Date/Time: Tue, 26 Nov 2024 15:45:33 +0000
[Programming Help] - How To Set Bar Period Parameters For A Chart The Study Is Not On
View Count: 188
[2023-11-17 18:09:33]
Richard Chinn - Posts: 28
Is there a way to set bar period parameters for charts in the same chartbook as my study chart using ANCIL?
I have five charts that I open from my study on chart one with sc.OpenChartOrGetChartReference.
I open them with the correct bar period parameters.
My study checks to make sure the bar period parameters have not been changed, specifically the bar period length.
I do this by using sc.GetBarPeriodParametersForChart
I store the value for bar period length, example: rBarPeriod.IntradayChartBarPeriodParameter1 = 300
This does not update the bar period parameters though.
I don't see a function, sc.SetBarPeriodParametersForChart to use in conjunction with sc.GetBarPeriodParametersForChart.
Is there another way to update bar period parameters for a specified chart?
