Date/Time: Mon, 16 Sep 2024 19:52:07 +0000
failed to connect to my rithmic account
View Count: 294
[2023-11-20 05:27:14] |
Rogers - Posts: 23 |
Reading Internal Order ID file. | 2023-11-19 23:45:54.837 Reading Trade Orders file. | 2023-11-19 23:45:54.875 Reading Trade Positions file. | 2023-11-19 23:45:54.880 Reading Trade Account Data files. | 2023-11-19 23:45:54.885 Software version: 2504 64-bit | 2023-11-19 23:45:54.891 Primary Thread ID: 11952 | 2023-11-19 23:45:54.891 Usage end date: 2023-12-18 | 2023-11-19 23:45:54.891 Enabled for: Advanced Features 2. | 2023-11-19 23:45:54.891 Enabled for: Sierra Chart Historical Data Service. | 2023-11-19 23:45:54.891 Enabled for: Denali Real-Time Exchange Data Feed. | 2023-11-19 23:45:54.891 Enabled for: Delayed Denali Exchange Data Feed. | 2023-11-19 23:45:54.891 Enabled for exchange2: CME (Trading Account Required) | 2023-11-19 23:45:54.891 Enabled for exchange2: CBOT (Trading Account Required) | 2023-11-19 23:45:54.891 Enabled for exchange2: COMEX (Trading Account Required) | 2023-11-19 23:45:54.891 Enabled for exchange2: NYMEX (Trading Account Required) | 2023-11-19 23:45:54.891 Allow Support for Sierra Chart Data Feeds is enabled. | 2023-11-19 23:45:54.891 Current selected Data/Trading service: Teton CME Order Routing | 2023-11-19 23:45:54.891 Custom symbol settings values: enabled | 2023-11-19 23:45:54.891 Chart Update Interval: 500 | 2023-11-19 23:45:54.891 Intraday Data Storage Time Unit: 1 | 2023-11-19 23:45:54.891 Time Zone: -05:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2023-11-19 23:45:54.891 2023-11-20 04:45:54 Local computer time in UTC | 2023-11-19 23:45:54.891 2023-11-19 23:45:54 Local computer time in SC Time Zone | 2023-11-19 23:45:54.891 2023-11-20 04:45:53 Server time in UTC | 2023-11-19 23:45:54.891 Local computer UTC time and Server UTC time difference: 0 seconds. | 2023-11-19 23:45:54.891 Program path: C:\SierraChart\ | 2023-11-19 23:45:54.891 Data Files path: C:\SierraChart\Data\ | 2023-11-19 23:45:54.891 OS Version Number: 10.0 | 2023-11-19 23:45:54.891 Locale Setting: C | 2023-11-19 23:45:54.891 DLLs: UserContributedStudies_64.dll | 2023-11-19 23:45:54.893 Allowed protected custom studies: | 2023-11-19 23:45:54.893 Crash reporter started: true | 2023-11-19 23:45:54.893 Rithmic Direct - DTC | Using server connection: | 2023-11-20 00:09:59.036 Rithmic Direct - DTC | Remote address is not set. | 2023-11-20 00:09:59.036 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-11-20 00:09:59.036 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:09:59.036 DTC Client socket (0) | CloseSocket call. | 2023-11-20 00:09:59.051 Rithmic Direct - DTC | Disconnected. | 2023-11-20 00:09:59.051 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:09:59.051 Rithmic Direct - DTC | Using server connection: | 2023-11-20 00:10:03.048 Rithmic Direct - DTC | Remote address is not set. | 2023-11-20 00:10:03.048 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-11-20 00:10:03.048 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:10:03.048 DTC Client socket (0) | CloseSocket call. | 2023-11-20 00:10:03.063 Rithmic Direct - DTC | Disconnected. | 2023-11-20 00:10:03.063 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:10:03.063 Rithmic Direct - DTC | Using server connection: | 2023-11-20 00:10:07.075 Rithmic Direct - DTC | Remote address is not set. | 2023-11-20 00:10:07.076 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-11-20 00:10:07.076 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:10:07.076 DTC Client socket (0) | CloseSocket call. | 2023-11-20 00:10:07.091 Rithmic Direct - DTC | Disconnected. | 2023-11-20 00:10:07.091 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:10:07.091 Rithmic Direct - DTC | Using server connection: | 2023-11-20 00:10:11.090 Rithmic Direct - DTC | Remote address is not set. | 2023-11-20 00:10:11.090 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-11-20 00:10:11.090 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:10:11.090 DTC Client socket (0) | CloseSocket call. | 2023-11-20 00:10:11.105 Rithmic Direct - DTC | Disconnected. | 2023-11-20 00:10:11.105 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:10:11.105 Rithmic Direct - DTC | Using server connection: | 2023-11-20 00:10:15.107 Rithmic Direct - DTC | Remote address is not set. | 2023-11-20 00:10:15.107 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-11-20 00:10:15.107 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:10:15.107 DTC Client socket (0) | CloseSocket call. | 2023-11-20 00:10:15.122 Rithmic Direct - DTC | Disconnected. | 2023-11-20 00:10:15.122 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:10:15.122 Rithmic Direct - DTC | Using server connection: | 2023-11-20 00:10:19.125 Rithmic Direct - DTC | Remote address is not set. | 2023-11-20 00:10:19.125 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-11-20 00:10:19.125 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:10:19.125 DTC Client socket (0) | CloseSocket call. | 2023-11-20 00:10:19.140 Rithmic Direct - DTC | Disconnected. | 2023-11-20 00:10:19.140 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:10:19.140 Rithmic Direct - DTC | Using server connection: | 2023-11-20 00:10:23.154 Rithmic Direct - DTC | Remote address is not set. | 2023-11-20 00:10:23.154 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-11-20 00:10:23.154 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:10:23.154 DTC Client socket (0) | CloseSocket call. | 2023-11-20 00:10:23.176 Rithmic Direct - DTC | Disconnected. | 2023-11-20 00:10:23.176 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:10:23.177 Rithmic Direct - DTC | Using server connection: | 2023-11-20 00:10:27.191 Rithmic Direct - DTC | Remote address is not set. | 2023-11-20 00:10:27.191 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-11-20 00:10:27.191 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:10:27.191 DTC Client socket (0) | CloseSocket call. | 2023-11-20 00:10:27.205 Rithmic Direct - DTC | Disconnected. | 2023-11-20 00:10:27.206 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:10:27.206 Rithmic Direct - DTC | Using server connection: | 2023-11-20 00:10:31.205 Rithmic Direct - DTC | Remote address is not set. | 2023-11-20 00:10:31.205 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-11-20 00:10:31.205 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:10:31.205 DTC Client socket (0) | CloseSocket call. | 2023-11-20 00:10:31.220 Rithmic Direct - DTC | Disconnected. | 2023-11-20 00:10:31.220 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:10:31.220 Rithmic Direct - DTC | Using server connection: | 2023-11-20 00:10:35.233 Rithmic Direct - DTC | Remote address is not set. | 2023-11-20 00:10:35.233 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-11-20 00:10:35.233 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:10:35.233 DTC Client socket (0) | CloseSocket call. | 2023-11-20 00:10:35.249 Rithmic Direct - DTC | Disconnected. | 2023-11-20 00:10:35.249 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:10:35.249 Rithmic Direct - DTC | Using server connection: | 2023-11-20 00:10:39.263 Rithmic Direct - DTC | Remote address is not set. | 2023-11-20 00:10:39.263 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-11-20 00:10:39.263 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:10:39.263 DTC Client socket (0) | CloseSocket call. | 2023-11-20 00:10:39.278 Rithmic Direct - DTC | Disconnected. | 2023-11-20 00:10:39.278 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:10:39.278 Rithmic Direct - DTC | Using server connection: | 2023-11-20 00:10:43.282 Rithmic Direct - DTC | Remote address is not set. | 2023-11-20 00:10:43.282 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-11-20 00:10:43.282 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:10:43.282 DTC Client socket (0) | CloseSocket call. | 2023-11-20 00:10:43.297 Rithmic Direct - DTC | Disconnected. | 2023-11-20 00:10:43.297 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:10:43.297 Rithmic Direct - DTC | Using server connection: | 2023-11-20 00:10:47.285 Rithmic Direct - DTC | Remote address is not set. | 2023-11-20 00:10:47.285 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-11-20 00:10:47.285 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:10:47.285 DTC Client socket (0) | CloseSocket call. | 2023-11-20 00:10:47.300 Rithmic Direct - DTC | Disconnected. | 2023-11-20 00:10:47.300 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:10:47.300 Rithmic Direct - DTC | Using server connection: | 2023-11-20 00:10:51.300 Rithmic Direct - DTC | Remote address is not set. | 2023-11-20 00:10:51.300 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-11-20 00:10:51.300 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:10:51.300 DTC Client socket (0) | CloseSocket call. | 2023-11-20 00:10:51.316 Rithmic Direct - DTC | Disconnected. | 2023-11-20 00:10:51.316 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:10:51.316 Rithmic Direct - DTC | Using server connection: | 2023-11-20 00:10:55.330 Rithmic Direct - DTC | Remote address is not set. | 2023-11-20 00:10:55.330 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-11-20 00:10:55.330 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:10:55.330 DTC Client socket (0) | CloseSocket call. | 2023-11-20 00:10:55.346 Rithmic Direct - DTC | Disconnected. | 2023-11-20 00:10:55.346 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:10:55.346 Rithmic Direct - DTC | Using server connection: | 2023-11-20 00:10:59.349 Rithmic Direct - DTC | Remote address is not set. | 2023-11-20 00:10:59.349 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-11-20 00:10:59.349 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:10:59.349 DTC Client socket (0) | CloseSocket call. | 2023-11-20 00:10:59.365 Rithmic Direct - DTC | Disconnected. | 2023-11-20 00:10:59.365 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:10:59.365 Rithmic Direct - DTC | Using server connection: | 2023-11-20 00:11:03.378 Rithmic Direct - DTC | Remote address is not set. | 2023-11-20 00:11:03.378 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-11-20 00:11:03.378 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:11:03.378 DTC Client socket (0) | CloseSocket call. | 2023-11-20 00:11:03.394 Rithmic Direct - DTC | Disconnected. | 2023-11-20 00:11:03.394 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:11:03.395 Rithmic Direct - DTC | Using server connection: | 2023-11-20 00:11:07.382 Rithmic Direct - DTC | Remote address is not set. | 2023-11-20 00:11:07.382 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-11-20 00:11:07.382 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:11:07.382 DTC Client socket (0) | CloseSocket call. | 2023-11-20 00:11:07.397 Rithmic Direct - DTC | Disconnected. | 2023-11-20 00:11:07.398 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:11:07.398 Rithmic Direct - DTC | Using server connection: | 2023-11-20 00:11:11.397 Rithmic Direct - DTC | Remote address is not set. | 2023-11-20 00:11:11.397 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-11-20 00:11:11.397 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:11:11.397 DTC Client socket (0) | CloseSocket call. | 2023-11-20 00:11:11.413 Rithmic Direct - DTC | Disconnected. | 2023-11-20 00:11:11.413 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:11:11.413 Rithmic Direct - DTC | Using server connection: | 2023-11-20 00:11:15.428 Rithmic Direct - DTC | Remote address is not set. | 2023-11-20 00:11:15.428 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-11-20 00:11:15.428 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:11:15.428 DTC Client socket (0) | CloseSocket call. | 2023-11-20 00:11:15.444 Rithmic Direct - DTC | Disconnected. | 2023-11-20 00:11:15.444 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:11:15.444 Socket (1) | Timed out waiting for shutdown. Performing an immediate socket close. | 2023-11-20 00:11:17.003 Socket (1) | Closed. | 2023-11-20 00:11:17.004 Rithmic Direct - DTC | Using server connection: | 2023-11-20 00:11:19.443 Rithmic Direct - DTC | Remote address is not set. | 2023-11-20 00:11:19.443 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-11-20 00:11:19.443 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:11:19.443 DTC Client socket (0) | CloseSocket call. | 2023-11-20 00:11:19.458 Rithmic Direct - DTC | Disconnected. | 2023-11-20 00:11:19.458 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:11:19.458 Rithmic Direct - DTC | Using server connection: | 2023-11-20 00:11:23.460 Rithmic Direct - DTC | Remote address is not set. | 2023-11-20 00:11:23.460 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-11-20 00:11:23.460 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:11:23.460 DTC Client socket (0) | CloseSocket call. | 2023-11-20 00:11:23.475 Rithmic Direct - DTC | Disconnected. | 2023-11-20 00:11:23.475 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:11:23.475 Rithmic Direct - DTC | Using server connection: | 2023-11-20 00:11:27.475 Rithmic Direct - DTC | Remote address is not set. | 2023-11-20 00:11:27.475 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-11-20 00:11:27.475 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:11:27.475 DTC Client socket (0) | CloseSocket call. | 2023-11-20 00:11:27.490 Rithmic Direct - DTC | Disconnected. | 2023-11-20 00:11:27.490 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:11:27.491 Rithmic Direct - DTC | Using server connection: | 2023-11-20 00:11:31.499 Rithmic Direct - DTC | Remote address is not set. | 2023-11-20 00:11:31.499 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-11-20 00:11:31.499 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:11:31.499 DTC Client socket (0) | CloseSocket call. | 2023-11-20 00:11:31.511 Rithmic Direct - DTC | Disconnected. | 2023-11-20 00:11:31.511 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:11:31.511 Rithmic Direct - DTC | Using server connection: | 2023-11-20 00:11:35.518 Rithmic Direct - DTC | Remote address is not set. | 2023-11-20 00:11:35.518 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-11-20 00:11:35.518 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:11:35.518 DTC Client socket (0) | CloseSocket call. | 2023-11-20 00:11:35.524 Rithmic Direct - DTC | Disconnected. | 2023-11-20 00:11:35.524 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:11:35.524 Rithmic Direct - DTC | Using server connection: | 2023-11-20 00:11:39.531 Rithmic Direct - DTC | Remote address is not set. | 2023-11-20 00:11:39.531 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-11-20 00:11:39.531 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:11:39.531 DTC Client socket (0) | CloseSocket call. | 2023-11-20 00:11:39.553 Rithmic Direct - DTC | Disconnected. | 2023-11-20 00:11:39.554 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:11:39.554 Rithmic Direct - DTC | Using server connection: | 2023-11-20 00:11:43.556 Rithmic Direct - DTC | Remote address is not set. | 2023-11-20 00:11:43.556 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-11-20 00:11:43.556 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:11:43.556 DTC Client socket (0) | CloseSocket call. | 2023-11-20 00:11:43.566 Rithmic Direct - DTC | Disconnected. | 2023-11-20 00:11:43.567 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:11:43.567 Socket (1) | Deleting network socket now after delay. | 2023-11-20 00:11:47.008 Rithmic Direct - DTC | Using server connection: | 2023-11-20 00:11:47.580 Rithmic Direct - DTC | Remote address is not set. | 2023-11-20 00:11:47.580 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-11-20 00:11:47.580 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:11:47.580 DTC Client socket (0) | CloseSocket call. | 2023-11-20 00:11:47.595 Rithmic Direct - DTC | Disconnected. | 2023-11-20 00:11:47.595 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:11:47.595 Rithmic Direct - DTC | Using server connection: | 2023-11-20 00:11:51.584 Rithmic Direct - DTC | Remote address is not set. | 2023-11-20 00:11:51.584 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-11-20 00:11:51.584 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:11:51.584 DTC Client socket (0) | CloseSocket call. | 2023-11-20 00:11:51.599 Rithmic Direct - DTC | Disconnected. | 2023-11-20 00:11:51.599 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:11:51.599 Rithmic Direct - DTC | Using server connection: | 2023-11-20 00:11:55.599 Rithmic Direct - DTC | Remote address is not set. | 2023-11-20 00:11:55.599 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-11-20 00:11:55.599 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:11:55.599 DTC Client socket (0) | CloseSocket call. | 2023-11-20 00:11:55.615 Rithmic Direct - DTC | Disconnected. | 2023-11-20 00:11:55.615 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:11:55.615 Rithmic Direct - DTC | Using server connection: | 2023-11-20 00:11:59.632 Rithmic Direct - DTC | Remote address is not set. | 2023-11-20 00:11:59.632 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-11-20 00:11:59.632 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:11:59.632 DTC Client socket (0) | CloseSocket call. | 2023-11-20 00:11:59.647 Rithmic Direct - DTC | Disconnected. | 2023-11-20 00:11:59.647 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:11:59.647 Rithmic Direct - DTC | Using server connection: | 2023-11-20 00:12:03.648 Rithmic Direct - DTC | Remote address is not set. | 2023-11-20 00:12:03.648 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-11-20 00:12:03.648 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:12:03.648 DTC Client socket (0) | CloseSocket call. | 2023-11-20 00:12:03.663 Rithmic Direct - DTC | Disconnected. | 2023-11-20 00:12:03.663 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:12:03.663 Rithmic Direct - DTC | Using server connection: | 2023-11-20 00:12:07.666 Rithmic Direct - DTC | Remote address is not set. | 2023-11-20 00:12:07.666 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-11-20 00:12:07.666 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:12:07.666 DTC Client socket (0) | CloseSocket call. | 2023-11-20 00:12:07.681 Rithmic Direct - DTC | Disconnected. | 2023-11-20 00:12:07.681 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:12:07.681 Rithmic Direct - DTC | Using server connection: | 2023-11-20 00:12:11.683 Rithmic Direct - DTC | Remote address is not set. | 2023-11-20 00:12:11.683 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-11-20 00:12:11.683 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:12:11.683 DTC Client socket (0) | CloseSocket call. | 2023-11-20 00:12:11.698 Rithmic Direct - DTC | Disconnected. | 2023-11-20 00:12:11.698 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:12:11.698 Rithmic Direct - DTC | Using server connection: | 2023-11-20 00:12:15.698 Rithmic Direct - DTC | Remote address is not set. | 2023-11-20 00:12:15.698 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-11-20 00:12:15.698 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:12:15.698 DTC Client socket (0) | CloseSocket call. | 2023-11-20 00:12:15.714 Rithmic Direct - DTC | Disconnected. | 2023-11-20 00:12:15.714 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:12:15.714 Rithmic Direct - DTC | Using server connection: | 2023-11-20 00:12:19.722 Rithmic Direct - DTC | Remote address is not set. | 2023-11-20 00:12:19.722 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-11-20 00:12:19.722 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:12:19.722 DTC Client socket (0) | CloseSocket call. | 2023-11-20 00:12:19.741 Rithmic Direct - DTC | Disconnected. | 2023-11-20 00:12:19.741 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:12:19.741 Rithmic Direct - DTC | Using server connection: | 2023-11-20 00:12:23.769 Rithmic Direct - DTC | Remote address is not set. | 2023-11-20 00:12:23.769 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-11-20 00:12:23.769 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:12:23.769 DTC Client socket (0) | CloseSocket call. | 2023-11-20 00:12:23.783 Rithmic Direct - DTC | Disconnected. | 2023-11-20 00:12:23.784 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:12:23.784 Rithmic Direct - DTC | Using server connection: | 2023-11-20 00:12:27.781 Rithmic Direct - DTC | Remote address is not set. | 2023-11-20 00:12:27.781 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-11-20 00:12:27.781 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:12:27.781 DTC Client socket (0) | CloseSocket call. | 2023-11-20 00:12:27.797 Rithmic Direct - DTC | Disconnected. | 2023-11-20 00:12:27.797 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:12:27.797 Rithmic Direct - DTC | Using server connection: | 2023-11-20 00:12:31.798 Rithmic Direct - DTC | Remote address is not set. | 2023-11-20 00:12:31.798 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-11-20 00:12:31.798 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:12:31.798 DTC Client socket (0) | CloseSocket call. | 2023-11-20 00:12:31.814 Rithmic Direct - DTC | Disconnected. | 2023-11-20 00:12:31.814 Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:12:31.814 Rithmic Direct - DTC | Using server connection: | 2023-11-20 00:12:35.814 Rithmic Direct - DTC | Remote address is not set. | 2023-11-20 00:12:35.814 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-11-20 00:12:35.814 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:12:35.814 DTC Client socket (0) | CloseSocket call. | 2023-11-20 00:12:35.829 Rithmic Direct - DTC | Disconnected. | 2023-11-20 00:12:35.829 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:12:35.829 HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (1) | Creating socket. Using TLS 1.2. | 2023-11-20 00:12:55.814 HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (1) | New receive buffer size: 32768 | 2023-11-20 00:12:55.814 HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (1) | Connecting to IP: 38.79.0.89. | 2023-11-20 00:12:55.814 HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (1) | Socket gracefully closed by remote side. | 2023-11-20 00:12:57.310 HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (1) | CloseSocket call. | 2023-11-20 00:12:57.318 HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-20 00:12:57.319 HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (1) | Closed. | 2023-11-20 00:12:57.319 Rithmic Direct - DTC | Using server connection: | 2023-11-20 00:13:30.032 Rithmic Direct - DTC | Remote address is not set. | 2023-11-20 00:13:30.032 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-11-20 00:13:30.032 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:13:30.032 DTC Client socket (0) | CloseSocket call. | 2023-11-20 00:13:30.045 Rithmic Direct - DTC | Disconnected. | 2023-11-20 00:13:30.045 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:13:30.045 HTTPS connection ID:4 to www.rithmic.com:443 for request ID:4 (1) | Creating socket. Using TLS 1.2. | 2023-11-20 00:13:50.032 HTTPS connection ID:4 to www.rithmic.com:443 for request ID:4 (1) | New receive buffer size: 32768 | 2023-11-20 00:13:50.033 HTTPS connection ID:4 to www.rithmic.com:443 for request ID:4 (1) | Connecting to IP: 38.79.0.89. | 2023-11-20 00:13:50.033 HTTPS connection ID:4 to www.rithmic.com:443 for request ID:4 (1) | Socket gracefully closed by remote side. | 2023-11-20 00:13:51.536 HTTPS connection ID:4 to www.rithmic.com:443 for request ID:4 (1) | CloseSocket call. | 2023-11-20 00:13:51.540 HTTPS connection ID:4 to www.rithmic.com:443 for request ID:4 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-20 00:13:51.540 HTTPS connection ID:4 to www.rithmic.com:443 for request ID:4 (1) | Closed. | 2023-11-20 00:13:51.540 Rithmic Direct - DTC | Using server connection: | 2023-11-20 00:15:30.041 Rithmic Direct - DTC | Remote address is not set. | 2023-11-20 00:15:30.041 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-11-20 00:15:30.041 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:15:30.041 DTC Client socket (0) | CloseSocket call. | 2023-11-20 00:15:30.057 Rithmic Direct - DTC | Disconnected. | 2023-11-20 00:15:30.058 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:15:30.058 HTTPS connection ID:5 to www.rithmic.com:443 for request ID:5 (1) | Creating socket. Using TLS 1.2. | 2023-11-20 00:15:50.049 HTTPS connection ID:5 to www.rithmic.com:443 for request ID:5 (1) | New receive buffer size: 32768 | 2023-11-20 00:15:50.050 HTTPS connection ID:5 to www.rithmic.com:443 for request ID:5 (1) | Connecting to IP: 38.79.0.89. | 2023-11-20 00:15:50.050 HTTPS connection ID:5 to www.rithmic.com:443 for request ID:5 (1) | Socket gracefully closed by remote side. | 2023-11-20 00:15:51.545 HTTPS connection ID:5 to www.rithmic.com:443 for request ID:5 (1) | CloseSocket call. | 2023-11-20 00:15:51.550 HTTPS connection ID:5 to www.rithmic.com:443 for request ID:5 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-20 00:15:51.550 HTTPS connection ID:5 to www.rithmic.com:443 for request ID:5 (1) | Closed. | 2023-11-20 00:15:51.550 Rithmic Direct - DTC | Using server connection: | 2023-11-20 00:17:30.066 Rithmic Direct - DTC | Remote address is not set. | 2023-11-20 00:17:30.066 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-11-20 00:17:30.066 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:17:30.066 DTC Client socket (0) | CloseSocket call. | 2023-11-20 00:17:30.081 Rithmic Direct - DTC | Disconnected. | 2023-11-20 00:17:30.081 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:17:30.081 HTTPS connection ID:6 to www.rithmic.com:443 for request ID:6 (1) | Creating socket. Using TLS 1.2. | 2023-11-20 00:17:50.065 HTTPS connection ID:6 to www.rithmic.com:443 for request ID:6 (1) | New receive buffer size: 32768 | 2023-11-20 00:17:50.066 HTTPS connection ID:6 to www.rithmic.com:443 for request ID:6 (1) | Connecting to IP: 38.79.0.89. | 2023-11-20 00:17:50.066 HTTPS connection ID:6 to www.rithmic.com:443 for request ID:6 (1) | Socket gracefully closed by remote side. | 2023-11-20 00:17:51.552 HTTPS connection ID:6 to www.rithmic.com:443 for request ID:6 (1) | CloseSocket call. | 2023-11-20 00:17:51.555 HTTPS connection ID:6 to www.rithmic.com:443 for request ID:6 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-20 00:17:51.555 HTTPS connection ID:6 to www.rithmic.com:443 for request ID:6 (1) | Closed. | 2023-11-20 00:17:51.555 Rithmic Direct - DTC | Using server connection: | 2023-11-20 00:19:30.078 Rithmic Direct - DTC | Remote address is not set. | 2023-11-20 00:19:30.078 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-11-20 00:19:30.078 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:19:30.078 DTC Client socket (0) | CloseSocket call. | 2023-11-20 00:19:30.093 Rithmic Direct - DTC | Disconnected. | 2023-11-20 00:19:30.093 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:19:30.093 HTTPS connection ID:7 to www.rithmic.com:443 for request ID:7 (1) | Creating socket. Using TLS 1.2. | 2023-11-20 00:19:50.112 HTTPS connection ID:7 to www.rithmic.com:443 for request ID:7 (1) | New receive buffer size: 32768 | 2023-11-20 00:19:50.112 HTTPS connection ID:7 to www.rithmic.com:443 for request ID:7 (1) | Connecting to IP: 38.79.0.89. | 2023-11-20 00:19:50.112 HTTPS connection ID:7 to www.rithmic.com:443 for request ID:7 (1) | Socket gracefully closed by remote side. | 2023-11-20 00:19:51.859 HTTPS connection ID:7 to www.rithmic.com:443 for request ID:7 (1) | CloseSocket call. | 2023-11-20 00:19:51.862 HTTPS connection ID:7 to www.rithmic.com:443 for request ID:7 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-20 00:19:51.862 HTTPS connection ID:7 to www.rithmic.com:443 for request ID:7 (1) | Closed. | 2023-11-20 00:19:51.863 Rithmic Direct - DTC | Using server connection: | 2023-11-20 00:21:30.087 Rithmic Direct - DTC | Remote address is not set. | 2023-11-20 00:21:30.087 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-11-20 00:21:30.087 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:21:30.087 DTC Client socket (0) | CloseSocket call. | 2023-11-20 00:21:30.102 Rithmic Direct - DTC | Disconnected. | 2023-11-20 00:21:30.102 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:21:30.102 HTTPS connection ID:8 to www.rithmic.com:443 for request ID:8 (1) | Creating socket. Using TLS 1.2. | 2023-11-20 00:21:50.090 HTTPS connection ID:8 to www.rithmic.com:443 for request ID:8 (1) | New receive buffer size: 32768 | 2023-11-20 00:21:50.090 HTTPS connection ID:8 to www.rithmic.com:443 for request ID:8 (1) | Connecting to IP: 38.79.0.89. | 2023-11-20 00:21:50.090 HTTPS connection ID:8 to www.rithmic.com:443 for request ID:8 (1) | Socket gracefully closed by remote side. | 2023-11-20 00:21:51.586 HTTPS connection ID:8 to www.rithmic.com:443 for request ID:8 (1) | CloseSocket call. | 2023-11-20 00:21:51.591 HTTPS connection ID:8 to www.rithmic.com:443 for request ID:8 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-20 00:21:51.591 HTTPS connection ID:8 to www.rithmic.com:443 for request ID:8 (1) | Closed. | 2023-11-20 00:21:51.591 Rithmic Direct - DTC | Using server connection: | 2023-11-20 00:23:30.112 Rithmic Direct - DTC | Remote address is not set. | 2023-11-20 00:23:30.112 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-11-20 00:23:30.112 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:23:30.112 DTC Client socket (0) | CloseSocket call. | 2023-11-20 00:23:30.127 Rithmic Direct - DTC | Disconnected. | 2023-11-20 00:23:30.127 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:23:30.127 HTTPS connection ID:9 to www.rithmic.com:443 for request ID:9 (1) | Creating socket. Using TLS 1.2. | 2023-11-20 00:23:50.112 HTTPS connection ID:9 to www.rithmic.com:443 for request ID:9 (1) | New receive buffer size: 32768 | 2023-11-20 00:23:50.112 HTTPS connection ID:9 to www.rithmic.com:443 for request ID:9 (1) | Connecting to IP: 38.79.0.89. | 2023-11-20 00:23:50.112 HTTPS connection ID:9 to www.rithmic.com:443 for request ID:9 (1) | Socket gracefully closed by remote side. | 2023-11-20 00:23:51.604 HTTPS connection ID:9 to www.rithmic.com:443 for request ID:9 (1) | CloseSocket call. | 2023-11-20 00:23:51.605 HTTPS connection ID:9 to www.rithmic.com:443 for request ID:9 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-20 00:23:51.606 HTTPS connection ID:9 to www.rithmic.com:443 for request ID:9 (1) | Closed. | 2023-11-20 00:23:51.606 The message log has been sent to support. | 2023-11-20 00:24:10.962 * HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Creating socket. Using TLS 1.2. | 2023-11-20 00:24:10.962 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | New receive buffer size: 32768 | 2023-11-20 00:24:10.962 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Connecting to IP: 162.251.232.252. | 2023-11-20 00:24:10.962 The Message Log was sent. Result: Message Log received. | 2023-11-20 00:24:13.331 * HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | CloseSocket call. | 2023-11-20 00:24:13.578 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2023-11-20 00:24:13.578 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2023-11-20 00:24:13.579 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Closed. | 2023-11-20 00:24:13.579 Rithmic Direct - DTC | Using server connection: | 2023-11-20 00:25:30.145 Rithmic Direct - DTC | Remote address is not set. | 2023-11-20 00:25:30.145 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-11-20 00:25:30.145 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:25:30.145 DTC Client socket (0) | CloseSocket call. | 2023-11-20 00:25:30.163 Rithmic Direct - DTC | Disconnected. | 2023-11-20 00:25:30.163 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-11-20 00:25:30.163 HTTPS connection ID:10 to www.rithmic.com:443 for request ID:10 (1) | Creating socket. Using TLS 1.2. | 2023-11-20 00:25:50.145 HTTPS connection ID:10 to www.rithmic.com:443 for request ID:10 (1) | New receive buffer size: 32768 | 2023-11-20 00:25:50.146 HTTPS connection ID:10 to www.rithmic.com:443 for request ID:10 (1) | Connecting to IP: 38.79.0.89. | 2023-11-20 00:25:50.146 HTTPS connection ID:10 to www.rithmic.com:443 for request ID:10 (1) | Socket gracefully closed by remote side. | 2023-11-20 00:25:51.831 HTTPS connection ID:10 to www.rithmic.com:443 for request ID:10 (1) | CloseSocket call. | 2023-11-20 00:25:51.833 HTTPS connection ID:10 to www.rithmic.com:443 for request ID:10 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-11-20 00:25:51.834 HTTPS connection ID:10 to www.rithmic.com:443 for request ID:10 (1) | Closed. | 2023-11-20 00:25:51.834 Date Time Of Last Edit: 2023-11-20 14:57:45
[2023-11-20 14:57:09] |
Sierra_Chart Engineering - Posts: 16387 |
There is no server set for connection: Rithmic Direct - DTC | Using server connection: | 2023-11-20 00:23:30.112
Follow the Rithmic set up instructions here: Rithmic Trading Platform Service: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
