Date/Time: Tue, 26 Nov 2024 13:50:42 +0000
Support for more than 200 alerts
View Count: 220
[2023-11-19 21:54:31] |
User594974 - Posts: 34 |
Believe it or not, I have a need for more than 200 alerts. I'm creating alerts based on different products/timeframes and want to create a specific alert for each. Is there a possibility to raise this limit to, say, 500. It's tedious, but it's a need that would benefit me significantly. Thank you! Cheers, |
[2023-11-20 15:08:59] |
Sierra_Chart Engineering - Posts: 17179 |
You can develop your own custom solution using ACSIL: Table of Contents | (Advanced Custom Study/System Interface and Language (ACSIL)) You can play your own alert sound file from ACSIL: sc.PlaySound() Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
