Date/Time: Tue, 26 Nov 2024 11:54:28 +0000
Spreadsheet for Trading - issue with Order Quantity
View Count: 297
[2023-11-21 17:10:24] |
nikos - Posts: 23 |
Good morning! I recently encountered an issue with the quantity in my automatic trading system that I had put up using a spreadsheet. When the trade fires for whatever reason, the quantity and the target are altered, even though I have the quantity set to 2 (in the spreadsheet as well). Please find attached the chartbook for your reference. Please check Monday, November 20, 22:23 Athens Greek time. thank you |
Private File Private File Private File |
[2023-11-22 19:14:50] |
nikos - Posts: 23 |
I tried to erase and download data for the Sympol with no luck. Please advise Date Time Of Last Edit: 2023-11-22 19:17:16
before firing the trade.PNG / V - Attached On 2023-11-22 19:17:02 UTC - Size: 132.19 KB - 62 views after firing the trade.PNG / V - Attached On 2023-11-22 19:17:11 UTC - Size: 114.91 KB - 64 views |
[2023-11-27 18:28:23] |
nikos - Posts: 23 |
I had to go back to 2516 to resolve this issue. @Sierrachart, did you have the chance to look at the OP? Thanks |
[2023-11-28 04:31:57] |
Sierra_Chart Engineering - Posts: 17179 |
We will check this as soon as possible.
[2023-12-01 20:45:38] |
We have looked into this. In the Spreadsheet System for Trading study Inputs, set this one to No: "Use Column I and J Values Version 2" And set this one to Yes: "Clear Unused Column I Names"; And then verify that all the values in the J column on the sheet used for trading, are as you intend. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-12-01 20:45:58
