Date/Time: Tue, 26 Nov 2024 12:20:17 +0000
VAH and VAL is different
View Count: 390
[2023-11-22 19:56:37] |
User285770 - Posts: 41 |
hello I having problems with the TPO My VAH and VAL is different from the other people in my trading group, It's more lower, like in the example I sent. How to fix it? I have attached here my TPO and the same TPO of one of the people in the group. thank you and have a good day :) Date Time Of Last Edit: 2023-11-22 20:07:06
WhatsApp Image 2023-11-22 at 19.00.51_22e0fc03.jpg / V - Attached On 2023-11-22 20:06:48 UTC - Size: 265.19 KB - 70 views WhatsApp Image 2023-11-22 at 19.01.43_878218a6.jpg / V - Attached On 2023-11-22 20:06:57 UTC - Size: 90.9 KB - 62 views |
[2023-11-22 20:11:37] |
John - SC Support - Posts: 36286 |
There are any number of reason why the TPOs would look different, including all of the Inputs for the TPO and how they are setup, as well as whether you are using the same data feed or not. But, one thing we can see offhand is that the Session Times between the two systems are different. The image with "This is My TPO" has TPOs starting at 09:30 and 16:15. The other image shows TPOs that start at 09:30 and 18:00. You would need to look through the above, along with the Chart Settings, data feed, etc. to determine why there is a difference. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-11-23 10:47:48] |
I opened the chartbook of one of the people in the group in my Sierra software, the chartbook with all its settings, and the same problem continues.... So WE can understand that it has nothing to do with the settings Is there another way to solve this? |
[2023-11-25 03:40:13] |
Sierra_Chart Engineering - Posts: 17179 |
Here is all of the information about this subject: Time Price Opportunity (TPO) Profile Charts: Incorrect Value Area or Point of Control Values Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
