Date/Time: Tue, 26 Nov 2024 15:38:37 +0000
VWAP on Weekly Charts
View Count: 247
[2023-11-12 09:51:06]
florian87 - Posts: 4
Dear SC Support Team,
I have noticed that the calculated VWAPs usually have the same values as the last prices of many futures contracts (see e.g. FDAX and NASDAQ in the attachment) on weekly charts. This issue does not occur on daily charts. I did not notice it on former versions of SC, either.
Could you fix this?
Kind regards,
Florian
imageScreenshot_2023-11-12_FDAX.png / V - Attached On 2023-11-12 09:40:33 UTC - Size: 696.36 KB - 74 views
imageScreenshot_2023-11-12_NASDAQ.png / V - Attached On 2023-11-12 09:40:39 UTC - Size: 682.79 KB - 64 views
[2023-11-14 15:56:06]
Sierra_Chart Engineering - Posts: 17182
There is nothing to fix at all. The calculations are 100% correct. Those screenshots also do not meet our requirements. They are overly complex and disregarded. Refer to:
The calculations are all well documented here:
Volume Weighted Average Price (VWAP) with Standard Deviation Lines
