Date/Time: Tue, 26 Nov 2024 14:30:49 +0000
[Locked] - Some type of an error
View Count: 227
[2023-11-15 09:21:35]
User740709 - Posts: 153
Please find attached a screenshot.
This is VbP study, set to show 1 day back for reference (yesterday), showing only Valleys and until future intersection.
The screenshot shows there there are lines for valleys that do not end with intersection.
Could you please have a look?
Huge thanks!
Kind regards,
H.
Date Time Of Last Edit: 2023-11-15 09:21:48
imageVbP Valleys.png / V - Attached On 2023-11-15 09:21:04 UTC - Size: 164.35 KB - 61 views
[2023-11-15 16:17:36]
Sierra_Chart Engineering - Posts: 17179
Those lines are not going to end, in the day for which they are for. Only future days.
It is not possible for there to be in error here.
Date Time Of Last Edit: 2023-11-15 16:17:43
[2023-11-15 16:33:13]
Thank you.
OK, I understand.
So in order for the intersection work, I have to set "0" as the number of periods back to reference.
The problem then however is that the day contains the lines for valleys from the prior day untill it intersects them AS WELL AS newly created lines which is very confusing.
Is there any workaround?
Thank you.
Regards,
H.
Date Time Of Last Edit: 2023-11-15 16:37:50
[2023-11-15 18:14:45]
Just to let you know - I resolved the issue (issue for me) - I used another VbP study with the same setting but coloring the valley lines the same as background to cover the lines during the current developing session.
Thank you.
All the best,
H.
