Date/Time: Tue, 26 Nov 2024 14:51:48 +0000
Does "Make Backup" stores Study Collections as well?
View Count: 237
[2023-11-15 11:30:43] |
funbun - Posts: 90 |
It can't be seen in the created backup folder
[2023-11-15 17:42:50] |
Sierra_Chart Engineering - Posts: 17179 |
No, that command does not do this. Check the Backups folder for backups of study collections.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-11-15 17:43:02
