Date/Time: Tue, 26 Nov 2024 15:40:16 +0000
[Programming Help] - VisualCCompile.Bat does not generate a DLL
View Count: 237
[2023-11-14 11:00:26]
User423915 - Posts: 15
I don't see any DLL file after running VisualCCompile.Bat, only a lib and exp file. It's the ExampleCustomStudies.cpp file that I've renamed and remote compile works so there should not be any problem with the code. I've updated the Visual C++ Compiler to the latest version.
C:\local\SierraChart\Data\my_acs_source>VisualCCompile.Bat
C:\local\SierraChart\Data\my_acs_source>call "C:\local\VisualStudio\2019\BuildTools\VC\Auxiliary\Build\vcvarsall.bat" amd64
** Visual Studio 2019 Developer Command Prompt v16.11.31
** Copyright (c) 2021 Microsoft Corporation
[vcvarsall.bat] Environment initialized for: 'x64'
Sbx1.cpp
Creating library Sbx1.lib and object Sbx1.exp
Generating code
Finished generating code
Any help is much appreciated!
[2023-11-14 16:00:56]
My bad, I see now that the lib and dll files end up in different places!
Another question: is it possible to have SC release DLL:s from the VisualCCompile.Bat file? It would make development soo much smoother!
