Date/Time: Tue, 26 Nov 2024 15:29:16 +0000
How to make to use both brokers?
View Count: 225
[2023-11-17 12:04:10] |
User716459 - Posts: 127 |
Can I have at the same time Sierra Chart for contract trading, as before - AMP broker, with all settings, and 2nd for stocks - Interactive? I don't want to connect Sierra to Interactive, losing settings and connection with Amp. How to make to use both brokers? Please give me a quick answer, thank you. A |
[2023-11-17 17:19:28] |
John - SC Support - Posts: 36294 |
You need to install a second Sierra Chart. You will want to do this on the same computer - as long as you have the two installations on the same computer there are no additional fees. Refer to the following for instructions to install a second Sierra Chart: Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
