Date/Time: Tue, 26 Nov 2024 13:33:54 +0000
the chartbook is not compatible
View Count: 195
[2023-11-21 17:34:11] |
User953820 - Posts: 1 |
i tried to install a chartbook but i got a message log the chartbook file is not compatible
[2023-11-21 17:42:29] |
John - SC Support - Posts: 36286 |
Refer to the following: Chartbooks (Workspaces): Opening Older Chartbooks For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
