Date/Time: Mon, 16 Sep 2024 19:20:15 +0000
Tick indexes not loading
View Count: 272
[2023-11-11 17:15:23] |
User394081 - Posts: 12 |
I have been using TICK-NYSE_NASDAQ_NYSEMKT for quite awhile. Today I wanted to try TICK_SP and it wouldn't load. I tried TICK_NYSE and it wouldn't load either. Any reason one market stat would load OK but others won't?
[2023-11-12 05:13:40] |
Sierra_Chart Engineering - Posts: 16387 |
Use: TICK-SP TICK-NYSE Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-11-12 07:08:06] |
Working now, thank you very much. Very strange. I understand I had a typo in my post TICK-SP not TICK_SP, but I had been using the "available symbols" menu to configure the study. Meaning it should have worked. It is working now so no problems. Either way, thank you for the response and I am a very satisfied customer. |
