Date/Time: Tue, 26 Nov 2024 14:44:53 +0000
display the second highest maximum volume- 2 pocat the same bar
View Count: 215
[2023-11-16 07:38:38]
User278398 - Posts: 291
hello,
i'm using "volume point of control for bars" study to find POC at every bar.
how can i get at the same bar the next maximum volume (the maximum volume which is before the really maximum volume)?
for exa:in the pic i display the "volume point of control for bars" study by the yellow dash.
in the last bar the vpoc is ~242.9$(and let suppose the volume there i 100K).
and at the blue dash which i draw, (what i want to get automatically) at 249.96$ is the next maximum value at that bar (next max volume after the real vpoc, 90K).
thank you.
image1.png / V - Attached On 2023-11-16 07:27:34 UTC - Size: 78.97 KB - 61 views
[2023-11-16 18:51:19]
John - SC Support - Posts: 36288
You would have to build a custom study to do this. You can start with the "Volume Point of Control for Bars" code, which is available in the Studies2.cpp file in the ACS_Source folder under your main Sierra Chart folder. Refer to the following:
How to Build an Advanced Custom Study from Source Code
Or refer to the list of programmers at the following link:
List of Third Party Sierra Chart Study and System Programmers
