Date/Time: Tue, 26 Nov 2024 15:25:17 +0000
[Programming Help] - sumproduct issue and depend bartime
View Count: 275
[2023-11-17 10:22:16]
User278398 - Posts: 291
hello,
im trying to sum the last 60 last bars and which start from bartime=1
for exa:
if the value for all bars are "1"
so:
at 9:30:00 the value will be: 1
at 9:30:01 the value will be: 2
at 9:30:59 the value will be: 60
at 9:31:00 the value will be: 1
at 9:31:01 the value will be: 2
maybe for an ideas:
im using sumproduct formula
and second(bartime)>0,second(bartime)<60
but i didnt get the right values :(
what is the solution by formula?
thank you
[2023-11-20 06:56:00]
some one ?
