Date/Time: Tue, 26 Nov 2024 14:49:24 +0000
Cumulative Delta Bars - Study
View Count: 330
[2023-11-14 21:24:42] |
User664579 - Posts: 7 |
Dear Support Team, cumulative delta study displays different values of cumulative delta for the same symbol (MNQ in my case) on 2 tick charts. My undersnading is that it must show the same amount of cumulative delta. I am using the same settings for both charts (i.e. same session time and same reset settings for calculation). Attached is the screenshot for a better understanding of the issue. I am using cumulative delta to be displayed as a "line on close" - light blue line showed on the screenshot. As can be seen the top chart (set to 497 ticks on MNQ) is showing cumulative delta at around 5800 while the bottom chart set to 4000 ticks on MNQ) is showing cumulative delta at around 9600. |
[2023-11-14 21:27:37] |
Sierra_Chart Engineering - Posts: 17179 |
Refer to: Cumulative Delta Bars - Volume: Resolving Cumulative Delta Bars Differences And also refer to: Working With Charts: Resolving Differences of Chart Bars Between Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-11-15 15:45:49] |
Thanks a lot for a swift reply! The problem was due to the fact that I used 2 different sudies: 1 for Trades and 1 for Volume. |
