Date/Time: Tue, 26 Nov 2024 15:30:57 +0000
Current price line
View Count: 338
[2023-11-10 12:03:42] |
Ghosttrader - Posts: 33 |
Hello I have the current price line study for my TPO chart. I also have a volume profile next to it. I have the both set to run only during regular trading hours. However the current price will still operate after hours. I haven't been able to figure out the correct setting to stop this. Actually it's the last price line the one that's in the chart settings. I probably should have that one unchecked but It offers the ability to customize the box more so than the current price line. If I wanted to continue the last price line instead of using the current price line study is it possible to have it only run during the regular trading hours? thank you. Date Time Of Last Edit: 2023-11-10 12:30:30
[2023-11-10 19:28:56] |
Sierra_Chart Engineering - Posts: 17181 |
There is no Chart Setting for "last price line". With the Current Price Line study, set the Input: Use Last Trade Price from Current Quote Data to No. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-11-10 19:29:17
