Date/Time: Tue, 26 Nov 2024 15:27:04 +0000
How to Install fresh copy of Sierra and retain charts and custom codes
View Count: 250
[2023-11-17 17:47:00] |
User360283 - Posts: 504 |
My old PC is broken so I have purchased a new one. I need to install a fresh copy of Sierra but I MUST retain my current charts and custom alerts and custom programs. How do I safely do this? Details please Thanks |
[2023-11-17 18:58:41] |
John - SC Support - Posts: 36294 |
That information only exists on your old computer - unless you have made backups of the information. If you can access the drive from the old computer, then you should be able to get the information from it, but this is something you would need to work out - we can not help with this part of it. The general instructions to copy the information from one installation to another is at the following link: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
