Date/Time: Tue, 26 Nov 2024 14:22:34 +0000
[User Discussion] - which Sierra Chart package to chose for mkt replay
View Count: 261
[2023-11-14 20:50:08] |
Schiavo - Posts: 1 |
Hi, hopefully someone could give me some directions as i am new to the platform. i have just started learning Sierra Chart because i urgently need to have a well functioning mkt replay simulator; later on i will consolidate my live trading in Sierra. My question is: is the Base Standard Sierra Chart package enough to do following (if not, which package?): KEEP in MIND I AM Referring TO trade in the replay mode: - intraday trading on price action - RTY, NQ, ES only markets i am trading - no DOM required - need to have time and tick charts - must have the ability to play replay working with multiple charts and multiple screens/monitors: this is a must have; - one year at least of price history in the replay charts. which vendor would u suggest for my data requirements? thanks ab |
[2023-11-15 17:00:07] |
John - SC Support - Posts: 36286 |
You can do all of this with the "Base Standard" package. Just keep in mind that your data will be "Delayed Streaming", so for the CME Group data, your data will be 10 minutes and 10 seconds behind the real-time data. But since you are only wanting this for replay - then this should not be an issue. We also recommend looking into our "Simulated Futures Trading Service" as a more realistic simulation environment, although this does not allow for trades during replay (for this you need to use the built-in Simulation Environment). Refer to the following: Simulated Futures Trading Service For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
