Date/Time: Tue, 26 Nov 2024 15:40:08 +0000
volume chart
View Count: 252
[2023-11-13 11:43:37] |
nilahi - Posts: 8 |
Hello, I would like to insert such chart volume related to the time and not related to the price. exactly like the attached chart. could you please help me how could I add it, it is available in tradingview and I do belive as well it is available on sierrachart. Thank you in advance. Regards Nader |
vloumeTimeProfile.PNG / V - Attached On 2023-11-13 11:41:39 UTC - Size: 290.14 KB - 65 views Attachment Deleted. |
[2023-11-13 15:19:34] |
Tony - Posts: 518 |
That is also a Study/Indicator in Sierra Chart Analysis -> Studies, find "Volume" and "Add>>" |
[2023-11-13 17:25:48] |
Sierra_Chart Engineering - Posts: 17182 |
Use the Volume study: Volume Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-11-14 08:10:05] |
nilahi - Posts: 8 |
Thank you so much for your quick feedback! is there an idicator that shows the divergence between price and cumulative delta. in other words, sometime the price goes high while the cumulative delta is going down , I have watched that some Trader on Youtube use sierra chart with this indicator to spot that. the candle price is green and CD candle is red, and this indicator highlights that. Thank you so much in advance! |
