Date/Time: Tue, 26 Nov 2024 15:48:57 +0000
[User Discussion] - Feature Request: Native Boolean buttons
View Count: 315
[2023-11-17 15:37:17] |
User233953 - Posts: 6 |
Hello! Please consider adding a true/false boolean button as native study. Example: User adds the Button study, ID1.SG1, if button is pressed then ID1.SG1 = 1, else 0. User can modify both the text (and formula) of button. User can set the chart region on the button, perhaps also axis location (similar to a text display). Secondary, adding the same thing but to a spreadsheet, if performance isn't significantly reduced. User Right-clicks a cell - such as in the static H column - and they can add a button to that cell. This would reduce the current cell modification mouse/keyboard clicks count from 4 to 1, that's very significant, since another study/cell could reference the boolean value the user no longer needs multiple clicks to quick switch a parameter. Thank you for considering, much appreciated. Ziggy Date Time Of Last Edit: 2023-11-17 16:05:54
[2023-11-17 16:20:30] |
User278450 - Posts: 4 |
I can image a lot of uses for this. This sounds like a really good idea.
