Date/Time: Tue, 26 Nov 2024 15:48:54 +0000
Open Spreadsheet Error
View Count: 242
[2023-11-17 07:52:27] |
Sierra_Chart Engineering - Posts: 17182 |
Is it actually a text file? Is the character encoding ASCII? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-11-17 14:34:00] |
netxqy - Posts: 4 |
Hello, I use the menu, File >>> Open Spreadsheet, "File Type" select "Comma Separated Values (*.csv)" Open a file named Data.csv. It's a text file. Encoding is ASCII. The content of the Data.csv file is as follows. A,1,10.1 B,2,20.2 An error occurred. "Error reading the spreadsheet file. The file type is not supported. A new spreadsheet will be created." Could you please tell me how to solve this problem? Thank you very much for your help. Date Time Of Last Edit: 2023-11-17 14:34:45
Data.csv - Attached On 2023-11-17 14:33:47 UTC - Size: 18 B - 209 views |
[2023-11-17 14:43:45] |
The fields need to be tab delimited. Not comma delimited. And also the text editor we use shows that the encoding was UTF-8. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
