Date/Time: Mon, 25 Nov 2024 05:11:04 +0000
[Programming Help] - Full Recalculation Detection
View Count: 270
[2023-11-20 16:27:39]
WarriorTrader - Posts: 245
Is there a way to determine in ACSIL when a chart has been tagged for recalculation?
Chart #15 has tagged chart #6 for full recalculation. Chartbook: DayTrade_ES_CQG.Cht
My chartbook uses a ton of remote drawing tools so there are a lot of recalculations when my chartbook opens. This has never been a problem till recently.
SC behavior has somehow changed. Studies that have run for many years are now getting random CPU exceptions:
Warning: The Custom DLL study "BreakoutColoring_64.scsf_BreakoutColoring" has just caused a CPU exception. | 2023-11-20 10:34:23.478 *
It is not completely random, and I can get everything running if a close and open the chartbook 7 to 10 times. I finally get lucky somehow.
I suspect it may have to do with all the recalculations, but I can't be sure.
I would like a study to return if a chart it is referencing is in the middle of a recalculation. Is there a function for this?
I am also getting the following error in the message log, but don't know if it is related because things do run without any CPU Exceptions with the error present:
Chart #8 | Base Graph ID: 0 DateTime: Out of bounds array error at Index 0 | 2023-11-20 10:34:24.905
Thx,
WT
I am running SC version 2543 Revision 47486
[2024-03-27 15:26:32]
gtaranti - Posts: 67
I asked the same question in another thread : Prevent Recalculation | Post: 377288
