Date/Time: Sun, 08 Sep 2024 00:42:27 +0000
template issue
View Count: 181
[2023-11-20 15:35:15] |
User335972 - Posts: 2 |
iam having a problem with my template icant apply my template on chart. it says its not compaitable pls help
[2023-11-20 22:03:15] |
If this is a Chartbook that you can not open, then refer to the following: Chartbooks (Workspaces): Opening Older Chartbooks If this is a Study Collection, then attach the study collection to this thread and we will take a look and see if we can get it to work. Refer to the following for how to attach a file: https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
