Date/Time: Tue, 26 Nov 2024 15:28:15 +0000
Trade activity log - period stats are not consistent when using different start dates
View Count: 313
[2023-11-10 18:10:09] |
User43 - Posts: 101 |
Hello, I'm currently running through several simulations and observed an odd result when looking at the Period Stats for the same day but with different start days. The attached pictures show the Jan 11 2022 once with many prior trades and then with only the data for the day. The number of trades is shown correctly but the Total profit for that day is not matching. As I write this it appears that when I have prior periods in the stats the stats don't switch from Currency to Points as I've selected. Why is that? Am I doing something wrong? Can that be solved? Any help is much appreciated. Thanks Martin |
SierraChart_64_xulHDeDlu6.png / V - Attached On 2023-11-10 18:04:43 UTC - Size: 20.71 KB - 67 views SierraChart_64_5FrFP4g5Kr.png / V - Attached On 2023-11-10 18:04:51 UTC - Size: 109.2 KB - 59 views |
[2023-11-11 13:44:36] |
I think I found it Trade Activity Log: Profit/Loss (P/L) Format sorry for not seeing that earlier regards Martin |
[2023-11-13 06:18:11] |
Sierra_Chart Engineering - Posts: 17181 |
If the issue is profit/loss values displaying as a Currency Value instead of Points, then refer to: Trade Activity Log: Profit/Loss (P/L) Format If there is some other issue then you have to look at the Fills on the Trade Activity tab to see what difference there is in the fills, between the different settings: Trade Activity Log: Viewing Historical Trade Activity Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-11-13 06:18:18
