Date/Time: Mon, 16 Sep 2024 19:20:14 +0000
Unable to process orders on EUREX products
View Count: 211
[2023-11-20 11:15:17] |
mikecap87 - Posts: 1 |
Hello, I have today enabled EUREX EOBI, I have your Denali feed and Teton order routing through my broker AMP, but I have been unable to place any orders on any EUREX instruments, I have tried the micro and mini dax. Up until today I have had zero issues with cme order placement so it seems for some reason that EUREX is not working. (many months ago I was successfully placing EUREX orders, but I used to have CQG order routing) I am attaching a screenshot of the error code Many thanks, I look forward to your reply. Mike |
[2023-11-20 14:46:49] |
Sierra_Chart Engineering - Posts: 16387 |
You need to use CQG for EUREX trading. Use one installation of Sierra Chart with Teton order routing for CME. Use another installation of Sierra Chart for CQG. Instructions: Using Multiple Data and Trading Services at the Same Time Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
