Date/Time: Wed, 27 Nov 2024 02:40:30 +0000
Are Indian NSE symbols supported through Interactive broker connection
View Count: 1131
[2014-07-24 05:32:59] |
User22099 - Posts: 8 |
Are Indian NSE symbols supported through Interactive broker connection if yes then how to go about setting them
[2014-07-24 07:45:50] |
Yes they are. You just need to manually enter the symbols through the File >> Find Symbol >> Selected Symbol box following the symbol formats documented here: http://www.sierrachart.com/index.php?page=doc/IBSymbols.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-07-24 07:46:10
