Date/Time: Tue, 26 Nov 2024 15:31:32 +0000
question about changing Font
View Count: 196
[2023-11-10 14:41:27] |
User117194 - Posts: 17 |
Also How do I change the font on the rectangle when I draw it on chart? Thanks |
Screenshot 2023-11-10 051630.png / V - Attached On 2023-11-10 14:41:12 UTC - Size: 19.02 KB - 60 views |
[2023-11-10 19:29:38] |
Sierra_Chart Engineering - Posts: 17181 |
Refer to: Chart Drawing Tools: Changing the Font Size For Text Displayed with Tool Drawings (Global Chart Drawing Font) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
