Date/Time: Tue, 26 Nov 2024 13:22:04 +0000
[User Discussion] - draw style issue
View Count: 240
[2023-11-20 10:31:39]
User278398 - Posts: 291
with spreadsheet formula study i got many result that are true.
i want for each true, to get "line" which his length will be depend the "width/size".
today i need to do many "spreadsheet formula" study, with "square" at the "draw style", and for each "square" at "spreadsheet formula" i need to change the "displacement" to get what i need...
(i also mange to get with one "spreadsheet formula" by "bar bottom" at the "draw style" and changing the "width/size" , but i don't want to see all this bar)
what is the right way to do it?
** i uploaded pic that display 10 spread sheet formula that i made to get the "line" that i want (the blue line, which is built from 10 square)
thank you
image1.png / V - Attached On 2023-11-20 10:29:28 UTC - Size: 68.23 KB - 81 views
[2023-11-20 14:48:55]
Sierra_Chart Engineering - Posts: 17179
Sorry you are over your limit with support. This is not within the scope of our support anyway.
[2023-11-20 15:12:55]
do u tell me that i cant ask any more technical question ?
