Date/Time: Tue, 26 Nov 2024 13:21:50 +0000
No daily data update from yesterday
View Count: 249
[2023-11-22 09:39:41] |
User560799 - Posts: 2 |
I receive no daily data update (from yesterday) for US stocks. Reload & Recalculate function neither solve it. When I switch to intraday chart I get intraday data updates. However, it won't work on daily charts. My problem refers only to US stock markets, daily updates from other markets (NYMEX, COMEX) are ok. |
[2023-11-22 14:41:48] |
Sierra_Chart Engineering - Posts: 17179 |
Follow the instructions here to download historical daily data manually: Downloading Historical Daily Data: Manual Download And check the time for downloading historical daily data and make sure it is set correctly: Downloading Historical Daily Data: Automatic Download Make sure it is set to the default as specified. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-11-22 14:41:57
[2023-11-22 16:21:11] |
Thank you. It works for a single chart. Is there a way to automatize it? Eg. per chartbook? I've got over 100 charts to be updated manually :)
[2023-11-22 22:10:18] |
This is from the documentation we linked to: To download Historical Daily data for all Historical charts you have currently open in all open Chartbooks, select Edit >> Download Data For All Historical Charts on the menu.
