Date/Time: Tue, 26 Nov 2024 14:36:38 +0000
extension lines forward lock fill space
View Count: 211
[2023-11-16 13:08:32] |
User278398 - Posts: 291 |
hello, im using "color bar based on alert condition" study and i cant draw "extension lines at color bar value" after the lock fill space. 1.there is away to do it? 2. there is away to do it but not to the end of the window? thank you |
[2023-11-16 19:09:24] |
John - SC Support - Posts: 36287 |
There is not a built-in way to do this for the Extension Lines. You could create a custom study to do this, or have a programmer do it for you. Refer to the following: How to Build an Advanced Custom Study from Source Code https://www.sierrachart.com/index.php?page=doc/SierraChartStudyAndSystemProgrammers.php For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
