Date/Time: Tue, 26 Nov 2024 14:52:09 +0000
Different linked drawing position on graphs with different bars type
View Count: 296
[2023-11-13 10:51:38]
tokauo - Posts: 32
I have noticed that if I draw trend line on time based chart (for example weakly bars) and I link drawings to chart based on: Volume per bar, Range per bar, Reversal bar, line has displacement on that chart (if it is linked to time based chart it woks perfect).
Is it right behaviour?
Thanks you
Tom
[2023-11-14 17:24:13]
Sierra_Chart Engineering - Posts: 17179
Yes this makes sense.
Refer to:
Lines/Rays or Other Chart Drawings Move After Drawing Them
[2023-11-16 09:27:34]
tokauo - Posts: 32
That's really strange behaviour, if you take consider, how important/core function it is... :-/
Thanks you
[2023-11-16 14:52:54]
There is nothing strange at all. Chart Drawings are managed 100% perfectly.
[2023-11-16 16:05:40]
tokauo - Posts: 32
Thanks you
I my opinion, there are two explanation. First we have different view on what mean "perfect" or there is something wrong.
So, for to be sure, I made an screenshot of my two charts https://postimg.cc/qgntSJTx , left is one minute bars, right is 5 range (I have tried my best to catch very similar time and crosshair is synced).
This example doesn't have the biggest "gap" between line it usually has... so...
[2023-11-16 16:11:44]
Is this a Horizontal Line or a Line? What type of drawing is this. Is it a Ray?
[2023-11-16 16:27:25]
tokauo - Posts: 32
It is just Line (Alt 4)
[2023-11-16 17:05:20]
It is impossible for us to analyze this, with a screenshot which is not even clear. We would need to have the Chart/Chartbook itself. All we can say is the comprehensive information on the subject is here:
Date Time Of Last Edit: 2023-11-16 17:05:42
[2023-11-16 18:12:37]
tokauo - Posts: 32
Thanks you
Of course I have read this article... I have tried some suggestions from it, but... if I understand to it right, it is simply saying: "it is impossible, so get over it" :-) ... and if it is like that, than OK... but if not, here https://easyupload.io/rb354q is my Chartbook and I'll be glad if you check it, for an (user) errors.
Thanks you for your time
Date Time Of Last Edit: 2023-11-17 07:36:07
