Date/Time: Tue, 26 Nov 2024 06:27:43 +0000
Not getting live data
View Count: 283
[2023-11-15 15:26:56] |
Satyam_1 - Posts: 12 |
hello i am not getting any price movement or data in XAUUSD. Kindly help
[2023-11-15 15:43:56] |
John - SC Support - Posts: 36286 |
That data comes directly from FXCM, so if there is an issue, it means that there was a problem with FXCM sending the data. We just checked this symbol and we are seeing the data flow just fine. Let us know if you are still having a problem with this data. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-11-15 16:07:51] |
Sierra_Chart Engineering - Posts: 17179 |
Refer to help topic 3: Intraday Chart or Chart Bars Not Updating | Blank Intraday Chart | "Currently no data to display" message for Intraday Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-12-26 02:25:08] |
HELLO can you tell me why i am not getting fee for XAUUSD?
[2023-12-26 02:49:30] |
The CFD data comes from FXCM and they are not providing any data at this time. Instead of XAUUSD use this symbol: GCG24_COMEX Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-12-26 02:49:55
