Date/Time: Tue, 26 Nov 2024 14:41:28 +0000
custom time bars
View Count: 190
[2023-11-15 07:11:06] |
User14683 - Posts: 34 |
How do I create 8 hour bars that close at specific 8 hour time intervals? e.g. 7h00; 15h00, 23h00
[2023-11-15 16:09:20] |
Sierra_Chart Engineering - Posts: 17179 |
Refer to: Chart Session Times: Bar Starting Times You do not control the closing time but the starting time. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
