Date/Time: Tue, 26 Nov 2024 14:23:28 +0000
NDX-NQGI MARKET DEPTH
View Count: 342
[2023-11-14 09:49:20] |
Daniel Kilinskas - Posts: 2 |
Hi, I am looking to trade the NDX-NQGI using sierra chart and the real time data. The thing is that when I look into the depth of market and the footprint as well as the times and sales I receive only 1 contract traded each time while looking at the delay data of other symbols I can see more contracts traded at each price. Is it because I didn't select the right Denali Exchange Data Feed service or there is something else? Thanks a lot. |
[2023-11-14 14:54:34] |
Sierra_Chart Engineering - Posts: 17179 |
There is no market depth data for that symbol. You need to use NQ futures on the CME instead. You can find the symbols in: File >> Find Symbol >>Futures-CME. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-11-14 20:03:53] |
That explains a lot :D Thanks! |
