Date/Time: Tue, 22 Apr 2025 02:18:37 +0000
Recent bid/ask volume tick compression on DOM
View Count: 905
[2023-11-16 20:44:04]
Dersy2000 - Posts: 1
Hi I know there is the function to compress market depth on the dom, but is there a way to currently do that to other trade dom columns such as the recent bid/ask volume. Currently if you compress market depth and price from 1 tick to 4 ticks or a point on NQ price and market depth will be correct but the recent bid/ask column will still display all 4 ticks of information and it’s unreadable. If this is something that isn’t currently available is it something that you plan to implement in the near future? Thank you
Date Time Of Last Edit: 2023-11-16 20:44:38
[2023-11-17 16:28:23]
John - SC Support - Posts: 39395
It is something we are working on, but we can not say when we will have it available.
[2024-01-03 11:23:00]
jakeybleez - Posts: 56
hi john, was seeing if this is available yet?
[2024-01-03 15:31:28]
Sierra_Chart Engineering - Posts: 19290
No, but we will get to it as soon as we can. Allow about two weeks.
[2024-02-26 13:55:42]
NQSlayer95 - Posts: 2
Has this been implemented? I would love this feature as well.
[2024-02-26 17:42:33]
The ability to have the "Recent Bid/Ask" columns consolidated in the same way as the Bid/Ask Market Depth columns has been available for a few months now. Refer to the following setting for this:
Chart Settings: Apply Combine Increment in Ticks to Other Market Data Columns (Chart >> Chart Settings >> Market Depth menu)
[2025-02-07 14:19:06]
User987628 - Posts: 1
I think that I got everything changed correctly for the bid/ask, but I still have some columns that show the 0.25 ticks. Is there a way to change these as well?
imageScreenshot 2025-02-07 081757.png / V - Attached On 2025-02-07 14:18:19 UTC - Size: 347.92 KB - 49 views
[2025-02-07 16:24:36]
Only the "Bid/Ask" and "Recent Bid/Ask" columns have the ability to consolidate the data at this time.
