on your account will be adjusted based upon the cost of the package you are changing to. If the new package is a higher-priced package, then the usage time will be reduced due to the higher price.
There is no charge for changing your Sierra Chart service package. Only your Sierra Chart account usage time ending date is adjusted.
When changing between Sierra Chart Service Packages, the usage time ending date on your Sierra Chart account is adjusted based upon the price differences between the package you are changing from and the package you are changing to.
When changing to a higher priced package, your usage time ending date will be brought back closer in time. When changing to a lower-priced package, your usage time ending date will be brought forward further out in time.
