Date/Time: Tue, 26 Nov 2024 15:48:09 +0000
Charts Stacking at open of SC chart.
View Count: 201
[2023-11-10 23:30:42] |
User757746 - Posts: 11 |
I have 3 charts layed out on 2 monitors. Been working OK. Now upon closing and when reopening SC, the 3 charts are Stacked upon each other and I have to separate and spread back onto the 2 monitors. I assume I have hit a button that makes the charts Stack; but can not find where to correct. Using #2478. I use Save All at closed but they still open Stacked ?? |
[2023-11-11 01:42:36] |
Sierra_Chart Engineering - Posts: 17182 |
No, there is no automatic function in Sierra Chart that would do this. You would have to manually do something like a Window >> Cascade. For other causes, which are all operating system related, refer to: Window Size and Position Not Restored When Opening Chartbook Other users may have useful information and may comment on this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
