Date/Time: Tue, 26 Nov 2024 12:18:36 +0000
Label column not working, in Manual Looping mode.
View Count: 377
[2023-11-20 01:12:08]
KylieV1618 - Posts: 67
I have some code that draws important levels, that I changed from AutoLoop, to ManualLoop.
But when I choose "Label" for the Name column, for any of the subgraphs, they no longer show up in the DOM/Label column
It worked before in AutoLoop though. So I thought it might be an indexing issue or something.
But the Name works and shows on the Chart, if I use any other setting, except `Label`.
So that means the last index has the correct Value.
Switching to Manual Looping is the only thing I can think of that surfaced this bug?
Any ideas on why that could happen in Manual looping versus AutoLooping?
Date Time Of Last Edit: 2023-11-20 01:17:11
[2023-11-20 15:14:50]
Sierra_Chart Engineering - Posts: 17179
We would not know without in-depth debugging which we do not do.
Enable the labels directly within the Study Subgraphs tab:
Chart Studies: Subgraphs Tab >> Name and Value Labels
Date Time Of Last Edit: 2023-11-20 15:15:14
[2023-11-20 20:00:10]
Yeah, Ive done that, but they dont show specifically only in the DOM column.
Its pretty strange.
Cuz they show up everywhere else. (LEFT, RIGHT, RIGHT EDGE etc)
Its an interesting bug for sure. Considering it was working before I switched to manual looping.
So it was specifically that switch that screwed it up.
All the code is identical. All that changed was switching `sc.Index` to `index` for most everything, and `sc.AutoLoop = 0`
Switching it back, makes them work again.
Its not a huge deal, I can just use auto loop, but I wanted to be more efficient.
But also....figured you might know of some code reason why this bug would exist?
Date Time Of Last Edit: 2023-11-20 20:03:02
[2023-11-24 21:46:03]
What Study Subgraph Draw Style is being used?
Refer to the documentation here for whatever you are using:
ACSIL Interface Members - sc.Subgraph Array: sc.Subgraph[].DrawStyle
