Date/Time: Tue, 26 Nov 2024 13:25:33 +0000
This SC Video is Not Working
View Count: 223
[2023-11-21 16:53:27] |
User429065 - Posts: 118 |
"Download Video: Activating Service Package and Making a Payment." Clicking directly starts off good then garbles. The downloaded version has no sound. Please advise thank you!
[2023-11-21 17:02:56] |
John - SC Support - Posts: 36286 |
We are not seeing any issue with this ourselves. It is working perfectly fine, both the version in the browser and the downloaded version. We tried multiple players for the downloaded version and they all worked fine for us. So we are not sure why you would be having an issue with this. For what it is worth, the downloaded file is a .mpeg, so make sure you have the correct extension and that the player you are using can play this kind of file (although nearly all should). For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-11-21 21:21:33] |
Sierra_Chart Engineering - Posts: 17179 |
Are you playing the video in a browser? Try using VLC. The top of the video page has a link to VLC.: Video Library Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
