Date/Time: Tue, 26 Nov 2024 06:55:15 +0000
VX SPreads
View Count: 467
[2023-11-18 16:34:13]
User841161 - Posts: 221
I see where VX future outrights are availale to be charted under Futures-CFE. There are exchange traded spreads on the VX products, but do not see where they are available under this area. Can they be found somewhere else?
[2023-11-21 18:05:53]
Sierra_Chart Engineering - Posts: 17179
You just need to follow the instructions here to get a listing of the spreads:
Real-Time Exchange Data Feeds Available From Sierra Chart: Exchange Traded Spreads
Date Time Of Last Edit: 2023-11-21 18:05:59
[2023-11-30 02:27:56]
VX spreads are not listed like other future products are.
imageVX 11-29-23.PNG / V - Attached On 2023-11-30 02:27:36 UTC - Size: 35.26 KB - 79 views
[2023-12-01 16:54:50]
You need to left click on the Get Symbols button.
Date Time Of Last Edit: 2023-12-01 16:54:59
[2023-12-04 01:26:40]
Doesn't Get to Spreads when I do that.
[2023-12-04 01:35:15]
What happens is another window will display, listing all of the spread symbols and even the outright contracts as well.
You do not see that? Just give it about 10 seconds but it should come much faster.
Date Time Of Last Edit: 2023-12-04 01:35:21
[2023-12-04 15:40:54]
Just shows Outright symbols, no spreads.. Here is picture of what is on screen after hitting left clicking Get Symbols.
imageVX 12-4-23.PNG / V - Attached On 2023-12-04 15:40:27 UTC - Size: 36.92 KB - 63 views
[2023-12-04 17:53:31]
John - SC Support - Posts: 36286
When you select the "Get Symbols" button, at the top of the "Find Symbols" page you should see the text "Requesting additional symbols" show. Are you seeing this text?
[2023-12-04 18:11:14]
Requesting additional symbols flashes up there for a milisecond, barely saw it. Doesn't add any symbols additionally.
[2023-12-04 18:15:27]
Please get us your Message Log by following these instructions:
[2023-12-04 18:45:25]
Software version: 2564 64-bit | 2023-12-04 12:43:20.106
Primary Thread ID: 24416 | 2023-12-04 12:43:20.106
Usage end date: 2023-12-25 | 2023-12-04 12:43:20.106
Enabled for: Advanced Features 2. | 2023-12-04 12:43:20.106
Enabled for: Sierra Chart Historical Data Service. | 2023-12-04 12:43:20.106
Enabled for: Denali Real-Time Exchange Data Feed. | 2023-12-04 12:43:20.106
Enabled for: Delayed Denali Exchange Data Feed. | 2023-12-04 12:43:20.106
Enabled for exchange2: CME (Trading Account Required) | 2023-12-04 12:43:20.106
Enabled for exchange2: CBOT (Trading Account Required) | 2023-12-04 12:43:20.106
Enabled for exchange2: COMEX (Trading Account Required) | 2023-12-04 12:43:20.106
Enabled for exchange2: NYMEX (Trading Account Required) | 2023-12-04 12:43:20.106
Enabled for exchange2: NASDAQ Global Indexes | 2023-12-04 12:43:20.106
Allow Support for Sierra Chart Data Feeds is enabled. | 2023-12-04 12:43:20.106
Current selected Data/Trading service: DTC - Sub Instance | 2023-12-04 12:43:20.106
Custom symbol settings values: disabled | 2023-12-04 12:43:20.106
Chart Update Interval: 500 | 2023-12-04 12:43:20.106
Intraday Data Storage Time Unit: 0 | 2023-12-04 12:43:20.106
Time Zone: -06:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2023-12-04 12:43:20.106
2023-12-04 18:43:20 Local computer time in UTC | 2023-12-04 12:43:20.106
2023-12-04 12:43:20 Local computer time in SC Time Zone | 2023-12-04 12:43:20.106
2023-12-04 14:27:27 Server time in UTC | 2023-12-04 12:43:20.106
Local computer UTC time and Server UTC time difference: 0 seconds. | 2023-12-04 12:43:20.106
Program path: C:\SierraChart\SierraChartInstance_2\ | 2023-12-04 12:43:20.106
Data Files path: C:\SierraChart\SierraChartInstance_2\Data\ | 2023-12-04 12:43:20.106
OS Version Number: 10.0 | 2023-12-04 12:43:20.106
Locale Setting: C | 2023-12-04 12:43:20.106
DLLs: AMTBalance_64.dll, AMT_BuySell_Pressure_64.dll, AMT_Collection_64.dll, AMT_Delta_64.dll, AMT_Multi_TimeFrame_Signals_64.dll, AMT_TheBalanceMethod_64.dll, AMT_TradeTrailingStops_64.dll, AMT_TrailingOrders_64.dll, BuySellPressure_64.dll, CoT_64.dll, DarvasTP_64.dll, DDT_64.dll, DeltaPivotPoints_64_2 (1).dll, DeltaPivotPoints_64_2.dll, GoogleSheetsImporter_64.dll, HausBalance_64.dll, HausDelta_64.dll, HausFVG_64.dll, HausMovingAverages_64.dll, HausTradesV7_64.dll, HausTradeTrailingStops_64.dll, HighVAP-0.4g_64.dll | 2023-12-04 12:43:20.107
Allowed protected custom studies: Analytical Market Theory, Haus Trades, SST_FreeBundle, TWFX_Free | 2023-12-04 12:43:20.107
Crash reporter started: true | 2023-12-04 12:43:20.107
DTC - Sub Instance | Sent symbols for underlying request to server. Underlying: VX | 2023-12-04 12:43:37.512
DTC - Sub Instance | Security Definition request has been rejected. Reason: SecurityType not specified. ID = 100000090 | 2023-12-04 12:43:37.516
[2023-12-19 19:51:35]
anything more on this?
[2023-12-19 20:02:50]
Please try to get the spreads in the main instance and not in a Sub-Instance and let us know if it works or not.
[2023-12-20 06:13:06]
Yes, that appears to have worked, I have spreads listed now after hitting Get Symbols Tab. Didn't know you had to do it under the main instance?
[2023-12-27 04:46:14]
Getting a list of symbols in the sub instance in this particular type of scenario, will be supported in the next release.
