Date/Time: Tue, 26 Nov 2024 14:17:06 +0000
Spreadsheet data for Volume by Price Study
View Count: 299
[2023-11-14 11:03:36]
Blacklake - Posts: 3
When using the Volume by Price study, is there a way to access the trade weighted mean price field along with its standard deviation bands (SG12-SG16) in a spreadsheet. Currently the only fields that are generated by the study in a spreadsheet are SG3-SG5.
Thank you.
[2023-11-14 20:55:20]
Sierra_Chart Engineering - Posts: 17179
If they are Subgraphs, yes. What is the Draw Style of the Subgraphs?
Do you see values for them in the Chart Values window?:
Chart Drawing Tools: Viewing Tool and Chart Data When Using Tools
And make sure they are enabled to be outputted to the Spreadsheet:
Chart Studies: Subgraphs Tab >> Include in Spreadsheet
[2023-11-15 08:15:54]
Thanks for the response.
'Include in Spreadsheet' is ticked for all the subgraphs on the subgraph tab, and the draw style of the subgraphs in question are lines which are correctly outputted on the chart. The values are not visible in the Chart Values window or the spreadsheet. Resetting the study settings to default and adding a new study still only outputs the four subgraphs noted above (SG3-SG5: VPOC VAH VAL VWAP).
Other studies, for example a moving average, can reference the subgraphs in question (SG12-SG16) and output them to the spreadsheet, but they are not outputted to the spreadsheet by the VbP study itself.
Screenshots attached for reference.
Would appreciate any further help on this matter.
Thank you.
imageSpreadsheet Output.jpg / V - Attached On 2023-11-15 08:14:57 UTC - Size: 479.57 KB - 54 views
imageChart Values Window.jpg / V - Attached On 2023-11-15 08:15:06 UTC - Size: 169.24 KB - 53 views
imageSubgraph Settings.jpg / V - Attached On 2023-11-15 08:15:15 UTC - Size: 153.35 KB - 53 views
[2023-11-15 16:45:21]
John - SC Support - Posts: 36286
The Trade Weighted Mean Price and Standard Deviation Bands are not available in the Spreadsheet study from the Volume by Price study.
The only place to view/get this information is from the "Tool Values Window" after you have enabled the option in the Volume by Price study for "Calculate Mean Price and Standard Deviation Bands".
[2023-11-15 17:28:05]
Understood, thank you.
