Date/Time: Tue, 26 Nov 2024 15:30:29 +0000
Volume by price not working?
View Count: 275
[2023-11-17 12:39:26]
Kmiller90 - Posts: 7
Unable to modify Volume Graph Period Type after multiple attempts. The setting is stuck on One Period At end of fix time length and I'm unable to remove it. Whenever I attempt to modify to the multiple profiles settings, it immediately switches back to the previous setting. I restarted, disconnected and reconnected, reset defaults, deleted the volume by price study and even created a new chart, nothing is working. I never had an issue changing this setting and need assistance.
[2023-11-17 15:16:26]
Sierra_Chart Engineering - Posts: 17181
Should not be any problem with this.
Are you adding the Volume by Price study to a Trading DOM?
[2023-11-17 15:23:58]
Well unfortunately I’m having an issue with this now. No I’m not adding to a Dom just my regular candle stick charts, I’ve never had an issue with it until now. Already checked for updates, What are your suggestions since this doesn’t seem like a common issue?
Date Time Of Last Edit: 2023-11-17 15:44:23
[2023-11-17 17:25:46]
John - SC Support - Posts: 36295
Please get us that chart by following these instructions:
