Date/Time: Tue, 26 Nov 2024 14:18:58 +0000
How to remove only latest order fill from the chart?
View Count: 313
[2023-11-13 19:02:40]
EugeneZ - Posts: 9
As the title states: How do I remove only latest order fill from the chart?
Here's a screenshot:
image13-11-2023-19-47-46.png / V - Attached On 2023-11-13 18:55:43 UTC - Size: 241.13 KB - 60 views
[2023-11-13 21:35:36]
Sierra_Chart Engineering - Posts: 17179
Uncheck this menu option:
Trade Menu: Show Order Fills (Trade menu)
It is either all or none. All or none, that is all.
[2023-11-14 18:52:25]
EugeneZ - Posts: 9
That would mean if I placed an order by mistake in a SIM mode and it is left on the chart, there would be no way to remove it from the chart, right?
[2023-11-15 04:59:19]
You can delete the order fill from the trade activity log:
Trade Activity Log: Trade Activity Data Editing Menu Commands (Trade >> Trade Activity Log)
[2023-11-15 06:05:07]
EugeneZ - Posts: 9
But if I delete a wrong order from the trade activity log, it will still remain on the chart?
[2023-11-15 06:42:11]
The order fill that you delete will be removed from the chart.
