Date/Time: Tue, 26 Nov 2024 14:21:22 +0000
not possible to load intraday data from csv file
View Count: 281
[2023-11-10 16:55:27]
User12089 - Posts: 361
using the following custom csv file data and loading it with File/Open Intraday Chart
following the instructions here:
Text/CSV Data Format
Date,Time,Open,High,Low,Close,Volume
9/11/23,21:15:00.0,4539,4539.5,4539,4539.5,0
9/11/23,21:16:00.0,4539.25,4539.75,4539,4539,435
9/11/23,21:17:00.0,4539,4539.25,4538.75,4538.75,43
9/11/23,21:18:00.0,4539,4539.25,4538.75,4538.75,
9/11/23,21:19:00.0,4539,4539.25,4539,4539,0
However the SC Chart consistently interprets the above data as Daily ie shows only ONE BAR per day ...
the above is intraday data and i am trying to obtain intraday chart
what is also interesting is that if u draw a volume profile it does appear as based on intraday data ...
however the price bars always appear as DAY bars
what is going on?
Date Time Of Last Edit: 2023-11-10 17:04:44
[2023-11-15 20:13:33]
anybody there?
[2023-11-16 18:30:37]
John - SC Support - Posts: 36286
You need to "Import" the data, not open the file as you did. Refer to the instructions here:
Exporting and Importing Intraday Data Files: Import and Load
