Date/Time: Tue, 15 Apr 2025 14:37:58 +0000
Trial activation
View Count: 685
[2023-11-19 20:19:25]
User542528 - Posts: 2
I cannot type in the box that says (button) under the SMS number with country code. It will not let me highlight or click in the box so I can’t input my phone number to activate the trial account. I have tried two computers and still the box will not highlight or let me type. Can you activate my trail?
[2023-11-19 23:08:41]
Sierra_Chart Engineering - Posts: 19229
Your account has been activated and the usage time extended if necessary.
If Sierra Chart is running, it will automatically be activated within about three minutes. However, you may need to exit from the Sierra Chart charting and trading software by selecting "File >> Exit". And then open Sierra Chart through the icon on your desktop or through the desktop Start menu.
After your Sierra Chart usage time ends you need to pay for additional usage time through "Help >> Add Usage Credit".
To get started with Sierra Chart, follow the Sierra Chart setup instructions here:
Sierra Chart Setup Instructions 1
[2023-11-26 03:39:49]
User996503 - Posts: 15
Can you activate my account? I can not activate it.
[2023-11-26 05:21:49]
[2023-11-27 02:01:08]
User379759 - Posts: 1
[2023-11-27 02:28:26]
[2024-02-25 21:10:11]
User201372 - Posts: 2
can you activate my trial plz
[2024-02-25 21:45:53]
At this time you do not have a trial. You are using Service Package 3.
Let us know what issue you are having if any?
[2024-02-26 13:53:29]
NoobTrader - Posts: 1
already sent the sms for trial activation 2 days ago and still didnt receive my activation code. please help
[2024-02-26 17:40:50]
John - SC Support - Posts: 39275
NoobTrader:
We have activated the trial for your account.
[2024-03-21 08:17:41]
User761023 - Posts: 1
How do i know the trial is active? In 'account management', next to 'current service program' it says 'trail package' with a timer above it. I assume this is the indicator.
[2024-03-21 15:52:04]
User761023:
Yes, that is correct place to look. If you have an activated trial, it would state "Trial Package (Activated)".
[2024-03-29 22:08:25]
Superscalp611441 - Posts: 2
same problem help please
[2024-03-30 05:10:50]
Your Sierra Chart account currently has 52 days of usage time . It is no longer a trial.
Date Time Of Last Edit: 2024-03-30 05:10:55
[2025-04-02 16:40:26]
User311108 - Posts: 1
can you activate my trial. It says that its no longer possible to activate a trial, but i just created the account, and have never used sierra chart before
[2025-04-02 17:21:48]
There is no special activation that has to take place for a trial. Your account is setup for the trial at this time. Refer to the following for what data is available while on a trial:
Sierra Chart Trial Account
And refer to the following for getting started with Sierra Chart:
Getting Started, Opening Charts and Basic Trading
