Date/Time: Tue, 26 Nov 2024 15:26:42 +0000
No market block profile data
View Count: 168
[2023-11-13 10:41:10]
CoolioDaddiyo - Posts: 3
Hi, I'm getting the VWAP data coming through but not the profile data. This was working automatically when I was on the trial basis. I understand option 10 on the data services should allow me this information. I only need delayed data at this time. I have adjusted the tab need additional support services to now as shown
[2023-11-13 15:28:42]
Sierra_Chart Engineering - Posts: 17181
TPO profile charts are only supported with Service Package 5, 11 and 12.
We have given you access for now at no cost for 30 days.
After that:
To change your Sierra Chart Service Package, select "Help >> Account Control Panel" on the Sierra Chart program menu. On the displayed webpage, click on the "Set Service Package for Renewal" link.
Or go to this page:
https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation
You will need to login if you are not currently logged in.
In the "Available Services >> Choose Usage Time Service Package" frame, select the Service Package that you want to set your account to. Press the "Set" button.
The remaining service usage time on your account will be adjusted based upon the cost of the package you are changing to. If the new package is a higher-priced package, then the usage time will be reduced due to the higher price.
There is no charge for changing your Sierra Chart service package. Only your Sierra Chart account usage time ending date is adjusted.
When changing between Sierra Chart Service Packages, the usage time ending date on your Sierra Chart account is adjusted based upon the price differences between the package you are changing from and the package you are changing to.
When changing to a higher priced package, your usage time ending date will be brought back closer in time. When changing to a lower-priced package, your usage time ending date will be brought forward further out in time.
