Date/Time: Tue, 26 Nov 2024 14:36:37 +0000
ES and NQ on different charts
View Count: 314
[2023-11-16 02:40:55] |
Trevtratta - Posts: 7 |
Hello is there a way to have NQ and ES on different charts without having to switch Chartbooks. Whenever I go to Find Symbol and change the symbol on one chart it changes all of my other charts to that symbol when I only wanted to change that single chart. I also don't want ES and NQ on the same chart via the add additional symbol on studies.
[2023-11-16 04:59:35] |
Sierra_Chart Engineering - Posts: 17179 |
Yes of course. You just simply open two separate charts. One for each. This is all. And make sure you are not using Chart Linking and linking the symbol, in either of those charts: Working With Charts: Chart Linking Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-11-16 04:59:52
