Date/Time: Tue, 26 Nov 2024 15:24:10 +0000
[User Discussion] - Pivot Points Daily Settings
View Count: 225
[2023-11-11 05:43:45]
User895355 - Posts: 55
The docs say:
Use Daily Chart For Settlement Only
[Link] - [Top]
In many Pivot Point Formula Types, the Prior Close appears as a variable. If instead the user wishes to use the CME Settlement Price, that can be accomplished with the help of this Input. First, open a chart to which the Pivot Points - Daily study is to be applied, and apply the study. Call this Chart #1. Then, open a second (Daily) chart for the same symbol. Call this Chart #2.
Finally, apply the following Input Settings for the Pivot Points - Daily study on Chart #1.
Daily Chart Number = 2
Reference Daily Chart for Data = Yes
Use Daily Chart For Settlement Only = Yes
However, I'm not able to set both "Reference Daily Chart..." and "Use Daily Chart..." to "Yes". "Reference Daily Chart For Data" always reverts to "No".
Thanks for your help
[2023-11-11 15:30:22]
Sawtooth - Posts: 4120
Despite the documentation, is seems 'Reference Daily Chart for Data' and 'Use Daily Chart For Settlement Only' are mutually exclusive.
Add the Pivot Points - Daily study to the daily chart to see where the pivots should be.
These settings on the Intraday chart will match them:
Use Daily Chart For Settlement Only = No
